Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    July 2012
    25
    issue chrooting ts3
    Is there a way to invoke ts3server_linux_x86 directly without using a shell .sh script?
    Also has anyone managed to get a chroot to work with ts3, or am I stuck with the less secure and unsupported ts2?
    July 2012
    25
    I think some background is in order. It is a FC14 x86 VM I pay to have hosted.
    I currently have enemy-territory successfully chrooted and running screen on it. (http://tjw.org/etded/ <---good start)
    ET itself takes up about 80% of resident memory due to amount of modifications present. Before my last compromised event I had it on a daily reboot schedule. I have managed to tweak things now and things have been running for almost 3 months with no issues at this point with no reboots.
    I can get teamspeak3 to run if not in a chroot.
    The concern is one of making it more hack proof, given TS's history of being quite hackable due to default insecure behavior of the application itself. Some of that behavior can be modified, however.
    I can get it to run with screen and get it to run with init scripts. The problem is I want to invoke screen as I chroot it as I have with ET.
    The other thing that is occuring to me is that I may not be able to run concurrent Chroot jail directory structures. I can try adding the teamspeak daemon to the existing chroot and see if I can make it run that way which is the only thing I have not tried as of yet.
    The other thing to point out is that with the new era of virtualization there has been an emphasis removed from file system rights and security lock down as "It's a VM, I can just reload the latest snapshot". This is a bad precedence and habit. Just having another level of safety and security does not remove your responsibility to lock down your systems.
    Now that you have some background on my brain wracking conundrum, does anyone have any input on what one might do to help lock things down properly?
    2,029
    cd /path/to/teamSpeak/Folder && export LD_LIBRARY_PATH="." && ./ts3server_linux_<arch>
    should work in theory.
    July 2012
    25
    I had to rebuild with stock steps from:
    http://www.feldstudie.net/2009/12/22...how-to-chroot/
    It then worked on the new built from scratch dir structure.
    I found that this command seemed to launch it by itself:
    cd /home/chroot/ts3/home/ts3 && export LD_LIBRARY_PATH="." && ./ts3server_linux_x86 dbplugin=ts3db_mysql
    since I want to use MYSQL.
    July 2012
    25
    2012-07-24 01:06:55.281592|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6 (2012-06-21 04:43:35)
    2012-07-24 01:06:55.369072|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
    2012-07-24 01:06:55.369170|INFO |DatabaseQuery | | dbPlugin version: 1
    2012-07-24 01:06:55.702698|ERROR |DatabaseQuery | | mysql_real_connect() failed with error: Access denied for user 'root'@'localhost' (using password: NO)
    2012-07-24 01:06:55.702795|CRITICAL|ServerLibPriv | | Server() DatabaseError
    Now I just can't seem to get su to see the user account, but I have always had that problem. Given that it is Fedora Core I have to wonder if the folks haven't done something weird with chroot to cause it to only allow one chroot directory structure.
    With the enemy territory server running for 90 days without a reboot, I don't think a reboot would fix things.
    July 2012
    25
    for the database part I did this:
    shell> mysql -u root
    mysql> SET PASSWORD FOR 'root'@'localhost' = PASSWORD('newpwd');
    mysql> SET PASSWORD FOR 'root'@'127.0.0.1' = PASSWORD('newpwd');
    # mysql -u root -p
    use mysql;
    INSERT INTO user (Host,User,Password) VALUES('%','teamspeak',PASSWORD('pwd'));
    flush privileges;
    create database teamspeak;
    grant all privileges on teamspeak.* to [email protected];
    flush privileges;
    Then I figured out things by RingTFM
    ./ts3server_linux_x86 dbplugin=ts3db_mysql dbsqlcreatepath=create_mysql/
    that gets it to use the mysql plugin instead of the default sqllite plugin
    I run this string in chroot:
    export LD_LIBRARY_PATH="/home/ts3" && /home/ts3/ts3server_linux_x86 dbpluginparameter=ts3db_mysql.ini dbplugin=ts3db_mysql inifile=ts3server.ini
    the passwd file in the chroot:
    ts3:x:611:611::/home/ts3:/home/ts3/ts3server_linux_x86
    the relevant line in the /etc/passwd file
    ts3:x:611:611::/home/chroot/ts3:
    Then I noticed I need to allow the user on the db
    flush privileges;
    July 2012
    25
    I got it somewhat working at this point:
    running: chroot /home/chroot/ts3 su - ts3
    gets:
    2012-07-26 01:00:50.528730|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6 (2012-06-21 04:43:35)
    ERROR: openFile( file:logs/ts3server_2012-07-26__01_00_50.527255_0.log) failed
    2012-07-26 01:00:50.529967|INFO |DatabaseQuery | | Please make sure you use the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRARY_PATH yourself
    2012-07-26 01:00:50.530038|CRITICAL|DatabaseQuery | | unable to load database plugin library "libts3db_sqlite3.so", halting!
    You have new mail in /var/spool/mail/root
    To get to that point I had to edit /etc/passwd to:
    ts3:x:611:611::/home/chroot/ts3/./home/ts3:
    and edit /home/chroot/ts3 to:
    To come to the conclusion I needed to change the account on /etc/passwd I had to run:
    jk_jailuser -m -j /home/chroot/ts3 testuser
    I then copied the resulting line in /etc/passwd to the ts3 account.
    2,029
    Make sure the libts3db_sqlite.so is executable (+x) and owned by the user who is running the ts3 server. Aso use ts3server_startscript.sh start to run the server!
