Results 1 to 10 of 10
    May 2012
    The 3rd dimension
    956
    Solved Issues connecting to a running server. CentOS
    I have done all the steps and the server is now listening on 0.0.0.0:9987 and I have checked with the status switch and it says the server is running, which I have also verified with ps -e
    The problem is I cannot connect to the server. The VPS provider has assured me I have been whitelisted for UDP access yet the port looks closed for some reason when I use a scanning site to check. Have I done something wrong?
    July 2006
    1,600
    Do you have a firewall installed?
    May 2012
    The 3rd dimension
    956
    I have not installed any, nor even know how. They have assured me there should be nothing blocking the port.
    18,513
    Morthawt
    I wonder, why your server does not work. you have started so many threads about server quetions and suggestions.
    So I guess this server worked before?
    May 2012
    The 3rd dimension
    956
    I have a hosted server, I am now experimenting however with setting up one on my VPS from scratch. I can telnet to the file transfer and query ports but I cannot connect to the server with my client.
    18,513
    Are you sure that the server is running and not crashed directly after the start?
    You said it is running, but what does the log say?
    Example for a crash on Cent OS
    2012-07-24 01:47:38.110096|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2012-07-24 01:47:38.111694|ERROR |Accounting | | failed to register local accounting service
    2012-07-24 01:47:38.111752|ERROR |ServerLibPriv | | Server() error while starting servermanager, error: instance check error
    Please check your server logs first.
    Does your vps has more then 1 IP?
    May 2012
    The 3rd dimension
    956
    I was having that issue but I found some article that got it working. The logs now say its listening on all 3 ports successfully.
    edit: 1 IP
    July 2006
    1,600
    No firewall is no good
    But also check
    PORT=9987; netstat -a | grep $PORT
    and see if the server is really listening on the respective udp port.
    You can additionally check if you can establish a telnet connection to serverquery.
    May 2012
    The 3rd dimension
    956
    I already am able to telnet into the file transfer and query ports from my machine. I am a linux noob btw so I do not understand what that is you typed.
    May 2012
    The 3rd dimension
    956
    Seems the guy did something and its working now. Thanks guys.
  1. Issues setting up server on CentOS 7 VPS
    By mangusbrother in forum Linux / FreeBSD
    Last Post: November 16th, 2014, 04:29 AM
  2. CentOS: Server running but unable to connect
    By Glotty in forum Server Support
    Last Post: October 13th, 2013, 06:11 PM
  3. [Resolved] Error starting server on vps running centos 5
    By Samkitz in forum Linux / FreeBSD
    Last Post: July 24th, 2012, 10:51 PM
  4. CentOS: Issues with Connecting to http://{myIP}:14534
    By darthvader666uk in forum Linux / FreeBSD
    Last Post: May 25th, 2012, 09:00 AM
  5. TS3 -> Error on running server on CentOS
    By KevinsL in forum Linux
    Last Post: June 28th, 2011, 07:30 PM
