Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    August 2012
    incompatible with new SKY Firmware using a wired connection
    Since a few days ago i received a new sky router firmware update which has resulted in teamspeak becoming unusable as ts3 disconnects / times out as soon as people start talking over the mic. Looking at the teamspeak forum & the Sky forums this is starting to become a common trend. People have commented that it not only affects teamspeak but also some online games e.g. ARMA 2.
    I have spoken to SKY and they have informed me that as the connection has no faults its merely a compatibility issue with Teamspeak and i should come to you guys to obtain a patch / fix.
    If you require any further details please let me know.
    the details of my router and the firmware are below:
    Manufacturer Sagemcom
    Model Number [email protected]
    Firmware Version 6.14.1a4N_UNI
    18,308
    As you have mentoined, Teamspeak is not the only software, that does not work correctly.
    This problem is a combination of software and hardware and it seems that their new firmware provides more bugs as before.
    Is there a way to get that old firmware back?
    This thread was moved into the client section.
    August 2012
    I have gone through all the options with SKY's support team to revert back to an older version of firmware however due to the nature of the update, it automatically updates to the latest firmware as soon as you connect to the internet.
    August 2012
    any more news about this?
    August 2012
    have the channel set to Codec Quality: 3 (estimated bitrate: 2.15 KiB/s) and it seems to be fine tho still very annoyed with sky for there force update polisy
    August 2012
    Teamspeak 3 Disconnection after max 30 seconds.
    I constantly randomly disconnect and get told repeatedly that there are multiple instances of me in the channel.
    Running windows 7 64bit with wired LAN connection.
    Reset router, changed IP address, un-installed and re-installed, tried on several different devices, tried different TS3 servers, restarted computers and all to no avail.
    Will remain connected so long as nobody in the channel speaks or types. The moment another user shows any kind of activity, TS3 will disconnect.
    Didn't do it 4 days ago. No software or hardware changes went on. One day it worked fine, turned pc off went to bed, next day turned pc on and it didn't work.
    Any guesses?
    Thanks
    Log is as follows
    11/08/2012 21:11:17 Info TeamSpeak 3 Client 3.0.8.1 (2012-07-30 14:09:12)
    11/08/2012 21:11:17 Direct Sound Debug setting timer resolution to 1ms
    11/08/2012 21:11:18 Query Info listening on 127.0.0.1:25639
    11/08/2012 21:11:18 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    11/08/2012 21:11:18 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    11/08/2012 21:11:21 Input Info -------- Enum Devices --------
    11/08/2012 21:11:21 Input Info Device No:5 [KEYBOARD]
    11/08/2012 21:11:21 Input Info Handle: \\?\Root#RDP_KBD#0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}
    11/08/2012 21:11:21 Input Info Mode: 1
    11/08/2012 21:11:21 Input Info Function Keys: 12
    11/08/2012 21:11:21 Input Info Indicators: 3
    11/08/2012 21:11:21 Input Info Keys Total: 101
    11/08/2012 21:11:21 Input Info Type: 81
    11/08/2012 21:11:21 Input Info Subtype: 0
    11/08/2012 21:11:21 Input Info ------------------------------
    11/08/2012 21:11:21 Input Info Device No:6 [KEYBOARD]
    11/08/2012 21:11:21 Input Info Handle: \\?\HID#VID_045E&PID_0745&MI_00#7&15f26b1&0&0000#{ 884b96c3-56ef-11d1-bc8c-00a0c91405dd}
    11/08/2012 21:11:21 Input Info Keys Total: 154
    11/08/2012 21:11:21 Input Info Device No: 7 [MOUSE]
    11/08/2012 21:11:21 Input Info Handle: \\?\Root#RDP_MOU#0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
    11/08/2012 21:11:21 Input Info ID: 2
    11/08/2012 21:11:21 Input Info Buttons: 2
    11/08/2012 21:11:21 Input Info Device No: 8 [MOUSE]
    11/08/2012 21:11:21 Input Info Handle: \\?\HID#VID_045E&PID_0745&MI_01&Col01#7&148f42ef&0 &0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
    11/08/2012 21:11:21 Input Info ID: 256
    11/08/2012 21:11:21 Input Info Buttons: 5
    11/08/2012 21:11:21 Input Info ---------- Enum End ----------
    11/08/2012 21:11:21 Input Info Default monitoring enabled
    11/08/2012 21:11:21 ClientUI Info Qt version: 4.7.2
    11/08/2012 21:11:21 ClientUI Info Using configuration location: C:/Users/Michael/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    11/08/2012 21:11:21 ClientUI Info Last update check was:
    11/08/2012 21:11:21 Info Checking for updates...
