Results 16 to 30 of 40
  1. #16
    August 2012
    8
    The delay is the same or a very little bit less.
    Here is the log : http://pastebin.com/iUiaHDfQ
    Voices seems more clear with that dll.
  2. #17
    June 2002
    Netherlands
    1,049
    Nope not yet. I have not been able to reproduce it here. I suspect it is a driver issue. I will work on this soon, but i am busy with something very important for the next few weeks.
  3. #18
    August 2013
    6
    I just registered to report the exact same bug in the current x64 build (3.0.11.1). I can provide any information you want.
    My system is Windows 7 Professional x64, the rest of my specs are as follows:
    Intel Core i7 920
    6GB DDR3 1600
    Creative X-Fi Titanium
    Asus P6T Deluxe
    nVidia GTX285
    When the client runs for like 4 hours, my voice is delayed significantly. I can see a heavy delay in the activation of the icon when I start to speak, and other users are telling me that it's time to restart my client because they can hear themselves with a 2 second delay.
  4. #19
    August 2013
    65
    Go to Control Panel > Sound > Recording tab > Microphone properties > Advanced. Send us a screenshot while showing the options (list) of Default format/Sample rate.
  5. #20
    August 2013
    6
    I posted a screenshot right after your post, but it didn't get unlocked by a moderator yet.
    Here it is, second try:
    http://s14.directupload.net/images/130826/id4ifoc9.png
    ---merged---
    So... no solution?
  6. #21
    June 2002
    Netherlands
    1,049
    No, no solution yet. what happens when in that dialog you set the quality to 2 kanal, 16 bit, 48000hz? Does it still delay after 4 hours? and what about 12 and 24 hours?
  7. #22
    August 2013
    6
    I'll give it a try.
    ---merged---
    Just tried it. Uptime a little over 5 hours, delay is approximately 1 second now.
  8. #23
    June 2002
    Netherlands
    1,049
    Hmm I am guessing that means this setting does not improve (reduce) the delay.
  9. #24
    8
    Hi.
    Is there any progress with this issue?
    I have the same issue like the others above (delay after some hours).
    If I restart the client, everything is ok for some hours again.
    Regards.
    ---merged---
    Anybody?
    Any news?
    ---merged---
    The issue remains in 3.0.13.1 client and server 3.0.10.1
    Is there any progress? Can you reproduce the problem?
  10. #25
    June 2002
    Netherlands
    1,049
    Nope not able to reproduce. Reading back, I only noticed direct sound logs. I assume you also tried to use wasapi (windows audio session api). Did you?
  11. #26
    8
    Hi.
    Sorry for late response.
    How can I try to use wasapi?
    In teamspeak client settings, there are two options: "use automatically best mode" and "Direct sound". I have selected "Direct sound" for both playback and capture profiles.
    My OS is winXP SP3 32bit
    Teamspeak client is 3.0.13.1 connected to teamspeak server 3.0.10.1
  12. #27
    8
    While waiting for the progress of the process regarding this issue, a temporary "solution", is to find a way to restart teamspeak client every, lets say, 2 hours. You can use "autohotkey" software and make a script for this.
    I started using the above "trick" with autohotkey yesterday and it is working ok so far...
  13. #28
    August 2013
    6
    No update regarding this? It's really annoying having to restart the client every hour or so.
  14. #29
    17,935
    We have the problem, that nobody in our company had such a problem.
    It's hard to find that error.
    "I assume you also tried to use wasapi (windows audio session api). Did you?"
    Wasapi isn ot available on Windows XP. This question was a mistake.
  15. #30
    August 2013
    6
    Ok I just tested some days now using Windows Audio Session instead of Direct Sound. It seems that the problem is gone now.
    Just had a 15 hours session with no delay.
    So it seems it's really a problem with Direct Sound output.
    Happy Holidays by the way!
  1. [No Bug] Temporary Channel deletion delay only 24 hours
    By Soulflare3 in forum Bug Reports [EN/DE]
    Last Post: September 25th, 2015, 09:24 AM
