Results 1 to 7 of 7
    June 2012
    ServerQuery Admin problem
    Hey everyone
    I've a great problem... I want to login in to server query and make myself Server Query Admin:
    login serveradmin <Pass>
    use sid=2
    servergroupdelclient sgid=2 cldbid=2
    And then i get this in the last line:
    error id=2568 msg=insufficient\sclient\spermissions failed_permid=17310
    Altough i've a new TeamSpeak Server on my Root with full Server Admin rights.
    I dont know what to do, and google cant help me, so i hope someone else can
    P.S.: Sorry for bad english
    Secret Base in Arctic Region
    1,671
    First, wrong command, use "servergroupaddclient".
    Second, its not recommended and supported to add any normal user into a query group.
    Normally SA-Group is sufficient, you only need a fraction of the permissions available in TS in daily business.
    252
    Can you give me the output of the command "whoami" after the login "serveradmin..." procedure?
    June 2012
    Thats the output:
    virtualserver_status=online virtualserver_id=1 virtualserver_unique_identifier=K 7crTNgE9IV5GbKZhDogoTfQtvU= virtualserver_port=9990 client_id=11 client_channel_ id=1 client_nickname=serveradmin\sfrom\s87.142.221.201: 64519 client_database_id= 1 client_login_name=serveradmin client_unique_identifier=serveradmin client_orig in_server_id=0
    error id=0 msg=ok
    (I made it with putty)
    June 2012
    Nobody can help me??
    March 2011
    You have use "sid=2", but it should be "use sid=1" since it's the first server, not the second
    So the putty commands should be...
    Add Server Query Admin:
    use sid=1
    servergroupaddclient sgid=2 cldbid=2
    logout
    Del Server Query Admin:
    use sid=1
    logout
    That's assuming your cldbid is actually 2 (the very first account you logged in with after the server creation)..... :-)
    6,079
    Adding regular clients to any query group is neither recommended, nor supported or required for anything. It can cause lots of trouble and can easily trash your server setup
  1. Replies: 2
    Last Post: July 8th, 2013, 10:52 AM
  2. ServerQuery Admin Problem
    By MrStorm in forum Off Topic
    Last Post: October 16th, 2012, 03:14 PM
  3. [Rejected] [Suggestion] Changing clientname as Admin / ServerQuery Admin
    By Sebi94 in forum Suggestions and Feedback
    Last Post: September 5th, 2012, 12:38 PM
  4. cant login as a serverquery admin
    By SiCk123 in forum Permission System
    Last Post: February 1st, 2011, 04:27 AM