    11/08/2012 21:11:21 Info DNS resolve successful, "update.teamspeak.com"=80.190.225.139
    11/08/2012 21:11:21 Info Update check, my version: 1343657352, latest version: 1343657352
    11/08/2012 21:11:41 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    11/08/2012 21:11:41 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    11/08/2012 21:11:41 Windows Audio Session Debug WAS::openDevice-enter
    11/08/2012 21:11:41 Windows Audio Session Debug WAS Buffer size: 896
    11/08/2012 21:11:41 Windows Audio Session Debug WAS::openDevice-leave
    11/08/2012 21:11:41 PreProSpeex Info Speex version: speex-1.2beta3
    11/08/2012 21:11:41 Windows Audio Session Debug WAS::startDevice-enter
    11/08/2012 21:11:41 Windows Audio Session Debug WAS::startDevice-leave
    11/08/2012 21:11:41 Windows Audio Session Debug WAS Buffer size: 3840
    11/08/2012 21:11:44 Windows Audio Session Debug WAS::stopDevice-enter
    11/08/2012 21:11:44 Windows Audio Session Debug WAS::stopDevice-leave
    11/08/2012 21:11:44 Windows Audio Session Debug WAS::closeDevice-enter
    11/08/2012 21:11:44 Windows Audio Session Devel DeviceDeleteList::queueDeviceDelete - enter
    11/08/2012 21:11:44 Windows Audio Session Devel DeviceDeleteList::queueDeviceDelete - leave
    11/08/2012 21:11:44 Windows Audio Session Devel DeviceDeleteList::clearQueue - enter
    11/08/2012 21:11:44 Windows Audio Session Debug WAS::closeDevice-leave
    11/08/2012 21:11:44 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    11/08/2012 21:11:44 Windows Audio Session Devel Waiting for device to close
    11/08/2012 21:11:44 Windows Audio Session Devel DeviceDeleteList::clearQueue - leave
    11/08/2012 21:11:44 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    11/08/2012 21:11:45 Windows Audio Session Debug WAS::stopDevice-enter
    11/08/2012 21:11:45 Windows Audio Session Debug WAS::stopDevice-leave
    11/08/2012 21:11:45 Windows Audio Session Debug WAS::closeDevice-enter
    11/08/2012 21:11:45 Windows Audio Session Devel DeviceDeleteList::queueDeviceDelete - enter
    11/08/2012 21:11:45 Windows Audio Session Devel DeviceDeleteList::clearQueue - enter
    11/08/2012 21:11:45 Windows Audio Session Devel DeviceDeleteList::queueDeviceDelete - leave
    11/08/2012 21:11:45 Windows Audio Session Debug WAS::closeDevice-leave
    11/08/2012 21:11:45 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    11/08/2012 21:11:45 Windows Audio Session Devel Waiting for device to close
    11/08/2012 21:11:45 Windows Audio Session Devel DeviceDeleteList::clearQueue - leave
    11/08/2012 21:11:45 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    11/08/2012 21:13:06 ClientUI Info Connect to server: 198.15.66.52
    11/08/2012 21:13:06 ClientUI Info Blacklist check ok
    11/08/2012 21:13:06 ClientUI Info Initiating connection: 198.15.66.52:4808 198.15.66.52
    11/08/2012 21:13:06 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    11/08/2012 21:13:06 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    11/08/2012 21:13:06 Windows Audio Session Debug WAS::openDevice-enter
    11/08/2012 21:13:06 Info DNS resolve successful, "blacklist.teamspeak.com"=80.190.225.139
    11/08/2012 21:13:06 Windows Audio Session Debug WAS Buffer size: 3840
    11/08/2012 21:13:06 Windows Audio Session Debug WAS::openDevice-leave
    11/08/2012 21:13:06 Windows Audio Session Debug WAS::startDevice-enter
    11/08/2012 21:13:06 Windows Audio Session Debug WAS::startDevice-leave
    11/08/2012 21:13:06 Windows Audio Session Debug WAS Buffer size: 896
    11/08/2012 21:13:06 ClientUI Info Connect status: Connecting
    11/08/2012 21:13:06 ClientUI Info Connect status: Disconnected
    11/08/2012 21:13:06 ClientUI Info Disconnected or forced to leave, want autoreconnect = 0
    11/08/2012 21:13:14 ClientUI Info Initiating connection: 198.15.66.52:4808 198.15.66.52
    11/08/2012 21:13:14 ClientUI Info Connect status: Connecting
