Results 1 to 7 of 7
    October 2012
    Question Teamspeak + NPL Problem
    I don't know what i have to do.
    I've have normally server it all works perfekt if i load the npl in the server the server startet but no one can connect to it.
    Ports who are free:9985,10011,30033
    musst i get a new port free or what?
    TS-Serverversion: 3.0.6.1 [Build: 1340956745] x86 Version
    VServer: Linux
    6,079
    Please provide the latest server logs and the output of
    ls -Flah
    from the folder where you installed Teamspeak in.
    October 2012
    The last serverlog after start with npl:
    2012-10-09 13:17:41.112647|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6.1 (2012-06-29 07:59:05)
    2012-10-09 13:17:41.133385|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2012-10-09 13:17:41.133451|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2012-10-09 13:17:41.133915|INFO |DatabaseQuery | | checking database integrity (may take a while)
    an the things from ls
    drwxr-xr-x 9 ts3 root 4.0K Oct 9 14:17 ./
    drwxr-xr-x 5 root root 4.0K Apr 27 17:03 ../
    -rw------- 1 ts3 users 853 Sep 20 22:00 .bash_history
    -rw-r--r-- 1 ts3 users 38K Jun 29 09:01 CHANGELOG
    -rw-r--r-- 1 ts3 users 24K Jun 29 09:01 LICENSE
    drwxr-xr-x 2 ts3 users 4.0K Sep 20 21:55 doc/
    drwx------ 4 ts3 users 4.0K Sep 20 21:55 files/
    -rwxr-xr-x 1 root root 204K Jun 29 09:01 libts3db_mysql.so*
    -rwxr-xr-x 1 root root 896K Jun 29 09:01 libts3db_sqlite3.so*
    -rw-r--r-- 1 root root 903 Dec 28 2011 licensekey.dat
    drwx------ 2 ts3 users 4.0K Oct 9 14:17 logs/
    -rw-r--r-- 1 ts3 users 1 Apr 2 2012 query_ip_blacklist.txt
    -rw-r--r-- 1 ts3 users 25 Apr 4 2012 query_ip_whitelist.txt
    -rw-r--r-- 1 root root 112 Oct 9 14:17 serverkey.dat
    drwxr-xr-x 2 ts3 users 4.0K Mar 17 2012 serverquerydocs/
    drwxr-xr-x 4 ts3 users 4.0K Sep 20 21:56 sql/
    -rw-r--r-- 1 ts3 users 270K Oct 9 14:15 ts3server.sqlitedb
    -rwxr-xr-x 1 root root 6.7M Jun 29 09:01 ts3server_linux_x86*
    -rwxr-xr-x 1 ts3 users 1.2K Jun 29 09:01 ts3server_minimal_runscript.sh*
    -rwxr-xr-x 1 ts3 users 3.7K Jun 29 09:01 ts3server_startscript.sh*
    drwxr-xr-x 2 ts3 users 4.0K Sep 20 21:56 tsdns/
    1000634:/home/ts3 #
    6,079
    The server cannot start because it doesn't have access to some of it's files.
    Please run the following command as root in the directory of the TeamSpeak server:
    chown -hR ts3:users
    Make sure that the server is stopped (check ps aux | grep ts3) and then switch to the ts3 user and start the TeamSpeak server:
    su ts3
    cd /path/to/teamspeak/install/directory
    ./ts3server_startscript.sh start
    October 2012
    done
    1000634:/home/ts3 # ls -Flah
    total 8.2M
    drwxr-xr-x 8 ts3 root 4.0K Oct 9 17:09 ./
    -rw------- 1 ts3 users 992 Oct 9 17:07 .bash_history
    -rwxr-xr-x 1 ts3 users 204K Jun 29 09:01 libts3db_mysql.so*
    -rwxr-xr-x 1 ts3 users 896K Jun 29 09:01 libts3db_sqlite3.so*
    -rw-r--r-- 1 ts3 users 903 Dec 28 2011 licensekey.dat
    drwx------ 2 ts3 users 4.0K Oct 9 17:09 logs/
    -rw-r--r-- 1 ts3 users 112 Oct 9 14:17 serverkey.dat
    -rw-r--r-- 1 ts3 users 6 Oct 9 17:09 ts3server.pid
    -rw-r--r-- 1 ts3 users 270K Oct 9 17:02 ts3server.sqlitedb
    -rwxr-xr-x 1 ts3 users 6.7M Jun 29 09:01 ts3server_linux_x86*
    but nothing works
    October 2012
    now after a long time worked with the npl the logfile say that:
    2012-10-09 16:09:52.628876|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6.1 (2012-06-29 07:59:05)
    2012-10-09 16:09:52.629522|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2012-10-09 16:09:52.629571|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2012-10-09 16:09:52.629957|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2012-10-09 16:13:01.799774|ERROR | | | TS3ANetwork::Connect failed error: 110
    2012-10-09 16:13:01.799911|ERROR |Accounting | | Unable to connect to accounting server
    2012-10-09 16:13:01.799964|ERROR |ServerLibPriv | | Server() error while starting servermanager, error: unable to connect to accounting server
    2012-10-09 18:26:16.060687|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.6.1 (2012-06-29 07:59:05)
    2012-10-09 18:26:16.061243|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2012-10-09 18:26:16.061308|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2012-10-09 18:26:16.061780|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2012-10-09 18:26:16.120399|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2012-10-09 18:26:16.153937|INFO |FileManager | | listening on 0.0.0.0:30033
    2012-10-09 18:26:16.210591|WARNING |Variables | | loadFromDatabase() found unregistered ident: virtualserver_antiflood_points_needed_command_stop
    2012-10-09 18:26:16.210714|WARNING |Variables | | loadFromDatabase() found unregistered ident: virtualserver_antiflood_points_needed_ip_ban
    2012-10-09 18:26:16.285566|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1, 94.100.240.196,
    2012-10-09 18:26:16.286217|INFO |Query | | listening on 0.0.0.0:10011
    October 2012
    ok after looking in google for the "TS3ANetwork::Connect failed error: 110" problem i think i have the problem and write tomorrow to my provider that they open port 2008.......thank you for help.
  1. Teamspeak and Alienware problem (SLi problem!)
    By Arotished in forum General Questions
    Last Post: January 27th, 2013, 12:56 PM
  2. TeamSpeak 3 NPL Problem
    By DEVIK in forum Server Support
    Last Post: September 25th, 2012, 10:52 AM
  3. problem with teamspeak 3
    By rexxel in forum Windows
    Last Post: June 16th, 2011, 10:06 AM
