Results 1 to 4 of 4
    August 2012
    Maximum number of connections with the same identity exceeded
    I keep getting this error message when i am in TS3 Maximum number of connections with the same identity exceeded and after a couple of boots cannot re-connect automatically, can anyone help me resolve this issue?
    2,029
    That Message only appears when connecting and it is because you are already connected to the same server you are trying to connect to, without being allowed to connect multiple times.
    If your Connection is bad and you keep dropping, that might be an explanation as the Server will wait up to 20 Seconds before removing the Client if that Client doesn't answer anymore.
    You can increase the value of i_client_max_clones_uid to circumvent this issue from happening but you should probably fix your unstable connection instead of fixing the symptoms.
    August 2012
    Connection is good, ive tested it out and spoke with service provider and all is good and not losing any internet feed, it will connect once, then disconnects, then connects a second time then i lose it completely and the message appears, this only happens when there is a larger number of users in the channel
    my friend was geting same message and tryd evrything,, no luck,,,then he changed his router and solved t prob,,,so seems like your router is the problem
  1. [Resolved] Maximum number of connections with the same identity exceeded.
    By amzero in forum Server Support
    Last Post: July 27th, 2017, 12:40 PM
  2. Replies: 3
    Last Post: January 17th, 2014, 12:15 PM
  3. Replies: 22
    Last Post: December 3rd, 2012, 01:05 AM
  4. Replies: 1
    Last Post: March 26th, 2012, 02:12 PM
  5. Maximum number of connections with the same identity exceeded.
    By *{FTB}*FreeJazz in forum Bug Reports [EN/DE]
    Last Post: October 4th, 2011, 06:54 AM
