Results 1 to 4 of 4
    November 2012
    licensekey.dat is not working why ?
    I have this Problem.
    login as: vlox
    [email protected]'s password:
    Linux vserver3732 3.3.1-domU #3 SMP Wed Apr 4 23:16:57 UTC 2012 x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Sat Nov 24 15:59:44 2012 from p5dc8649c.dip0.t-ipconnect.de
    $ cd /home/vlox/vlox_ts3server/vlox_ts3amd64
    $ ls
    CHANGELOG  doc    libts3db_mysql.so    licensekey.dat  query_ip_blacklist.txt  serverquerydocs  ts3server.sqlitedb     ts3server_minimal_runscript.sh  tsdns
    LICENSE    files  libts3db_sqlite3.so  logs            query_ip_whitelist.txt  sql              ts3server_linux_amd64  ts3server_startscript.sh
    $ ./ts3server_minimal_runscript.sh
    2012-11-24 16:05:02.760237|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.6.1 (2012-06-29 07:59:05)
    2012-11-24 16:05:02.760664|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2012-11-24 16:05:02.760746|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2012-11-24 16:05:02.761036|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2012-11-24 16:05:02.789213|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2012-11-24 16:05:03.289542|ERROR   |Accounting    |   | local accounting reports an already running instance, instance will shutdown
    2012-11-24 16:05:03.289781|ERROR   |ServerLibPriv |   | Server() error while starting servermanager, error: instance limit reached
    Edit : Rights for data reading added.
    My question is how can i check if my Licensekey is valid ?
    am i allowed to post the code here ?
    sry for bad english.
    MFG Vlox
    2,698
    Quote Originally Posted by Vlox-Dunkral View Post
    MFG Vlox
    Better DON'T post the code of your license here!!
    In this post, a model of a valid license:
    http://forum.teamspeak.com/showthrea...343#post321343
    In this thread you'll find some clues:
    http://forum.teamspeak.com/showthrea...licensekey.dat
    a) maybe the e-mail programm has changed the contents --> try with a webmail version
    b) see the Chris's sugestion in post #7
    April 2011
    1,266
    Are you sure that your license.dat is read and writeable by the server? In your screenshot showing the file access rights the line of the license.dat is quite empty.
    6,078
    Keep in mind the post I linked there was for the specific case when the for some weird reason the file wasn't decoded from it's base64 encoded form used for mailing. So only use it when the file ONLY contains one huge string that is on a single line and ends with one or two equal signs.
    @Vlox-Dunkral: post ls -FlAh from the same directory you installed the server to.
    Also you can check whether the license has expired by doing the following: cat licensekey.dat | grep end
    it should post a single line containing a date... if the date is in the future the license should be fine and work, otherwise it expired and you will have to get a new one.
    If nothing happens at all, then you are either not allowed to access the file in which case you can do a sudo -c chown vlox:vlox licensekey.dat and repeat the command from above. If it still doesn't display anything possibly the file wasn't decoded, see PotaBlava's reply then.
  1. Licensekey.dat
    By Metallica in forum Linux / FreeBSD
    Last Post: December 1st, 2012, 09:44 PM
  2. licensekey.dat?
    By mvp4kobe in forum General Questions
    Last Post: October 30th, 2012, 01:41 PM
  3. licensekey.dat
    By dennis403 in forum General Questions
    Last Post: April 5th, 2012, 09:35 PM
  4. NPL 512 slot licensekey.dat not working
    By grinn3r in forum Windows
    Last Post: March 7th, 2012, 12:27 AM
  5. [No Bug] Licensekey.dat
    By chris_pl in forum Linux / FreeBSD
    Last Post: January 24th, 2011, 06:49 PM
