Results 1 to 6 of 6
    August 2012
    6
    Problem with server group
    My english is bad, but:
    I have three groups: "Admin", "Moderator", "Channel Admin".
    "Admin" - 75, "Moderator" - 65, "Channel Admin" - 55
    "Moderator":
    i_client_permission_modify_power = 65
    i_group_needed_member_add_power = 65
    i_group_member_add_power=55
    He can give only "Channel Admin". "Admin" - "Moderator" or "Channel Admin"
    If i create server group = 55 ( "Test" - i_client_permission_modify_power = 55), moderator cannot give this group, "Test"
    This is the error: insufficient client permissions (failed on i_group_member_add_power)
    The Group issued only when values 75 (i_group_needed_member_add_power = 75,
    i_group_member_add_power=75)
    I hope for your help.
    2,029
    Assigning Groups (regardless of whether Channel or Server) is controlled by the Permissions i_group_member_add_power and i_group_needed_member_add_power
    The value of the former needs to be equal or greater than the latter.
    So Moderator in your Example will be able to assign Channel Admin but not admin (by default needs 75 add_power) or Moderator (needs 65 add_power, but only has 55). Everything is working as expected.
    August 2012
    6
    It's so, but: If i create server group = 55 ( "Test" - i_client_permission_modify_power = 55), moderator cannot give this server group, "Test". He can give only Channel Admin (Although its value equal to the value of the Group Test). Why can't I give group Test?
    2,029
    By Default newly created Groups have an i_group_needed_member_add_power value of equal to your i_group_member_add_power which since you are Admin is 75. That explains why you cannot give out that Group as Moderator. You will need to change the needed_member_add_power to 55 or lower on new Groups if you want your Moderators to assign it.
    The Permission i_client_permission_modify_power has nothing to do with assigning that group.
    August 2012
    6
    Did as you wrote, and now a new error:
    insufficient client permissions (error i_client_needed_permission_modify_power)
    Moderator have: i_client_needed_permission_modify_power = 65
    What's wrong?
    August 2012
    6
    Thank you so much, you've opened my eyes to the world Topic can be closed.
  1. Server Group Add & Remove Problem
    By Serializator in forum Permission System
    Last Post: September 14th, 2015, 02:30 PM
  2. [Resolved] I have a problem with group Server Admin
    By csovidiu1234 in forum Permission System
    Last Post: January 18th, 2014, 04:30 PM
  3. Server group problem[Screenshots]
    By IamNyan in forum Server Support
    Last Post: January 3rd, 2014, 05:58 PM
  4. Problem with Server Group icons.
    By RandomBob in forum Server Support
    Last Post: October 28th, 2013, 02:28 AM
  5. New server group but problem
    By simoleo89 in forum Permission System
    Last Post: January 11th, 2010, 09:28 AM
