Page 1 of 15 12311 ... LastLast
Results 1 to 15 of 217
    6,080
    "Failed to connect to server" - Troubleshooting & Solutions
    This is a collective Thread about any and all issues with not being able to connect to a certain server, or any server at all. It will list potential issues and solutions you should check out first before posting a new thread about this kind of issue.
    I got the "Failed to connect to server" error message. What should I do?
    First of all don't panic Now try the following
    • make sure you didn't misspell the address and that you do not have any typos in the address.
    • Ping the address
    • Ask a few friends to try and connect to the server from their end (these friends should preferably have different ISPs to rule out ISP failure), if it doesn't work for them either it's increasingly likely it's a server problem after all and in that case nobody but the server owner can do anything about it.
    • Try to connect using a mobile client using the mobile network (not Wireless LAN), it it doesn't work again it's more likely a server problem (at least if your mobile connection is stable and better than edge).
    If all those worked (ie. your friends could connect and/or you connecting with your cell phone worked too), then it might be a problem with your network or router.
    • Check your firewall and make sure it doesn't block TeamSpeak at all.
    • Check your security software to make sure it doesn't block any ports or protocols (some like to block UDP traffic which is essential for TeamSpeak)
    • Check your router and search for any firewall, SPI Firewall, DDoS Protection, Flood Protection or similar and disable those option
    • Occasionally it helped to disable "UDP Checksum Offload" for the network card. On Windows this can be found in the device manager, properties of the network adapter under the advanced tab.
    If you are on a campus / work / public network then it might very well be that the responsible network administrator blocked certain ports and maybe even UDP alltogether. In this case you will need to ask the network administrator to unblock the ports of those servers you would like to connect to.
    After you disabled them try and connect again, if it still doesn't work then maybe your ISP is blocking UDP traffic, ask them about it.
    TeamSpeak needs UDP and if it somehow gets blocked it just won't connect.
    September 2013
    i am having the same issue i can log on to other servers but not my groups server for the game i play ive done everything mentioned to do and still get error cant connect to server and other members are using ut
    October 2013
    Hello reputable administration! ! ! Help please with a problem! ! ! I can't unite to the server. I enter the IP-90.188.239.176 to me the mistake already tells everything tried the head hurts help explain to the fool what to make! ! ! Thanks in advance!!!
    January 2014
    Is somebody from team speak going to resolve this??? Its happening to alot more people
    18,422
    Quote Originally Posted by Dean Shields View Post
    These are network problem. What should we fix on other networks???
    March 2014
    I am having the same exact issue. I cannot connect to one server, but can connect to all others. Other people are able to connect to the server and think I am nuts.
    Were you able to resolve this issue? If so, how did you do it?
    March 2014
    O'Fallon, MO
    6
    Followed all the directions on ensuring UDP ports are open, typing in IP address, turning off popup blocker, etc etc etc....
    3/16/2014 7:31 PM	 Info	TeamSpeak 3 Client 3.0.14 (2014-03-12 11:49:03)
    3/16/2014 7:31 PM	 Info	SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    3/16/2014 7:31 PM	Direct Sound	Debug	setting timer resolution to 1ms
    3/16/2014 7:31 PM	 Info	Loading plugin: appscanner_plugin
    3/16/2014 7:31 PM	 Info	Loading plugin: clientquery_plugin
    3/16/2014 7:31 PM	 Info	Loading plugin: lua_plugin
    3/16/2014 7:31 PM	 Info	Loading plugin: teamspeak_control_plugin
    3/16/2014 7:31 PM	 Info	Loading plugin: test_plugin
    3/16/2014 7:31 PM	 Info	Loading plugin: ts3g15
    3/16/2014 7:31 PM	Query	Info	listening on 127.0.0.1:25639
    3/16/2014 7:31 PM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    3/16/2014 7:31 PM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    3/16/2014 7:31 PM	 Info	*** Time [SERVERVIEWMANAGER]: 173
    3/16/2014 7:31 PM	Input	Info	Default monitoring enabled
    3/16/2014 7:31 PM	 Info	*** Time [MAINWINDOW]: 520
    3/16/2014 7:31 PM	 Info	*** Time [INIT]: 521
    3/16/2014 7:31 PM	ClientUI	Info	Qt version: 5.2.1
    3/16/2014 7:31 PM	ClientUI	Info	Using configuration location: C:\Users\Kevin\AppData\Roaming\TS3Client\settings. db
    3/16/2014 7:31 PM	ClientUI	Info	Last update check was:
    3/16/2014 7:31 PM	ClientUI	Info	Connect to server: ts3.thecrimsonorder.com
    3/16/2014 7:31 PM	ClientUI	Info	Trying to resolve ts3.thecrimsonorder.com
    3/16/2014 7:31 PM	TSDNS	Info	SRV DNS resolve unsuccessful for "_ts3._udp.ts3.thecrimsonorder.com"
