Results 1 to 2 of 2
    7
    Solved Problem with ts3client_openCaptureDevice, returns ERROR_undefined
    Out of boredom, I tried to create a plugin for the game garrysmod, in order to allow a direct intigration of teamspeak.
    Everything went pretty smooth to the point where I tried to connect to the server, apparently ts3client_openCaptureDevice returns ERROR_undefined, I didn't find any note about this in the sdk documentation.
    Can anyone tell what the conditions are for this to happen?
    Below the code, ignore everything Lua related as it's not important in this matter.
    #include "ILuaModuleManager.h"
    #include <cstring>
    #include <cstdio>
    #include "clientlib.h"
    #include "public_errors.h"
    GMOD_MODULE( Open, Close );
    ILuaInterface *gLua = NULL;
    struct ClientUIFunctions handlerFuncs;
    uint64 connectionHandler = NULL;
    bool isInitialized = false;
    bool isConnected = false;
    FILE* debugFile;
    using namespace GarrysMod::Lua;
    #define TS3LOG(msg) fprintf(debugFile, msg); fflush(debugFile)
     * Callback for connection status change.
     * Connection status switches through the states STATUS_DISCONNECTED, STATUS_CONNECTING, STATUS_CONNECTED and STATUS_CONNECTION_ESTABLISHED.
     * Parameters:
     *   serverConnectionHandlerID - Server connection handler ID
     *   newStatus                 - New connection status, see the enum ConnectStatus in clientlib_publicdefinitions.h
     *   errorNumber               - Error code. Should be zero when connecting or actively disconnection.
     *                               Contains error state when losing connection.
    void onConnectStatusChangeEvent(uint64 serverConnectionHandlerID, int newStatus, unsigned int errorNumber) {
    	printf("Connect status changed: %llu %d %u\n", (unsigned long long)serverConnectionHandlerID, newStatus, errorNumber);
    	/* Failed to connect ? */
    	if(newStatus == STATUS_DISCONNECTED && errorNumber == ERROR_failed_connection_initialisation) {
    		printf("Looks like there is no server running, terminate!\n");
     * Callback for current channels being announced to the client after connecting to a server.
     * Parameters:
     *   channelID                 - ID of the announced channel
     *   channelParentID           - ID of the parent channel
    void onNewChannelEvent(uint64 serverConnectionHandlerID, uint64 channelID, uint64 channelParentID) {
        /* Query channel name from channel ID */
        char* name;
        unsigned int error;
        printf("onNewChannelEvent: %llu %llu %llu\n", (unsigned long long)serverConnectionHandlerID, (unsigned long long)channelID, (unsigned long long)channelParentID);
        if((error = ts3client_getChannelVariableAsString(serverConnectionHandlerID, channelID, CHANNEL_NAME, &name)) == ERROR_ok) {
            printf("New channel: %llu %s \n", (unsigned long long)channelID, name);
            ts3client_freeMemory(name);  /* Release dynamically allocated memory only if function succeeded */
        } else {
            char* errormsg;
            if(ts3client_getErrorMessage(error, &errormsg) == ERROR_ok) {
                printf("Error getting channel name in onNewChannelEvent: %s\n", errormsg);
                ts3client_freeMemory(errormsg);
     * Callback for just created channels.
     * Parameters:
     *   invokerID                 - ID of the client who created the channel
     *   invokerName               - Name of the client who created the channel
    void onNewChannelCreatedEvent(uint64 serverConnectionHandlerID, uint64 channelID, uint64 channelParentID, anyID invokerID, const char* invokerName, const char* invokerUniqueIdentifier) {
        char* name;
        if(ts3client_getChannelVariableAsString(serverConnectionHandlerID, channelID, CHANNEL_NAME, &name) != ERROR_ok)
            return;
        printf("New channel created: %s\n", name);
     * Callback when a channel was deleted.
     * Parameters:
     *   channelID                 - ID of the deleted channel
     *   invokerID                 - ID of the client who deleted the channel
     *   invokerName               - Name of the client who deleted the channel
    void onDelChannelEvent(uint64 serverConnectionHandlerID, uint64 channelID, anyID invokerID, const char* invokerName, const char* invokerUniqueIdentifier) {
    	printf("Channel ID %llu deleted by %s (%u)\n", (unsigned long long)channelID, invokerName, invokerID);
     * Called when a client joins, leaves or moves to another channel.
     * Parameters:
     *   clientID                  - ID of the moved client
     *   oldChannelID              - ID of the old channel left by the client
     *   newChannelID              - ID of the new channel joined by the client
     *   visibility                - Visibility of the moved client. See the enum Visibility in clientlib_publicdefinitions.h
     *                               Values: ENTER_VISIBILITY, RETAIN_VISIBILITY, LEAVE_VISIBILITY
    void onClientMoveEvent(uint64 serverConnectionHandlerID, anyID clientID, uint64 oldChannelID, uint64 newChannelID, int visibility, const char* moveMessage) {
    	printf("ClientID %u moves from channel %llu to %llu with message %s\n", clientID, (unsigned long long)oldChannelID, (unsigned long long)newChannelID, moveMessage);
     * Callback for other clients in current and subscribed channels being announced to the client.