    11/08/2012 21:13:15 ClientUI Info Connect status: Connected
    11/08/2012 21:13:15 ClientUI Info Connect status: Establishing connection
    11/08/2012 21:13:15 ClientUI Info Connect status: Connection established
    11/08/2012 21:13:15 Info Failed to download remote image: Error downloading http://www.escaped.net/images/12th-.jpg - server replied: Not Found 203
    11/08/2012 21:13:40 ClientUI Warning Error moving client into passworded channel
    11/08/2012 21:13:40 ClientUI Info Connect status: Disconnected
    11/08/2012 21:13:40 ClientUI Info Connection lost, want autoreconnect = 1
    11/08/2012 21:13:41 ClientUI Info Autoreconnecting
    11/08/2012 21:13:41 ClientUI Info Connect to server: 198.15.66.52
    11/08/2012 21:13:41 ClientUI Info Blacklist check ok
    11/08/2012 21:13:41 ClientUI Info Initiating connection: 198.15.66.52:4808 198.15.66.52
    11/08/2012 21:13:41 Info DNS resolve successful, "blacklist.teamspeak.com"=80.190.225.139
    11/08/2012 21:13:41 ClientUI Info Connect status: Connecting
    11/08/2012 21:13:42 ClientUI Info Connect status: Disconnected
    11/08/2012 21:13:42 ClientUI Info Disconnected or forced to leave, want autoreconnect = 0
    18,308
    http://forum.teamspeak.com/showthrea...of-information.
    Maybe it is just a server problem in your case, please try other servers to.
    August 2012
    I have tried 3 servers. 2 private and 1 teamspeak public already. This didn't work either. ISP state they cant help me either :/
    18,308
    There more hints in my thread, what you could test out.
    August 2012
    Have tried everything in your thread before i posted. I still can't find the problem. will try new router.
    18,308
    Even with DMZ enabled? I guess this is no router problem then.
    Maybe a new network cable or disbaled firewall etc will help here too?
    August 2012
    I am getting the same problem with the exact same blacklist ip address.
    whosip traces this to Germany. I am in the UK.
    wtf? is that where it checks the blacklist?
    I have the same problems as the OP. One day it worked, the next day it didn't.
    15/08/2012 21:21:11 ClientUI Info Connect to server: 85.236.100.27
    15/08/2012 21:21:11 ClientUI Info Blacklist check ok
    15/08/2012 21:21:11 ClientUI Info Initiating connection: 85.236.100.27:10127 85.236.100.27
    15/08/2012 21:21:11 ClientUI Info Connect status: Connecting
    15/08/2012 21:21:11 Info DNS resolve successful, "blacklist.teamspeak.com"=80.190.225.139
    15/08/2012 21:21:11 ClientUI Info Connect status: Connected
    15/08/2012 21:21:11 ClientUI Info Connect status: Establishing connection
    15/08/2012 21:21:11 ClientUI Info Connect status: Connection established
    15/08/2012 21:21:36 ClientUI Info Connect status: Disconnected
    15/08/2012 21:21:36 ClientUI Info Connection lost, want autoreconnect = 1
    15/08/2012 21:21:36 Bookmarks Info Disconnect, total time: 25 - 75
    15/08/2012 21:21:37 ClientUI Info Autoreconnecting
    15/08/2012 21:21:37 ClientUI Info Connect to server: 85.236.100.27
    15/08/2012 21:21:37 ClientUI Info Blacklist check ok
    15/08/2012 21:21:37 ClientUI Info Initiating connection: 85.236.100.27:10127 85.236.100.27
    15/08/2012 21:21:37 Info DNS resolve successful, "blacklist.teamspeak.com"=80.190.225.139
    15/08/2012 21:21:37 ClientUI Info Connect status: Connecting
    15/08/2012 21:21:37 ClientUI Info Connect status: Disconnected
    15/08/2012 21:21:37 ClientUI Info Disconnected or forced to leave, want autoreconnect = 0
    15/08/2012 21:23:19 Info Memory usage: 48.22 MiB
    August 2012
    7
    Lose of connection every few mins
    I have recently started running into some problems on my TS3 Client. For the past 2 weeks every time I try to connect to my clans server I get in and then after a few mins I get disconnected. I have looked through the logs but can't see what is causing the problem.