    3/16/2014 7:31 PM	TSDNS	Info	No SRV TSDNS found at "_tsdns._tcp.ts3.thecrimsonorder.com"
    3/16/2014 7:31 PM	TSDNS	Info	DNS resolve successful, "ts3.thecrimsonorder.com"=209.141.39.218
    3/16/2014 7:31 PM	TSDNS	Info	TSDNS found at "ts3.thecrimsonorder.com" and queried successfully. Result: east1.ts3.enjin.com:18074
    3/16/2014 7:31 PM	ClientUI	Info	Lookup finished: east1.ts3.enjin.com 18074 ts3.thecrimsonorder.com 1 0
    3/16/2014 7:31 PM	ClientUI	Info	Resolve successful: east1.ts3.enjin.com:18074
    3/16/2014 7:31 PM	ClientUI	Info	Blacklist check ok
    3/16/2014 7:31 PM	ClientUI	Info	Initiating connection: east1.ts3.enjin.com:18074 ts3.thecrimsonorder.com
    3/16/2014 7:31 PM	Windows Audio Session	Debug	WAS:penDevice-enter
    3/16/2014 7:31 PM	Windows Audio Session	Debug	WAS Buffer size: 896
    3/16/2014 7:31 PM	Windows Audio Session	Debug	WAS:penDevice-leave
    3/16/2014 7:31 PM	Windows Audio Session	Debug	WAS::startDevice-enter
    3/16/2014 7:31 PM	Windows Audio Session	Debug	WAS::startDevice-leave
    3/16/2014 7:31 PM	PreProSpeex	Info	Speex version: speex-1.2beta3
    3/16/2014 7:31 PM	ClientUI	Info	Connect status: Connecting
    3/16/2014 7:31 PM	ClientUI	Info	Blacklist check timeout
    3/16/2014 7:31 PM	ClientUI	Info	Connect status: Disconnected
    3/16/2014 7:31 PM	ClientUI	Info	Failed to connect to server, want autoreconnect = 0
    April 2014
    I have had this very problem today and its not my end as a friend in the states cannot connect either and im in the uk so server failure i guess. Altho i did manage to connect to someone elses server. Please help we need this to be running as its our alliance chat
    6,080
    Quote Originally Posted by Bappi View Post
    As stated you need to contact the company / individual that is providing the TeamSpeak server. Nobody on this forum can help you with a specific server being unavailable if it is the server's end that is having the problem. You will need to talk to those that run the server.
    May 2014
    Admins, please change this issue from resolved for it is not. I am attempting to connect to a server (which is in canada while I live in the US) which my associates are currently inside and inform me that it is running properly. So the issue is not with the server. However, I have been able to connect to it in the past (such as 5 hours ago) but only now have I received a connection failed error. I am able to connect to other servers easily. Please inform me as to what is causing this bug so I may correct it.
    2014-05-29 23:19:11.524110|INFO |ClientUI | 1| Connecting to next server...
    2014-05-29 23:19:11.524110|INFO |ClientUI | 1| Connect to server: 192.99.7.42
    2014-05-29 23:19:11.525112|INFO |ClientUI | 1| Blacklist check ok
    2014-05-29 23:19:11.525112|INFO |ClientUI | 1| Initiating connection: 192.99.7.42:9987 192.99.7.42
    2014-05-29 23:19:11.807299|INFO |ClientUI | 1| Connect status: Connecting
    2014-05-29 23:19:16.793315|INFO |ClientUI | | Blacklist check timeout
    2014-05-29 23:19:16.859359|INFO |ClientUI | 1| Connect status: Disconnected
    2014-05-29 23:19:16.860357|INFO |ClientUI | 1| Failed to connect to server, want autoreconnect = 0
    2014-05-29 23:26:34.622056|INFO | | | Memory usage: 39.52 MiB
    August 2014
    Having same issue for lack of connection.
    Worked great for a few weeks, suddenly no connection. Various error messages reported; blacklist timeout, etc.
    Its not the server, others in my group can connect.
    Its not my connection, router, firewall, etc. Have tested all of those.
    So.. any ideas? I see this same issue all over reported as blacklist, no server connection, etc. but don't see any solution.
    September 2014
    Arg
    Hiho!!! PLxs I neeed help My Ts was working very well but since yesterday i cant log in the new ip that my friends gove to me :< If some one can help me i will be so happy !!!!!!!! I dont understand so much things about ISPs and that things but everything was fine :/
    October 2014
    Teamspeak randomly disconnects me
    So I can join any TS3 channel but I will randomly disconnect after a while. When I disconnect, it will not let me rejoin the channel I disconnected from for about 5 minutes. I am able to join other channels during this time unless I disconnect from them also.
    It just says
    attempting to resolve hostname...
    failed
    and repeats over and over
    I uninstalled and reinstalled to try and fix the problem but that didn't work. I've been having this problem for a few weeks now.
    4,371
    October 2014
    I don't think that solves my problem. I am able to connect to the server, but then I randomly disconnect and can't reconnect. I could be wrong though.. I tried troubleshooting but didn't work.
  1. Replies: 0
    Last Post: February 28th, 2015, 04:00 PM
  2. Replies: 0
    Last Post: January 1st, 2014, 11:28 PM
  3. [Not possible] Change "Failed to connect to server"-message
    By djang0 in forum Server Support
    Last Post: August 13th, 2013, 02:05 PM
  4. Replies: 1
    Last Post: January 17th, 2013, 10:37 AM
