Results 1 to 4 of 4
    August 2012
    Teamspeak 3 wont connect
    i was on another net and it worked fine. i switched to a different one and now it wont connect to any teamspeak i try to connect. i tried to disable my antivirus firewall (AVG antivirus), and the regular firewall. i also tried uninstalling and installing it again. and still does not work
    2,029
    Try to connect to the IP Address directly instead of a DomainName.
    Also try these Servers: Test Server Name, Test Server IP
    If the second Link works but the first does not then you are having DNS Issues and need to check and fix those first.
    August 2012
    i tried to connect to both and it didnt work. how can i check if i got problems with dns?
    July 2006
    1,600
    If you cannot connect both servers then you have some other basic issue. Maybe udp connections are blocked from your machine or some firewall does not like teamspeak or maybe even your antivirus software causes the connection to fail.
  1. Teamspeak 3 wont connect
    By stilian1000 in forum Windows
    Last Post: August 5th, 2013, 09:14 PM
  2. teamspeak wont connect
    By madwolf in forum General Questions
    Last Post: April 1st, 2011, 10:48 AM
  3. my teamspeak 3 wont connect to ANY servers?
    By butterbaugh64 in forum Server Support
    Last Post: August 22nd, 2010, 10:03 PM
  4. teamspeak just wont connect!!
    By rAggy10 in forum General Questions
    Last Post: January 2nd, 2010, 05:09 PM