    2012-08-15 21:33:34.393316|INFO | | | TeamSpeak 3 Client 3.0.8.1 (2012-07-30 14:09:12)
    2012-08-15 21:33:34.415317|DEBUG |Direct Sound | | setting timer resolution to 1ms
    2012-08-15 21:33:34.456319|INFO |Query | | listening on 127.0.0.1:25639
    2012-08-15 21:33:34.509322|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - enter
    2012-08-15 21:33:34.509322|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - leave
    2012-08-15 21:33:34.554325|INFO |Input | | -------- Enum Devices --------
    2012-08-15 21:33:34.562325|INFO |Input | | Device No:3 [KEYBOARD]
    2012-08-15 21:33:34.562325|INFO |Input | | Handle: \\?\Root#RDP_KBD#0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd}
    2012-08-15 21:33:34.562325|INFO |Input | | Mode: 1
    2012-08-15 21:33:34.563325|INFO |Input | | Function Keys: 12
    2012-08-15 21:33:34.563325|INFO |Input | | Indicators: 3
    2012-08-15 21:33:34.563325|INFO |Input | | Keys Total: 101
    2012-08-15 21:33:34.563325|INFO |Input | | Type: 81
    2012-08-15 21:33:34.563325|INFO |Input | | Subtype: 0
    2012-08-15 21:33:34.563325|INFO |Input | | ------------------------------
    2012-08-15 21:33:34.563325|INFO |Input | | Device No:4 [KEYBOARD]
    2012-08-15 21:33:34.563325|INFO |Input | | Handle: \\?\HID#VID_1532&PID_0015&MI_01#7&247e2ad7&0&0000# {884b96c3-56ef-11d1-bc8c-00a0c91405dd}
    2012-08-15 21:33:34.563325|INFO |Input | | Mode: 1
    2012-08-15 21:33:34.563325|INFO |Input | | Keys Total: 264
    2012-08-15 21:33:34.563325|INFO |Input | | Device No:5 [KEYBOARD]
    2012-08-15 21:33:34.563325|INFO |Input | | Handle: \\?\HID#VID_1038&PID_0510&MI_00#8&16c12799&0&0000# {884b96c3-56ef-11d1-bc8c-00a0c91405dd}
    2012-08-15 21:33:34.563325|INFO |Input | | Device No: 6 [MOUSE]
    2012-08-15 21:33:34.563325|INFO |Input | | Handle: \\?\Root#RDP_MOU#0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
    2012-08-15 21:33:34.563325|INFO |Input | | ID: 2
    2012-08-15 21:33:34.563325|INFO |Input | | Buttons: 2
    2012-08-15 21:33:34.564325|INFO |Input | | ------------------------------
    2012-08-15 21:33:34.564325|INFO |Input | | Device No: 7 [MOUSE]
    2012-08-15 21:33:34.564325|INFO |Input | | Handle: \\?\HID#VID_1532&PID_0015&MI_00#7&cba9e92&0&0000#{ 378de44c-56ef-11d1-bc8c-00a0c91405dd}
    2012-08-15 21:33:34.564325|INFO |Input | | ID: 256
    2012-08-15 21:33:34.564325|INFO |Input | | Buttons: 7
    2012-08-15 21:33:34.564325|INFO |Input | | ---------- Enum End ----------
    2012-08-15 21:33:34.564325|INFO |Input | | Default monitoring enabled
    2012-08-15 21:33:34.592327|INFO |ClientUI | | Qt version: 4.7.2
    2012-08-15 21:33:34.592327|INFO |ClientUI | | Using configuration location: C:/Users/Sauasge/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    2012-08-15 21:33:34.881344|INFO |ClientUI | | ts3server: 46.249.40.72/?port=10002
    2012-08-15 21:33:34.881344|INFO |ClientUI | 1| Connect to server: 46.249.40.72
    2012-08-15 21:33:34.883344|INFO |ClientUI | 1| Blacklist check ok
