Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    October 2012
    Yeah but what version of TeamSpeak? See Help -> About TeamSpeak 3
    Sorry Chris.
    Version 3.0.8.1
    TroubleGirl, Wasn't sure if you were responding to me or not.?
  2. #17
    6,079
    Please post a full client log and any hotkeys you have set.
    Client logs can be found in %AppData%\TS3Client\logs
  3. #18
    May 2014
    EDIT: I seem to have found a temporary solution, but please read below regardless. That temporary workaround is thus: create a new hotkey profile, and use that profile (you will have to switch manually on the main screen under the "self" tab, Hotkey section). You will have to re-add all your hotkeys to this new profile (In the options menu where you created it).
    Hello. I see that this thread is classed as "resolved" yet I see no solutions to the original problem. I now have this exact issue and can't find any more recent threads on it. I am sorry to dredge up this old thread, but I felt their information might be helpful to you. Please respond with any information you need.
    My problem is as follows: I can set hotkeys in the options menu. It clearly detects the keys, because it allows me to set them. These hotkeys (such as mute) work fine when not connected to a server. Additionally, the push to talk voice test menu works fine as well (push to talk key works in test mode).
    However, when in any server, the keys do not work, whether in or out of game (I play Mechwarrior Online only). This issue started for me today, but I hadn't used Teamspeak for a week when it started, so I don't know what may have happened. There was a recent Windows update that may have caused it. Both mouse and keyboard hotkeys do not work. I run Teamspeak in administrator.
    Hotkeyes set: u is toggle mike mute. Mouse 5 is Push To Talk "default"
    following are my text logs for today:
    2014-05-20 20:20:46.689238|INFO    |              |   | TeamSpeak 3 Client 3.0.14 (2014-03-12 11:49:03)
    2014-05-20 20:20:46.689238|INFO    |              |   | SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2014-05-20 20:20:46.689238|INFO    |              |   | Using hardware aes
    2014-05-20 20:20:46.777238|DEBUG   |Direct Sound  |   | setting timer resolution to 1ms
    2014-05-20 20:20:46.905238|INFO    |              |   | *** Time [SPAWN_EVENTCONVERTER]: 217
    2014-05-20 20:20:55.319238|INFO    |              |   | *** Time [ICONMANGER]: 8414
    2014-05-20 20:20:55.320238|INFO    |              |   | Loading plugin: appscanner_plugin
    2014-05-20 20:20:55.320238|INFO    |              |   | Loading plugin: clientquery_plugin
    2014-05-20 20:20:55.320238|INFO    |              |   | Loading plugin: lua_plugin
    2014-05-20 20:20:55.320238|INFO    |              |   | Loading plugin: teamspeak_control_plugin
    2014-05-20 20:20:55.320238|INFO    |              |   | Loading plugin: test_plugin
    2014-05-20 20:20:55.320238|INFO    |              |   | Loading plugin: ts3g15
    2014-05-20 20:20:55.336238|INFO    |Query         |   | listening on 127.0.0.1:25639
    2014-05-20 20:20:55.353238|DEBUG   |Overwolf      |   | Detected Overwolf start
    2014-05-20 20:20:59.870238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:20:59.870238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:21:00.968238|INFO    |              |   | *** Time [BUILD_GUI]: 1093
    2014-05-20 20:21:01.035238|INFO    |              |   | *** Time [SERVERVIEW]: 1175
    2014-05-20 20:21:01.399238|INFO    |              |   | *** Time [SERVERVIEWMANAGER]: 4783
    2014-05-20 20:21:03.496238|INFO    |              |   | *** Time [LOAD_usb_ids]: 1831
    2014-05-20 20:21:03.497238|INFO    |Input         |   | Default monitoring enabled
    2014-05-20 20:21:03.498238|INFO    |              |   | *** Time [HOTKEYS]: 1833
    2014-05-20 20:21:03.826238|INFO    |              |   | *** Time [MAINWINDOW]: 17243
    2014-05-20 20:21:03.826238|INFO    |              |   | *** Time [INIT]: 17243
    2014-05-20 20:21:11.678238|INFO    |              |   | *** Time [NOTIFICATIONS]: 7852
    2014-05-20 20:21:11.678238|INFO    |ClientUI      |   | Qt version: 5.2.1
    2014-05-20 20:21:11.679238|INFO    |ClientUI      |   | Using configuration location: C:\Users\michael.lovell\AppData\Roaming\TS3Client\settings.db
    2014-05-20 20:21:14.687238|INFO    |ClientUI      |   | Last update check was: Fri May 16 21:02:16 2014
    2014-05-20 20:21:17.948238|INFO    |              |   | Checking for updates...
