Results 1 to 6 of 6
    9
    Problems with installing ts3 on debian.
    Hey,
    so im trying to install ts3 on debian but im having problems.
    [email protected]:/home/ts3user/teamspeak3-server_linux-x86# ./ts3server_minimal_runscript.sh
    Do you have the right TS3 Server package for your system? You have: Linux x86_64, not Linux i386.
    ./ts3server_linux_x86: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
    This is what i get when trying to do ./ts3server_minimal_runscript.sh
    what to do ? thanks!
    UK
    769
    Quote Originally Posted by chetii View Post
    If what you've posted is what came up on the screen, then the answer (or one of them at least) is staring you in the face, you're trying to run 32 bit Teamspeak on a 64 bit Linux system, download the 64 bit Teamspeak server & try again
    9
    Okay i got it up and running but when i try to connect to my localhost (im connecting through my pc, not the debian homeserver) then i cant get in.
    [email protected]:/home/ts2user/teamspeak3-server_linux-x86# ./ts3server_minimal_r unscript.sh
    Do you have the right TS3 Server package for your system? You have: Linux x86_64 , not Linux i386.
    2012-09-11 12:14:21.196312|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6 .1 (2012-06-29 07:59:05)
    2012-09-11 12:14:21.196760|INFO |DatabaseQuery | | dbPlugin name: SQLite 3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2012-09-11 12:14:21.196819|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2012-09-11 12:14:21.197116|INFO |DatabaseQuery | | checking database integr ity (may take a while)
    2012-09-11 12:14:21.248812|WARNING |Accounting | | Unable to find valid lic ense key, falling back to limited functionality
    2012-09-11 12:14:21.281760|INFO |FileManager | | listening on 0.0.0.0:300 33
    2012-09-11 12:14:23.387544|INFO |VirtualServer | 1| listening on 0.0.0.0:998 7
    2012-09-11 12:14:23.387787|INFO |CIDRManager | | updated query_ip_whiteli st ips: 127.0.0.1,
    2012-09-11 12:14:23.388222|INFO |Query | | listening on 0.0.0.0:100 11
    this is what im getting. ports are open through router and when i host a server on my PC then i and my friend can get in. whats wrong ?
    UK
    769
    Bit confused at this, 'localhost' will always be the PC you're on, if your PC & Debian box are on the same network you need to connect to the local IP of the Debian box
    9
    ooooh, got it now, thanks
    e// well, i can get in now but my friends cant. the ports are open on the router so i gues i need to open ports on the debian side aswell, how do i do that ?
    UK
    769
    If you were running Centos & IPTables, I'd be able to answer that. You'll have to find out what firewall software Debian is using, then figure out how to add rules to open the correct ports.
    Having said that, you said 'i can get in now', so I assume you mean you can connect to Teamspeak (on the Debian box) from your PC? If that's the case the ports on the Debian box are already open
    Just make sure your router is forwarding the ports to the correct IP & you've given the correct (external) IP to your friend
  1. Replies: 13
    Last Post: July 13th, 2014, 12:09 AM