    July 2012
    25
    Quote Originally Posted by SilentStorm View Post
    You do make a very valid point, and that is how one would normally do it. But, as others at my work have said, I invented the box since I think outside of it so much.
    I have looked over the scripts and I can see some great amounts have been thought to try and "idiot proof" things. The other thing I am trying to do in all of this is learn and understand linux to a greater extent.
    The other thing is that scripts can be modified. To prevent malicious alteration and execution, I am trying to set it so that I can directly launch the program so that I can call it using screen.
    I do greatly appreciate your comment, and if I can't get things to otherwise work, I will use your recommendation. I will probably use it in any case when I go to turn the launching of the program to a true service.
    July 2002
    2,192
    The user running the server will need permissions to create files in the logs subdirectory.
    The failure to load libts3db_sqlite3.so can have multiple causes: Make sure your LD_LIBRARY_PATH is indeed set correctly, and also make sure that the user running teamspeak has read permissions on the library.
    You think my answer is stupid ? Read This:
    http://www.catb.org/~esr/faqs/smart-...ons.html#intro
    In a world without fences and walls - who needs windows and gates ?
    July 2012
    25
    Hmm... I already had TS3 set to own everything. It appears that I must chroot mysql as well. I am not sure if that deficiency is not causing the errors when invoking the executable alone.
    2012-07-28 14:00:42.099825|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6 (2012-06-21 04:43:35)
    2012-07-28 14:00:42.117070|INFO |DatabaseQuery | | Please make sure you use the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRARY_PATH yourself
    2012-07-28 14:00:42.117141|CRITICAL|DatabaseQuery | | unable to load database plugin library "libts3db_sqlite3.so", halting!
    [[email protected] bin]# chroot /home/chroot/ts3 su - ts3 dbpluginparameter=ts3db_mysql.ini dbplugin=ts3db_mysql inifile=ts3server.ini
    2012-07-28 14:02:28.140928|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6 (2012-06-21 04:43:35)
    2012-07-28 14:02:28.217638|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
    2012-07-28 14:02:28.217774|INFO |DatabaseQuery | | dbPlugin version: 1
    2012-07-28 14:02:28.231433|ERROR |DatabaseQuery | | mysql_real_connect() failed with error: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
    2012-07-28 14:02:28.231693|CRITICAL|ServerLibPriv | | Server() DatabaseError
    July 2012
    25
    having already installed mysql i Muxxed things up slightly. I had to copy all files for mysql to:
    /home/chroot/ts3/var/lib and preserve the directory structure.
    If I forgot a file I would get this error:
    Starting MySQL ERROR! Couldn't find MySQL manager (/home/chroot/ts3/var/lib/mysql/bin/mysqlmanager) or server (/home/chroot/ts3/var/lib/mysql/bin/mysqld_safe)
    Apparently file relational location has to be preserved as well.
    Source file locations:
    /var/lib/mysql
    /usr/bin (anything mysql)
    /usr/lib/mysql
    /usr/sbin (anything mysql)
    Then I had to edit /etc/init.d/mysql and add this:
    basedir=/home/chroot/ts3/var/lib/mysql
    datadir=/home/chroot/ts3/var/lib/mysql
    If you are doing a fresh install this may be a better option:
    http://www.symantec.com/connect/arti...ysql-step-step
    July 2012
    25
    had to add /etc/my.cnf
    with:
    [client]
    port=3306
    socket=/home/chroot/ts3/var/lib/mysql/mysql.sock
    [mysqld]
    port=3306
    key_buffer_size=16M
    max_allowed_packet=8M
    [mysqldump]
    quick
    I had to fix these issues:
    '/var/lib/mysql/mysql.sock' (13) chmod mysql dir to 755
    '/var/lib/mysql/mysql.sock' (2) ledit socket lines on the my.cnf file
    '/var/lib/mysql/mysql.sock' (111) delete mysql.sock (has bad info causing the problem)
    mysqladmin -u root -p status shows if server is running or not and it's status
    Now I get:
    2012-07-29 13:02:57.910953|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6 (2012-06-21 04:43:35)
    2012-07-29 13:02:57.976238|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
    2012-07-29 13:02:57.976352|INFO |DatabaseQuery | | dbPlugin version: 1
    2012-07-29 13:02:58.165541|ERROR | | | Error reading the PRNG.
    2012-07-29 13:02:58.171491|CRITICAL| | | Encryption::initialize not called (yet)!!
    Further along, we are.
    July 2012
    25
    I will try compiling from source as mentioned in the symantec article. I believe some hard coded depdencies are causing some issues with TS3 and MySQL trying to connect to the database in the jailed structure
    source that works from the horses mouth:
    http://dev.mysql.com/downloads/
    download version 5.0 ONLY!!!!
    July 2012
    25
    I got it working compiled from source but get stopped trying to initialize encryption
    2012-08-11 13:14:13.236694|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6 (2012-06-21 04:43:35)
    2012-08-11 13:14:13.297379|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
    2012-08-11 13:14:13.297484|INFO |DatabaseQuery | | dbPlugin version: 1
    2012-08-11 13:14:13.363940|ERROR | | | Error reading the PRNG.
    2012-08-11 13:14:13.374628|CRITICAL| | | Encryption::initialize not called (yet)!!
  1. TS Issue
    By JoshO in forum Client Support
    Last Post: March 5th, 2014, 08:49 PM
  2. mic issue
    By ExtremeRuneGuides in forum Client Support
    Last Post: May 10th, 2013, 09:29 AM
  3. ts3 issue
    By crazedstickman in forum Client Support
    Last Post: August 5th, 2010, 10:23 AM