    2014-05-20 20:21:17.998238|INFO    |TSDNS         |   | DNS resolve successful, "update.teamspeak.com"=176.9.148.78
    2014-05-20 20:21:44.358238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:21:44.358238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:21:44.508238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:21:44.508238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:21:44.509238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - enter
    2014-05-20 20:22:06.084238|INFO    |              |   | TeamSpeak 3 Client 3.0.14 (2014-03-12 11:49:03)
    2014-05-20 20:22:06.084238|INFO    |              |   | SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2014-05-20 20:22:06.084238|INFO    |              |   | Using hardware aes
    2014-05-20 20:22:06.173238|DEBUG   |Direct Sound  |   | setting timer resolution to 1ms
    2014-05-20 20:22:06.301238|INFO    |              |   | *** Time [SPAWN_EVENTCONVERTER]: 218
    2014-05-20 20:22:06.331238|INFO    |              |   | Loading plugin: appscanner_plugin
    2014-05-20 20:22:06.331238|INFO    |              |   | Loading plugin: clientquery_plugin
    2014-05-20 20:22:06.331238|INFO    |              |   | Loading plugin: lua_plugin
    2014-05-20 20:22:06.331238|INFO    |              |   | Loading plugin: teamspeak_control_plugin
    2014-05-20 20:22:06.331238|INFO    |              |   | Loading plugin: test_plugin
    2014-05-20 20:22:06.331238|INFO    |              |   | Loading plugin: ts3g15
    2014-05-20 20:22:06.349238|INFO    |Query         |   | listening on 127.0.0.1:25639
    2014-05-20 20:22:06.368238|DEBUG   |Overwolf      |   | Detected Overwolf start
    2014-05-20 20:22:16.094238|INFO    |              |   | *** Time [PERMISSIONSMANAGER]: 5356
    2014-05-20 20:22:16.095238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:22:16.095238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:22:19.960238|INFO    |              |   | *** Time [TREE]: 3865
    2014-05-20 20:22:22.755238|INFO    |              |   | *** Time [CHATTAB]: 2723
    2014-05-20 20:22:22.755238|INFO    |              |   | *** Time [SERVERVIEW]: 12026
    2014-05-20 20:22:22.765238|INFO    |              |   | *** Time [SERVERVIEWMANAGER]: 14140
    2014-05-20 20:22:23.778238|INFO    |Input         |   | Default monitoring enabled
    2014-05-20 20:22:23.778238|INFO    |              |   | *** Time [HOTKEYS]: 990
    2014-05-20 20:22:24.045238|INFO    |              |   | *** Time [MAINWINDOW]: 17964
    2014-05-20 20:22:24.185238|INFO    |              |   | *** Time [INIT]: 18104
    2014-05-20 20:22:28.841238|INFO    |              |   | *** Time [NOTIFICATIONS]: 4656
    2014-05-20 20:22:28.841238|INFO    |ClientUI      |   | Qt version: 5.2.1
    2014-05-20 20:22:28.841238|INFO    |ClientUI      |   | Using configuration location: C:\Users\michael.lovell\AppData\Roaming\TS3Client\settings.db
    2014-05-20 20:22:29.342238|INFO    |ClientUI      |   | Last update check was: Tue May 20 20:21:14 2014
    2014-05-20 20:23:01.199238|INFO    |ClientUI      |  1| Connect to server: shalom.teamspeak3.com
    2014-05-20 20:23:01.204238|INFO    |ClientUI      |  1| Trying to resolve shalom.teamspeak3.com
    2014-05-20 20:23:01.280238|INFO    |TSDNS         |   | SRV DNS resolve successful, "_ts3._udp.shalom.teamspeak3.com"=>"ts79.light-speed.com:6879" = 216.127.64.137:6879
    2014-05-20 20:23:01.280238|INFO    |ClientUI      |  1| Lookup finished: 216.127.64.137 6879 shalom.teamspeak3.com 0 0
    2014-05-20 20:23:01.281238|INFO    |ClientUI      |  1| Resolve successful: 216.127.64.137:6879
    2014-05-20 20:23:01.281238|INFO    |ClientUI      |  1| Blacklist check ok
    2014-05-20 20:23:01.281238|INFO    |ClientUI      |  1| Initiating connection: 216.127.64.137:6879 shalom.teamspeak3.com
    2014-05-20 20:23:01.319238|INFO    |TSDNS         |   | DNS resolve successful, "shalom.teamspeak3.com"=216.127.64.137
    2014-05-20 20:23:01.404238|INFO    |TSDNS         |   | TSDNS found at "teamspeak3.com" and queried successfully. Result: 216.127.64.137:6879
    2014-05-20 20:23:01.432238|INFO    |TSDNS         |   | SRV TSDNS found at "_tsdns._tcp.teamspeak3.com"=>"tsdns.light-speed.com:80" and queried successfully. Result: 216.127.64.137:6879
    2014-05-20 20:23:04.862238|INFO    |TSDNS         |   | TSDNS found at "shalom.teamspeak3.com" and queried successfully. Result: 216.127.64.137:6879
    2014-05-20 20:23:14.183238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:23:14.183238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:23:14.183238|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2014-05-20 20:23:14.196238|DEBUG   |Windows Audio Session|   | WAS Buffer size: 960
    2014-05-20 20:23:14.196238|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2014-05-20 20:23:14.196238|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2014-05-20 20:23:14.196238|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2014-05-20 20:23:23.323238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:23:23.323238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:23:23.323238|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2014-05-20 20:23:23.505238|DEBUG   |Windows Audio Session|   | WAS Buffer size: 896