     * Parameters:
     *   clientID                  - ID of the announced client
     *   oldChannelID              - ID of the subscribed channel where the client left visibility
     *   newChannelID              - ID of the subscribed channel where the client entered visibility
     *   visibility                - Visibility of the announced client. See the enum Visibility in clientlib_publicdefinitions.h
    void onClientMoveSubscriptionEvent(uint64 serverConnectionHandlerID, anyID clientID, uint64 oldChannelID, uint64 newChannelID, int visibility) {
        char* name;
        /* Query client nickname from ID */
        if(ts3client_getClientVariableAsString(serverConnectionHandlerID, clientID, CLIENT_NICKNAME, &name) != ERROR_ok)
            return;
        printf("New client: %s\n", name);
     * Called when a client drops his connection.
     * Parameters:
     *   oldChannelID              - ID of the channel the leaving client was previously member of
     *   newChannelID              - 0, as client is leaving
     *   visibility                - Always LEAVE_VISIBILITY
     *   timeoutMessage            - Optional message giving the reason for the timeout
    void onClientMoveTimeoutEvent(uint64 serverConnectionHandlerID, anyID clientID, uint64 oldChannelID, uint64 newChannelID, int visibility, const char* timeoutMessage) {
    	printf("ClientID %u timeouts with message %s\n",clientID, timeoutMessage);
     * This event is called when a client starts or stops talking.
     * Parameters:
     *   status                    - 1 if client starts talking, 0 if client stops talking
     *   isReceivedWhisper         - 1 if this event was caused by whispering, 0 if caused by normal talking
     *   clientID                  - ID of the client who announced the talk status change
    void onTalkStatusChangeEvent(uint64 serverConnectionHandlerID, int status, int isReceivedWhisper, anyID clientID) {
        char* name;
            return;
        if(status == STATUS_TALKING) {
            printf("Client \"%s\" starts talking.\n", name);
        } else {
            printf("Client \"%s\" stops talking.\n", name);
    void onServerErrorEvent(uint64 serverConnectionHandlerID, const char* errorMessage, unsigned int error, const char* returnCode, const char* extraMessage) {
    	printf("Error for server %llu: %s %s\n", (unsigned long long)serverConnectionHandlerID, errorMessage, extraMessage);
    #define tryTS3Call(func, ...)\
    	if(errCode = func(##__VA_ARGS__) != ERROR_ok) {\
    		char* errorMsg;\
    		if(ts3client_getErrorMessage(errCode, &errorMsg) == ERROR_ok) {\
    			gLua->Push(false);\
    			gLua->Push((double)errCode);\
    			gLua->Push(errorMsg);\
    			ts3client_freeMemory(errorMsg);\
    			return 3;\
    		gLua->Push(false);\
    		gLua->Push(-1.0f);\
    		gLua->Push("Unknown error");\
    		return 3;\
    LUA_FUNCTION( lTS3GetVersion ) {
    	char* verTemp;
    	unsigned int errCode;
    	tryTS3Call(ts3client_getClientLibVersion, &verTemp);
    	gLua->Push(verTemp);
    	ts3client_freeMemory(verTemp);
    	return 1;
    LUA_FUNCTION( lTS3Disconnect ) {
    	if(!connectionHandler) {
    		gLua->Push(false);
    		gLua->Push(-1.0f);
    		gLua->Push("Not connected");
    		return 3;
    	const char* leaveMsg = "disconnected";
    	if(gLua->Top() > 0) {
    		gLua->CheckType(1, Type::STRING);
    		leaveMsg = gLua->GetString();
    	tryTS3Call(ts3client_stopConnection, connectionHandler, leaveMsg)
    	tryTS3Call(ts3client_destroyServerConnectionHandler, connectionHandler)
    	gLua->Push(true);
    	return 1;
    LUA_FUNCTION( lTS3Connect ) {
    	if(connectionHandler && isConnected) {
    		gLua->Push(false);
    		gLua->Push(-1.0f);
    		gLua->Push("Already connected");
    		return 3;
    	gLua->CheckType(1, Type::STRING);//host
    	gLua->CheckType(2, Type::NUMBER);//port
    	gLua->CheckType(3, Type::STRING);//username
    	int top = gLua->Top();
    	bool usePass, useChannelPass, useDefaultChannel = false;
    	char* channelPath[9];
    	memset(channelPath, NULL, 9);
    	switch(top) {
    		case 6:
    			gLua->CheckType(6, Type::STRING);//password
    			usePass = true;
    		case 5:
    			if(gLua->GetType(5) == Type::STRING) {
    				useChannelPass = true;
    		case 4:
    			if(gLua->GetType(4) == Type::TABLE) {
    				ILuaObject* lTbl = gLua->GetObject(4);
    				char idx[2] = {'\0', '\0'};
    				ILuaObject* tblMember;
