Results 1 to 6 of 6
    August 2012
    Solved PTT - running as admin, still having issues
    Been searching threads, can't quite find this problem or a solution that works.
    I have teamspeak3. Windows 7. It is set to run as admin for all users. When in settings, I can test my PTT and it lights up the scale, but once I save settings/apply and am in TS or any other program, my PTT doesn't seem to register.
    I have tried changing keybinds, mouse/keyboard both, with no luck. If I set it to Voice Activation, it works fine. I would MUCH rather have it on PTT though, so I can talk to people in the room and not have it transmit.
    Any ideas what I'm doing wrong?
    18,151
    Could it be, that you have a second or no hotkey profile activated?
    Please check your bookmark settings under Bookmarks > Manage Bookmarks > now select your bookmark and press on more.
    Now compare the hotkey profile with the profile , where they key was set in.
    August 2012
    Checked bookmarks' profile settings and they were all set to "none". Switched that to "default", since that's where the keybind was set, and... VOILA! I have PTT! You sir, are my hero-for-today. Many thanks.
    18,151
    What hardware is plugged in and what driver do you use?
    We wonder, why it was set to "none" in your bookmarks.
    August 2012
    I have checked my bookmarks and they are all on default. Still no PTT. I am running Windows 7 and latest TS
    18,151
    What client version do you use and what hotkey mode do you use?
    Does it work, when you change the hotkey mode under Settings > Options > Hotkeys.
    You can choose Default, Direct Input and Keyboard & mouse only.
    What about this? Maybe this helps here.
  1. Replies: 4
    Last Post: January 22nd, 2010, 03:16 AM