    2012-08-15 21:33:34.883344|INFO |ClientUI | 1| Initiating connection: 46.249.40.72:10002 46.249.40.72
    2012-08-15 21:33:34.884344|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - enter
    2012-08-15 21:33:34.884344|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - leave
    2012-08-15 21:33:34.884344|DEBUG |Windows Audio Session| | WAS:penDevice-enter
    2012-08-15 21:33:34.912345|INFO | | | DNS resolve successful, "blacklist.teamspeak.com"=80.190.225.139
    2012-08-15 21:33:34.920346|DEBUG |Windows Audio Session| | WAS Buffer size: 960
    2012-08-15 21:33:34.920346|DEBUG |Windows Audio Session| | WAS:penDevice-leave
    2012-08-15 21:33:34.920346|DEBUG |Windows Audio Session| | WAS::startDevice-enter
    2012-08-15 21:33:34.920346|DEBUG |Windows Audio Session| | WAS::startDevice-leave
    2012-08-15 21:33:34.921346|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - enter
    2012-08-15 21:33:34.921346|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - leave
    2012-08-15 21:33:34.921346|DEBUG |Windows Audio Session| | WAS:penDevice-enter
    2012-08-15 21:33:34.933347|DEBUG |Windows Audio Session| | WAS Buffer size: 896
    2012-08-15 21:33:34.933347|DEBUG |Windows Audio Session| | WAS:penDevice-leave
    2012-08-15 21:33:34.933347|INFO |PreProSpeex | 1| Speex version: speex-1.2beta3
    2012-08-15 21:33:34.934347|DEBUG |Windows Audio Session| | WAS::startDevice-enter
    2012-08-15 21:33:34.934347|DEBUG |Windows Audio Session| | WAS::startDevice-leave
    2012-08-15 21:33:34.938347|INFO |ClientUI | 1| Connect status: Connecting
    2012-08-15 21:33:35.083355|INFO |ClientUI | | Last update check was: Wed 15. Aug 21:33:02 2012
    2012-08-15 21:33:35.099356|INFO |ClientUI | 1| Connect status: Disconnected
    2012-08-15 21:33:35.099356|INFO |ClientUI | 1| Disconnected or forced to leave, want autoreconnect = 0
    2012-08-15 21:33:37.848513|INFO |ClientUI | 1| Initiating connection: 46.249.40.72:10002 46.249.40.72
    2012-08-15 21:33:37.852514|INFO |ClientUI | 1| Connect status: Connecting
    2012-08-15 21:33:37.950519|INFO |ClientUI | 1| Connect status: Connected
    2012-08-15 21:33:37.980521|INFO |ClientUI | 1| Connect status: Establishing connection
    2012-08-15 21:33:38.048525|INFO |ClientUI | 1| Connect status: Connection established
    2012-08-15 21:34:02.895946|INFO |ClientUI | 1| Connect status: Disconnected
    2012-08-15 21:34:02.896946|INFO |ClientUI | 1| Connection lost, want autoreconnect = 1
    2012-08-15 21:34:03.914004|INFO |ClientUI | 1| Autoreconnecting
    2012-08-15 21:34:03.914004|INFO |ClientUI | 1| Connect to server: 46.249.40.72
    2012-08-15 21:34:03.915004|INFO |ClientUI | 1| Blacklist check ok
    2012-08-15 21:34:03.916004|INFO |ClientUI | 1| Initiating connection: 46.249.40.72:10002 46.249.40.72
    2012-08-15 21:34:03.916004|INFO | | | DNS resolve successful, "blacklist.teamspeak.com"=80.190.225.139
    2012-08-15 21:34:03.920005|INFO |ClientUI | 1| Connect status: Connecting
    2012-08-15 21:34:03.988008|INFO |ClientUI | 1| Connect status: Disconnected