    				char errMsg[128];
    				for(int i = '1'; '9' > i;i++) {
    					idx[0] = (char)i;
    					if(tblMember = lTbl->GetMember(idx)) {
    						if(!tblMember->isString()) {
    							sprintf(errMsg, "Invalid value for channel path table, expected string got %s at key %c", lTbl->GetTypeName(), i);
    							gLua->Error(errMsg);
    							return 0;
    						const char* str = tblMember->GetString();
    						if(!strcmp(str, "")) {
    							sprintf(errMsg, "Invalid value for channel path table, got empty string at key %c", i);
    							return 0;
    						channelPath[i-49] = (char*)malloc(strlen(str)+1);
    						strcpy(channelPath[i-49], str);
    					else
    						break;
    			useDefaultChannel = true;
    	char* identity;
    	TS3LOG("creating connection handler\n");
    		tryTS3Call(ts3client_spawnNewServerConnectionHandler, 0, &connectionHandler);
    	/*char* mode;
    		TS3LOG("getting default capture mode\n");
    	tryTS3Call(ts3client_getDefaultCaptureMode, &mode);
    	char** captureDevice;
    		TS3LOG("getting default capture device\n");
    	tryTS3Call(ts3client_getDefaultCaptureDevice, mode, &captureDevice);*/
    		TS3LOG("opening capture device\n");
    	tryTS3Call(ts3client_openCaptureDevice, connectionHandler, "", NULL)
    		TS3LOG("opening playback device\n");
    	tryTS3Call(ts3client_openPlaybackDevice, connectionHandler, "", NULL)
    		TS3LOG("creating identity device\n");
    	tryTS3Call(ts3client_createIdentity, &identity)
    		TS3LOG("connecting\n");
    	tryTS3Call(
    		ts3client_startConnection,
    		connectionHandler,
    		identity,
    		gLua->GetString(1),
    		(unsigned int)gLua->GetNumber(2),
    		gLua->GetString(3),
    		useDefaultChannel ? const_cast<const char **>(channelPath) : NULL,
    		useChannelPass ? gLua->GetString(5) : "",
    		usePass ? gLua->GetString(6) : ""
    	isConnected = true;
    	gLua->Push(true);
    	return 1;
    LUA_FUNCTION( lTS3Init ) {
    	if(isInitialized) {
    		gLua->Push(false);
    		gLua->Push(-1.0f);
    		gLua->Push("Already initialized");
    		return 3;
    	tryTS3Call(ts3client_initClientLib, &handlerFuncs, NULL, LogType_FILE | LogType_CONSOLE | LogType_USERLOGGING, NULL, "ts3logs/")
    	gLua->Push(true);
    	isInitialized = true;
    	return 1;
    int Open( lua_State *L )
    	gLua = Lua();
    	debugFile = fopen("ts3debug.txt", "w");
    	/* Initialize all callbacks with NULL */
    	memset(&handlerFuncs, 0, sizeof(struct ClientUIFunctions));
    	/* Callback function pointers */
    	/* It is sufficient to only assign those callback functions you are using. When adding more callbacks, add those function pointers here. */
    	handlerFuncs.onConnectStatusChangeEvent    = onConnectStatusChangeEvent;
    	handlerFuncs.onNewChannelEvent             = onNewChannelEvent;
    	handlerFuncs.onNewChannelCreatedEvent      = onNewChannelCreatedEvent;
    	handlerFuncs.onDelChannelEvent             = onDelChannelEvent;
    	handlerFuncs.onClientMoveEvent             = onClientMoveEvent;
    	handlerFuncs.onClientMoveSubscriptionEvent = onClientMoveSubscriptionEvent;
    	handlerFuncs.onClientMoveTimeoutEvent      = onClientMoveTimeoutEvent;
    	handlerFuncs.onTalkStatusChangeEvent       = onTalkStatusChangeEvent;
    	handlerFuncs.onServerErrorEvent            = onServerErrorEvent;
    	ILuaObject* ts3 = gLua->GetNewTable();
    	ts3->SetMember("init", lTS3Init);
    	ts3->SetMember("connect", lTS3Connect);
    	ts3->SetMember("disconnect", lTS3Disconnect);
    	ts3->SetMember("getVersion", lTS3GetVersion);
    	gLua->SetGlobal("teamspeak", ts3);
    	ts3->UnReference();
    	return 0;
    int Close( lua_State *L )
    	fclose(debugFile);
    	ts3client_stopConnection(connectionHandler, "disconnected");
    	ts3client_destroyServerConnectionHandler(connectionHandler);
    	ts3client_destroyClientLib();
    	return 0;
    7
    Nevermind, I had 2 parameters swapped.
  1. [On Todo] Query API: servergroupbyclientid returns help for servergroupsbyclientid
    By nikeee in forum Bug Reports [EN/DE]
    Last Post: December 9th, 2014, 01:30 PM
  2. Replies: 9
    Last Post: September 28th, 2014, 04:30 PM
  3. PluginSDK getClientID returns ERROR_ok when not connected.
    By SilentStorm in forum Bug Reports [EN/DE]
    Last Post: January 26th, 2012, 11:23 AM
  4. [No Bug] [PluginSDK] requestDeleteFile always returns 0x806
    Last Post: April 6th, 2011, 08:13 AM
