Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    18,413
    "Volume Control Plugin" collection
    The plugin is not under development anymore, we only update the api versions.
    It was removed out of the client setup, because it does cause to many crashes.
    click me to get the latest version
    Older versions
    Attached Files Attached Files
    April 2012
    12
    Since a little while back, this plugin's "Winamp-only" feature stopped working properly.
    When it reduces the volume, it only does it for a fraction of a second. So when people are talking on TS, it will only reduce the volume at the start for like half a second, and then it goes back to normal - even if people still are talking.
    Without the "Winamp-only" feature it works fine. But I would love to see a future feature that allows you to exclude processes/programs that it shouldn't touch the volume on. (for example a game's volume).
    Win 7 Pro / Winamp 5.63
    18,413
    The older version had sucha bug yes, but this should be fixed.
    This plugin was removed, because it does cause to much problems at some users.
    April 2012
    12
    I really hope you will continue to work on this plugin. It's extremely useful for very many users.
    I'm trying to figure out why Winamp-only is not working on my system. How does the plugin control Winamp's volume? Does it send 'keypresses' by using Global Hotkeys?
    18,413
    I'm not the author i just provide this plugin with latest Api version. I guess it does detect Winamp on Winodw's Volume mixer and just reduce the volume. I have no hotkeys enabled on Winamp.
    April 2010
    GER - Hamburg
    46
    Just if someone is interested:
    You can use window commands to communicate with winamp.
    August 2012
    The odler version had sucha bug yes, but this should be fixed.
    I'm afraid that the Winamp-only bug has not been fixed. I had to revert my music bot back to 3.0.5 because of this.
    What happens is when someone begins to speak, the Winamp volume 'flickers' to the volume it would normally be set to, but is instantly returned to what it was before no matter how you do the settings.
    I was using 3.0.8.1 32-bit. I hope you can fix this because it's an integral feature for my music bot and I'd like to upgrade its software as soon as possible.
    Also, you should really include this plugin with the application again, just don't keep it enabled by default anymore. I was introducing people to the program and one of them asked if they could reduce the volume of people speaking, and there was a lot of confusion when Volume Control was no longer there.
    May 2007
    Eastern NC
    1,800
    API 19 would be nice for beta channel users... even if just posted to the thread until 3.0.9 goes public for everyone.
    18,413
    Api 19 was added here for the latest beta client.
    October 2012
    I love this plugin and as I use a desktop mic with Teamspeak while gaming, consider it essential.
    It is, however, missing one small feature that would really help; the ability to also turn down Teamspeak itself (or at least people talking in my channel) when my mic is open, in addition to all other applications as it functions now. Eliminating splashback from my games and such is great but people hearing themselves if I happen to accidentally talk at the same time is still a problem.
    October 2012
    553
    From the description, this should be what options -> Capture -> Echo reduction does.
    Tried that already?
    While here, if I may ask naively about the plugin myself...
    If I get this correctly from the console output, the plugin does exactly what I coded recently in an unrelated project myself: Manually iterating the audio sessions and manipulating their mixer values. However, while I need exactly that, I am wondering why this route was chosen here, as with the same windows version (7) also the eCommunications role was introduced. To me it seems an already provided feature is reimplemented and the question arises why (just out of curiosity).
    As it seems I have never heard the OS Variant in work, maybe it just sucks. Always figured the plugin would work with that until I saw it.
    Unrelated: Source code still possibly released with 3.1? Values-To-Restore tend to wander to silence over time.
    November 2012
    I'm having a bit of a problem with this, I have the latest plugin installed with the latest TS3, API versions match. The plugin has no effect on my volume regardless of settings it just doesn't do anything at all. it is definitely ticked and enabled. I have dissabled Windows 7's own voip volume attenuation but this hasn't had any effect on the problem. Running Win7 x64 with a Xonar DX.
    edit:
    Forget this, updated my xonar drivers and everything is happy!
    April 2011
    The plugin does not save settings. You have to adjust every time you start the client. Client 3.0.10. API 19.
    August 2003
    NJ
    32
    I would really like to see an exception list. I have in game coms that we use too, and when I use this, it makes it hard to hear those coms.
    March 2013
    Api version is not compatible api 19 i think work
  1. Replies: 2
    Last Post: July 8th, 2015, 11:39 AM
  2. Please Update this Plugin ""Connection History"" Or Include to Client Version
    By varela1george in forum Suggestions and Feedback
    Last Post: October 13th, 2012, 08:28 AM
  3. Replies: 15
    Last Post: June 20th, 2012, 01:51 PM
  4. [Rejected] Volume Control "suggestion"
    By SS Raptor in forum Suggestions and Feedback
    Last Post: November 7th, 2011, 08:04 AM
