Page 1 of 6 123 ... LastLast
Results 1 to 15 of 83
    6,035
    [Beta Channel] TeamSpeak 3 Client 3.0.10
    We are happy to announce that the TeamSpeak 3 Client 3.0.10 is available for beta testing in the Beta Channel.
    Most notable changes is that the Opus Codec has been added into the client and server.
    Please note: You need a Server running version 3.0.7 PreRelease2 or later (published 10.12.12) in order to test this client and it's new features
    Please note that Opus Music is not intended for general voice chat and no preprocessing is done when opus music is used. This means that AGC, noise suppression, echo cancellation etc. do not work when using Opus music.
    Complete changelog:
    === Client Release 3.0.10 10 Jan 2013
    + Added Opus voice and music codecs. Requires server 3.0.7 or later.
    * Updated Qt to 4.8.3 for improved Windows 8 compatibility.
    * Overhauled Audio tab of channel edit dialog for new Opus Codec
    * Updated client to use new permission list format as used by server 3.0.7
    * Restore size and position of Complains List and Permission Overview windows.
      Changed base class of both from QDialog to QWidget.
    * Added guiConnect, createBookmark, getPermissionIDByName and
      getClientNeededPermission to Lua API
    * Tweaked length checks in various text fields for client and channelname.
    * A spacer without a name will now be shown as an empty line.
    * If a playback- or capture profile was renamed or deleted every hotkey
      depending on this profile will be adjusted.
    * Changed hotkey dialog category spacer alignment to left.
    * Client template can now show the update channel used by other clients.
    * New option to autostart TeamSpeak on Windows startup.
    * Added optional "server_uid=<suid>" parameter to ts3server links. If an
      existing bookmark with the same server UID found, the bookmarks settings
      will be used for the connection.
    * Added context menu to notifications to select which sounds are important.
      The setting is globally for all sound packs.
    * Added context menu entry in server list to copy server address to clipboard.
    * Added "Move Client to own Channel" in client context menu.
    * Added display in status bar if client has unread offline messages.
    * Added TS3_CONFIG_DIR environment variable to overwrite location of config
      directory.
    * Adjusted default size of some windows to adjust better to small and very
      large monitor resolutions.
    * Added message for outgoing pokes. Can be configured in Notifications Options.
    * Overhauled Tabs look on Mac OS X via default_mac.qss stylesheet.
    * ts3server links are again caught for the Collected URLs
    * Added confirmation when resetting custom toolbar settings to default
    - Fixed upload/download slots if one slot was set to 0.
    - Fixed closing hotkey dialog even though keep open was enabled.
    - Fixed copy and paste client text.
    - Fixed client window sizes which now depend on the screen resolution when
      opening for the first time.
    - Fixed converting 3D sound positions into db.
    - Fixed offline message parsing error if message was empty.
    - Fixed that hotkey push button always adds in "all" hotkey profiles instead
      of the selected one.
    - Fixed resizing and centering smaller gif icons to 16x16.
    - Fixed that the setup wizard only configures the default hotkey profile and
      when having more than one hotkey profile a hint on the welcome page will be
      shown as a reminder.
    - Fixed bb-code of server host message when message contains newlines.
    - Fixed editing a hotkey but assigning the same action.
    - Fixed a direct input hotkey issue when pushing two buttons at once on
      different devices.
    - Fixed stuck PTT button when releasing the mouse.
    - Fixed "Edit bookmark" contextmenu in bookmarks menu.
    - Fixed some ts3server links issues when using cid parameter.
    - Setup wizard now always uses the Standard hotkey profile in case when
      multiple hotkey profiles exist.
    - Fixed UTF-8 characters in URL catcher
    - Fixed possible crash sending a poke to a meanwhile disconnected client
    - Fixed local mute/unmute hotkeys
    - Fixed passing onClientIDsEvent and onClientIDsFinishedEvent to Plugin API
    To update your TeamSpeak client on the beta channel, go to the TeamSpeak 3 Client installation folder and create a file "update.ini" with this content:
    [Channel]
    beta=true
    Last edited by dante696; January 14th, 2013 at 02:52 PM. Reason: changelog updated
    69
    Opus codec...
    Also just mono, or will TS finally grow up and allow stereo broadcast of music?
    6,035
    Yes, opus music is stereo
    All other codecs are mono.