    2012-08-15 21:34:03.988008|INFO |ClientUI | 1| Disconnected or forced to leave, want autoreconnect = 0
    2012-08-15 21:34:14.028583|DEBUG |Windows Audio Session| | WAS::associateAECDevice-enter
    2012-08-15 21:34:14.029583|DEBUG |Windows Audio Session| | WAS::associateAECDevice-leave
    2012-08-15 21:34:14.029583|DEBUG |Windows Audio Session| | WAS::stopDevice-enter
    2012-08-15 21:34:14.029583|DEBUG |Windows Audio Session| | WAS::stopDevice-leave
    2012-08-15 21:34:14.029583|DEBUG |Windows Audio Session| | WAS::closeDevice-enter
    2012-08-15 21:34:14.029583|DEVELOP |Windows Audio Session| | DeviceDeleteList::queueDeviceDelete - enter
    2012-08-15 21:34:14.029583|DEVELOP |Windows Audio Session| | DeviceDeleteList::queueDeviceDelete - leave
    2012-08-15 21:34:14.029583|DEBUG |Windows Audio Session| | WAS::closeDevice-leave
    2012-08-15 21:34:14.029583|DEVELOP |Windows Audio Session| | DeviceDeleteList::clearQueue - enter
    2012-08-15 21:34:14.029583|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - enter
    2012-08-15 21:34:14.029583|DEVELOP |Windows Audio Session| | Waiting for device to close
    2012-08-15 21:34:14.035583|DEVELOP |Windows Audio Session| | DeviceDeleteList::clearQueue - leave
    2012-08-15 21:34:14.035583|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - leave
    2012-08-15 21:34:14.046584|DEBUG |Windows Audio Session| | WAS::stopDevice-enter
    2012-08-15 21:34:14.046584|DEBUG |Windows Audio Session| | WAS::stopDevice-leave
    2012-08-15 21:34:14.046584|DEBUG |Windows Audio Session| | WAS::closeDevice-enter
    2012-08-15 21:34:14.046584|DEVELOP |Windows Audio Session| | DeviceDeleteList::queueDeviceDelete - enter
    2012-08-15 21:34:14.046584|DEVELOP |Windows Audio Session| | DeviceDeleteList::queueDeviceDelete - leave
    2012-08-15 21:34:14.046584|DEVELOP |Windows Audio Session| | DeviceDeleteList::clearQueue - enter
    2012-08-15 21:34:14.046584|DEBUG |Windows Audio Session| | WAS::closeDevice-leave
    2012-08-15 21:34:14.046584|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - enter
    2012-08-15 21:34:14.046584|DEVELOP |Windows Audio Session| | Waiting for device to close
    2012-08-15 21:34:14.048584|DEVELOP |Windows Audio Session| | DeviceDeleteList::clearQueue - leave
    2012-08-15 21:34:14.048584|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - leave
    2012-08-15 21:34:14.296598|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - enter
    2012-08-15 21:34:14.296598|DEVELOP |Windows Audio Session| | DeviceDeleteList::waitForDeletes - leave
    2,029
    Check your Router Settings for Flood Protection / dDoS Protection Settings etc. and try disabling them.
    August 2012
    7
    My Router doesn't show any of those settings. Could it be UPnP? I remember back a few years ago this was causing problems with a lot of people PS3 connections?
  1. Replies: 2
    Last Post: April 17th, 2015, 10:04 AM
  2. Replies: 0
    Last Post: October 23rd, 2014, 10:01 PM
  3. Replies: 0
    Last Post: September 21st, 2013, 04:35 AM
  4. Replies: 0
    Last Post: June 1st, 2012, 08:28 AM
