Results 1 to 6 of 6
    July 2012
    Solved import/export identity problem on Ubuntu 12.04
    i have two pc at home ..
    my office pc runs ubuntu 12.04 x64 with last version of teamspeak ...
    i also have a notebook with dual boot on windows xp and ubuntu 12.04 x86
    i want to export my identity from office pc to notebook ... i use a fat32 usb key for that ...
    once my identity is on the usb key , i start my notebook
    first , i use windows session , start TS , identity import , grab the file on my usb key ....
    no problem .... great ....
    i reboot my notebook to start ubuntu session , start TS , identity , import but ... ( there's always a but .. ) my ubuntu session does not see my identity file (jeromets.ini) which is on the usb key ....
    Even nautilus can see the file but i am unable to import it because there's no such file in dialog box of TS
    i have tried to chmod my .ini file ...
    i have added .ini in the name just in case it could be a problem with its extension ...
    Still no luck
    even with the same pc ( on ubuntu ) , i can export a identity file but i can't see it when i try to import ...lol
    any idea ??
    thanks for reading me
    Best regards , Jérôme
    18,513
    What happens , when you just copy it from the stick onto your hard drive and load from there?
    July 2012
    hello
    i just copied my .ini file to my home folder .... i can see it with nautilus ...
    when i try to import with TS , there's a dialog box and it asks for the .ini file ... unforttunately i can't see any .ini file ..
    strange thing ...
    you can reproduce the bug if you want
    start TS , go to identity , export your file to whatever place you want ...
    close TS , restart TS and try to import the file you have exported just before ...
    you won't see it thru ts even if nautilus says the file is here
    best regards
    Jérôme
    18,513
    I can see and use the ini file, after i have stored it on my desktop.
    July 2012
    Thanks for the answer .....
    well , i can see the ini file i have exported on my desktop with nautilus
    but when i try to import this .ini file , the dialog box doesn't see any .ini file on my desktop ....
    Finally , i found a way to do it ...
    i have first to tick on the icon " Entrez le nom du fichier " ( enter file name manually ) , then write the name of the .ini file to be able to choose it ....
    thanks for your support
    problem solved
    Best regards
    Jéjé
    18,513
    I'm sorry, that you can not see the file, i had no problems :-(
  1. Import and Export Data
    By Piyush Chandra in forum Off Topic
    Last Post: December 7th, 2011, 02:10 PM
  2. identity import/export
    By LMP67 in forum General Questions
    Last Post: December 31st, 2009, 12:15 PM
  3. [Bug] Identity import/export filename extension
    By nobleclem in forum Bug Reports [EN/DE]
    Last Post: December 20th, 2009, 08:20 PM
  4. Replies: 1