    2014-05-20 20:23:23.506238|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2014-05-20 20:23:23.506238|INFO    |PreProSpeex   |  1| Speex version: speex-1.2beta3
    2014-05-20 20:23:23.506238|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2014-05-20 20:23:23.507238|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2014-05-20 20:23:23.649238|INFO    |ClientUI      |  1| Connect status: Connecting
    2014-05-20 20:23:23.712238|DEVELOP |PktHandler    |   | Puzzle solve time: 9
    2014-05-20 20:23:24.022238|INFO    |ClientUI      |  1| Connect status: Connected
    2014-05-20 20:23:24.156238|INFO    |ClientUI      |  1| Connect status: Establishing connection
    2014-05-20 20:23:24.389238|INFO    |ClientUI      |  1| Connect status: Connection established
    2014-05-20 20:23:24.426238|INFO    |PermManager   |   | Loading permissions from cache
    2014-05-20 20:25:00.186238|INFO    |ClientUI      |  1| Connect status: Disconnected
    2014-05-20 20:25:00.428238|INFO    |ClientUI      |  1| Disconnected or forced to leave, want autoreconnect = 0
    2014-05-20 20:25:10.670238|INFO    |Bookmarks     |   | Disconnect, total time: 102 - 62291
    2014-05-20 20:25:13.646238|DEBUG   |Windows Audio Session|   | WAS::associateAECDevice-enter
    2014-05-20 20:25:13.646238|DEBUG   |Windows Audio Session|   | WAS::associateAECDevice-leave
    2014-05-20 20:25:13.646238|DEBUG   |Windows Audio Session|   | WAS::stopDevice-enter
    2014-05-20 20:25:13.646238|DEBUG   |Windows Audio Session|   | WAS::stopDevice-leave
    2014-05-20 20:25:13.646238|DEBUG   |Windows Audio Session|   | WAS::closeDevice-enter
    2014-05-20 20:25:13.646238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - enter
    2014-05-20 20:25:13.646238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - leave
    2014-05-20 20:25:13.646238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - enter
    2014-05-20 20:25:13.646238|DEBUG   |Windows Audio Session|   | WAS::closeDevice-leave
    2014-05-20 20:25:13.646238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:25:13.647238|DEVELOP |Windows Audio Session|   | Waiting for device to close
    2014-05-20 20:25:13.647238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - leave
    2014-05-20 20:25:13.647238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:25:26.370238|DEBUG   |Windows Audio Session|   | WAS::stopDevice-enter
    2014-05-20 20:25:26.370238|DEBUG   |Windows Audio Session|   | WAS::stopDevice-leave
    2014-05-20 20:25:26.370238|DEBUG   |Windows Audio Session|   | WAS::closeDevice-enter
    2014-05-20 20:25:26.370238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - enter
    2014-05-20 20:25:26.370238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - leave
    2014-05-20 20:25:26.370238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - enter
    2014-05-20 20:25:26.370238|DEBUG   |Windows Audio Session|   | WAS::closeDevice-leave
    2014-05-20 20:25:26.370238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:25:26.370238|DEVELOP |Windows Audio Session|   | Waiting for device to close
    2014-05-20 20:25:26.372238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - leave
    2014-05-20 20:25:26.372238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:25:26.522238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2014-05-20 20:25:26.522238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2014-05-20 20:25:26.523238|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - enter
    Those are the first two. I have about 20 more if you really need them (I've been trying to fix this and restarting it a lot)
    Thanks for any help you can provide.
    -Faolind
  4. #19
    May 2014
    UPDATE: The issue is still occurring. The workaround of creating a new hotkey profile works, but is only temporary. I have to keep creating new profiles. Please work on this issue.
  5. #20
    May 2014
    UPDATE: The workaround is no longer working. Why does no one post here but me? Could someone please help?
  6. #21
    May 2014
    Quote Originally Posted by Faolind View Post
    I am in the same boat as you my friend, I've used 3 microphones and none of them work. However they work on other voice chats.
  1. [Resolved] PTT Hotkeys not Working
    By GPMMoonShine in forum Windows
    Last Post: March 12th, 2015, 04:49 AM
  2. TS3 Hotkeys not working...
    By Abuser in forum Windows
    Last Post: June 3rd, 2014, 10:04 AM
  3. Hotkeys not working?
    By DanTheHumann in forum General Questions
    Last Post: December 14th, 2013, 07:10 PM
  4. Hotkeys not working
    By thecakeisalie in forum Windows
    Last Post: September 25th, 2012, 02:45 PM
  5. None of my hotkeys are working...
    By McJamesV in forum Windows
    Last Post: February 27th, 2012, 11:14 AM
