Results 16 to 30 of 31
  1. #16
    January 2011
    Australia
    Gotta say I was really pissed when I accidentally updated and the automatic volume decreaser thing wasn't there anymore - that was extremely useful.
  2. #17
    May 2007
    Eastern NC
    1,800
    Quote Originally Posted by Drizzles View Post
    They have been keeping it updated on the addons site. Can be found here.
  3. #18
    February 2012
    Denmark
    This batch file will be good too have - in case you exit a program while someone is talking the volume stays modified next time you open it.
    The script resets all the Application custom volumes in Windows Mixer. (aka. fixing "problems" caused by Volume Control Plugin)
    Please note, all sound will stop when running this. And you maybe need to restart a few programs to get sound from them again.
    @ECHO OFF
    ECHO Reset Volume Mixer Settings...
    NET STOP Audiosrv
    NET STOP AudioEndpointBuilder
    REG DELETE "HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertySt ore" /F
    REG ADD "HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertySt ore"
    NET START Audiosrv
    (Stolen from this place)
  4. #19
    September 2013
    I believe that I may have narrowed down one of the cases that causes the client to crash.
    It seems to happen when a new audio application is to or removed from the mixer while speaking. It might just be when removed. I suspect that the plugin doesn't properly handle the list of programs with audio changing out of under it, dying when it goes to restore the volumes.
    It's a shame that the source for it hasn't been released so that no one can fix it. I've been toying with the idea of writing my own replacement, but I haven't had time to read up on the Windows audio APIs.
  5. #20
    March 2014
    After I updated Teamspeak to version 3.0.14 I tried to install Volume Control with API 20 (attached file), but an error always occurs saying that extracting is failing. I asked a friend and he got the same issue.
    May you check the API20-File?
    Btw: Thanks for this Add-On. It really helps not to silence every task manually and I can't imagine playing games without.
  6. #21
    November 2013
    57
    a workaround to get this plugin installed:
    The "*.ts3_plugin" files are pretty much only simple zip archives, so you can rename the file and change the filetype to ".zip" and open it with whatever tool you have installed for zips.
    Then just extract the dlls into ".../Teamspeak 3 Client/plugins/"
  7. #22
    May 2013
    Broken since the update to 3.0.14. "Plugin failed to load: API version is not compatible".
    Edit: I was using API19 version, think I need API20 :\
  8. #23
    March 2014
    Same here....although I have found this nice replacement:
    http://addons.teamspeak.com/director...y)-remake.html
  9. #24
    March 2014
    Quote Originally Posted by Goreki View Post
    Changing the file ending works.
    Thanks for the quick response
    Unfortunately your rework doesn't suit me due to your own argument concerning resetting to 100% Volume.
  10. #25
    18,423
    Quote Originally Posted by ragnarok246 View Post
    Plugin fpr API20 is linked in post #1.
  11. #26
    November 2013
    57
    Perhaps you could apply your own workaround to this, so it actually works.
    And thanks for the red bar of shame.
  12. #27
    18,423
    Has nothing to do with wrong api version.
    I won't change the package content. I know that our developers will fix this soon.
  13. #28
    May 2014
    Having trouble installing volume control plugin
    Hey guys. So first of all I have 2 drives, my SSD with my OS and my HDD. I used to have TS on my HDD, but teamspeak "rights" wouldn't install there, so I decided today to move it to my SSD where installing the rights did work. However, now I am having trouble installing the volume control plugin that's kind of a staple to my teamspeak use.
    Here's a link to that plugin
    When I extract the .zip file and then open the result with package_inst.exe, I get the following error: http://i.imgur.com/Vb96Vqh.png
    This may be because of security or permissions on my SSD, but I tried giving as many things as possible full control and it didn't seem to work. Any help would be appreciated, thanks in advance.
  14. #29
    18,423
    Just rename Volume_Control_API20.ts3_plugin to Volume_Control_API20.zip and then try to exract it manually into the clients folder.
    If it still won't extract, then redownload the package again. I can extract it here.
  15. #30
    May 2014
    Thanks, that worked.
  1. Replies: 2
    Last Post: July 8th, 2015, 11:39 AM
  2. Please Update this Plugin ""Connection History"" Or Include to Client Version
    By varela1george in forum Suggestions and Feedback
    Last Post: October 13th, 2012, 08:28 AM
  3. Replies: 15
    Last Post: June 20th, 2012, 01:51 PM
  4. [Rejected] Volume Control "suggestion"
    By SS Raptor in forum Suggestions and Feedback
    Last Post: November 7th, 2011, 08:04 AM
