Results 1 to 4 of 4
    July 2012
    Yet another port 9987 Issue
    I have been through the forums and all of google looking for an answer but to no avail.
    Hopefully, someone can help me fix this issue.
    I am running Windows 7. I have a TS3 server set up and until not too long ago it was working fine. (Linksys router)
    Recently I purchased a new router (Belkin) and went about setting up the port forwarding just as I had on my old router.
    Except now people cannot connect to my server though I still can (localhost)
    When I have the server up and running I port checked and found that 10011 and 30033 were open and working fine.
    However, port 9987 returned a connection timed out message. I tried putting my computer outside the firewall using DMZ just to check if for some reason the router was not forwarding a port correctly. Same result, connection timed out. I then disabled my windows firewall to see if that was causing the issue. Now instead of receiving a connection timed out message I get a connection refused message.
    After performing these steps I believe that my router is forwarding the ports correctly and that the windows firewall (currently disabled) is not causing the issue either.
    I have no idea why the connection to port 9987 is being refused. To my knowledge my ISP does not block the port either since I have friends using the same ISP and their TS servers work fine using the same port.
    Any ideas you could give me concerning this issues would be much appreciated. Thanks in advance.
    2,029
    Make sure the Server is actually running (the Virtual TS3 Server that is), also check the Server Logs and post them.
    August 2012
    GA
    19
    What were you using to check the ports? Port checking sites do not/can't check UDP ports.
    2,698
    Quote Originally Posted by Rooster2xl View Post
    Belkin, this model?
    F5D7234-4v3
    http://www.belkin.com/uk/support/art...d=14477&scid=0
  1. Port 9987 won't open
    By AM-99 in forum Server Support
    Last Post: November 20th, 2016, 08:16 PM
  2. port 9987 not working
    By modyghost in forum Linux / FreeBSD
    Last Post: September 4th, 2015, 04:18 PM
  3. Port 9987 not listening
    By kaski in forum Linux / FreeBSD
    Last Post: March 22nd, 2012, 01:02 AM
