Results 1 to 4 of 4
    August 2012
    Failed to Start TS3 (Too many slots)
    greetings friends
    I have a Problem with teamspeak 3 server and I would like to help me fix
    8-03 17:07:00.009727 | INFO | ServerLibPriv | | TeamSpeak 3 Server 3.0.6.1 (6/29/2012 7:59:05)
    03/08/2012 17:07:00.010629 | INFO | DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c) TeamSpeak Systems GmbH
    03/08/2012 17:07:00.010705 | INFO | DatabaseQuery | | dbPlugin version: 3.7.3
    03/08/2012 17:07:00.011482 | INFO | DatabaseQuery | | checking database integrity (may take a while)
    03/08/2012 17:07:00.106741 | INFO | SQL | | db_CreateTables () tables created
    03/08/2012 17:07:02.232496 | INFO | Accounting | | Licensing Information
    03/08/2012 17:07:02.232624 | INFO | Accounting | | type: Non-profit
    03/08/2012 17:07:02.232775 | INFO | Accounting | | starting date: Thu November 10 00:00:00 2011
    03/08/2012 17:07:02.232874 | INFO | Accounting | | ending date: Sat 10 November 2012 00:00:00
    03/08/2012 17:07:02.232972 | INFO | Accounting | | virtualservers max: 10
    03/08/2012 17:07:02.233101 | INFO | Accounting | | max slots: 512
    03/08/2012 17:07:02.277650 | INFO | FileManager | | listening on 0.0.0.0:30033
    03/08/2012 17:07:02.288775 | INFO | VirtualSvrMgr | | executing monthly interval
    03/08/2012 17:07:02.289282 | INFO | VirtualSvrMgr | | traffic statistics reset VirtualServer
    03/08/2012 17:07:03.242507 | INFO | CIDRManager | | query_ip_whitelist ips updated: 127.0.0.1,
    03/08/2012 17:07:03.243683 | INFO | Query | | listening on 0.0.0.0:10011
    03/08/2012 17:07:07.133550 | ERROR | Accounting | | hosted too many slots, shutting down!
    03/08/2012 17:10:54.437247 | INFO | ServerMain | | Received signal SIGTERM, shutting down.
    the only mistake That brand is hosted Many slots, shutting down!
    and saw the TS3 unable to open
    2,029
    You already noticed the Error: You are hosting more than 512 Slots on the License.
    There are multiple possibilities:
    • Your License is being used elsewhere, either by yourself or someone else.
    • TS3 Server is already running with that License.
    • You recently killed the Instance without properly shutting it down (either on same machine or elsewhere), which causes your Slots to still be allocated at the License Server, hence you cannot start the server. In this case just wait 3 hours before attempting to start the server again.
    • You are indeed hosting more than 512 Slots total. In this case you need to edit the server using the query interface to reduce the slots (use port=PORT -virtual and then serveredit virtualserver_maxclients=32).
    Last edited by Chris; November 27th, 2014 at 08:57 AM. Reason: updated ancient post to include new capabilities of current TeamSpeak versions
    November 2014
    Quote Originally Posted by SilentStorm View Post
    [*]You are indeed hosting more than 512 Slots total. In this case you need to manually edit the Database to remove some slots.[/list]
    How do I edit manually edit the database?
    4,368
    That post is incorrect. Simply log on via query, use the server virtually and change the slots.
  1. [Resolved] Licensekey.dat prevents server start. "to many slots hosted"
    By Alpha Bootis in forum Linux / FreeBSD
    Last Post: February 15th, 2013, 12:16 PM
  2. Server won't start too many slots hosted, shutting down
    By Basd82 in forum Linux / FreeBSD
    Last Post: January 31st, 2013, 01:06 PM
  3. TS3 Server failed to start...
    By Minidkz in forum Windows
    Last Post: April 26th, 2010, 10:52 AM
  4. Failed to start on windows XP
    By MattyB in forum Windows
    Last Post: April 19th, 2010, 02:52 PM