    69
    Sorry for double checking. It just sounds too good to be true.
    So we really will be able to broadcast stereo music through Teamspeak and other people will hear stereo music?
    If that's true, I will get on my knees with tears of joy in my eyes and thank the holy Teamspeak gods.
    This will be the second best x-mas gift for me this year, right after the upcoming release of the new Android app (wich hopefully features auto reconnect and better microphone quality :-)
    June 2002
    Krün / Germany
    1,639
    @Failure: yes...
    November 2010
    30
    I tested the Opus Music codec.. this quality is really awesome!!! Great work to embedded this codec.
    But not all TeamSpeak Server Versions with 3.0.7 supports this Codec. I have the following Version which not works -> 3.0.7 (24.10.2012 10:55:20).. Tomorrow i must update ;-)
    2,699
    In clientinfo.tpl, x and y marks included for delimiting the new variable CLIENT_VERSION_STATE
        <td class="label">Version:</td>
        <td>%%CLIENT_VERSION%% x%%CLIENT_VERSION_STATE%%y on %%CLIENT_PLATFORM%%</td>
    Results:
    Version:3.0.10 (07/12/2012 10:41:57) xy on Windows
    It seems CLIENT_VERSION_STATE shows nothing.
    December 2012
    bug found!
    if u have more than 5 gifs in a channel-description u get 25% cpu load
    Florida, US
    35
    Thank you for adding this feature. I hope it stays in the final release.
    2,699
    Here in the changelog and in the client too:
      bookmark and also a link to open the bookmark manager.
    a) The "Edit bookmark" appears twice
    b) The line "bookmark and also a link to open the bookmark manager" has no sense where it's placed.
    6,035
    Results:
    Doesn't appear to be the case for me, the clientinfo.tpl contains the following lines:
      <tr>
        <td>%%CLIENT_VERSION%% %%CLIENT_VERSION_STATE%% on %%CLIENT_PLATFORM%%</td>
      </tr>
    the german version clientinfo_de.tpl contains:
      <tr>
        <td>%%CLIENT_VERSION%% %%CLIENT_VERSION_STATE%% auf %%CLIENT_PLATFORM%%</td>
      </tr>
    so everything looks ok to me.
    File Hashes (SHA1):
    5C1C60898FC782B5A0DB778D7DA563CED86F0BFE clientinfo.tpl
    2B4F0BD8C135E7885B81ADDFED6596D462F7FEB8 clientinfo_de.tpl
    Note that the version needs to match exactly with those on the update server, if it doesn't match with the update server nothing is being displayed, so if a client is running for example 3.0.8 it won't display anything, nor if the client were to be running this pre release when there is a newer one available.
    True, thanks for spotting
    Quote Originally Posted by jackbox View Post
    bug found!
    I couldn't reproduce this, but depending on the gif, it's size and the information stored in the gif file, the processing can obviously take quite a lot of cpu power.
    2,699
    Well, I was using 3.0.10 client with the 3.0.7 server and I've added x y as delimeters to CLIENT_VERSION_STATE because nothing it's shown. It's supposed it shows alpha|beta|stable.
    6,035
    Did you select yourself and are you sure that you are using the default theme in settings -> options -> design -> theme?
    Keep in mind this shows for the currently selected client.
    2,699
    Yes, I've selected myself (I'm in beta) and I've had selected default theme --> to be sure of this I've modified the clientinfo.tpl with the x-y delimeters.
    Note: Server and client are both in windows
    Catalunya
    2,350
    Works in German and in English
ID:	7196 Click image for larger version.
  1. [Beta Channel] TeamSpeak 3 Client 3.0.18
    By Chris in forum Archive
    Last Post: September 18th, 2015, 01:42 PM
  2. [Beta Channel] TeamSpeak 3 Client 3.0.17
    By PeterS in forum Archive
    Last Post: August 10th, 2015, 09:35 AM
  3. [Beta Channel] TeamSpeak Client 3.0.14
    Last Post: March 13th, 2014, 08:34 AM
  4. [Beta Channel] TeamSpeak 3 Client 3.0.10.1
    Last Post: April 1st, 2013, 12:50 PM
  5. [Beta Channel] TeamSpeak 3 Client 3.0.9
    Last Post: October 22nd, 2012, 08:41 AM
