Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 114
  1. #16
    October 2013
    constant error
    Failed to convert string nan to float
  2. #17
    March 2014
    Unhappy Failed to convert string nan to float
    Whenever I try to connect to a server, or 'Begin Test' of any microphone, I get the error: Failed to convert string nan to float. I have tried updating drivers, using different settings, logging on to different servers, using the 32 bit client instead of the 64, all to no avail. Any suggestions?
  3. #18
    March 2014
    Nevermind. Deleted my settings file and it magically worked. :P For those of you with windows 8, it's %appdata%\roaming\TS3Client. Delete the settings.db
  4. #19
    April 2014
    Anytime I try to connect to my ts3 server, or anytime I try to change capture settings and test them. Anyone have an idea?
    I am running windows 7 64 bit. My usb microphone is set to default. My microphone works when I test it in set-up. I am running windows 7 64 bit. I am running the current version of TS3. Every time I open TS3 and connect to server or try and test capture device it crashes with that message. I cannot find an answer to this problem anywhere.
    Here are the crash dump files.
    Attached Files Attached Files
  5. #20
    April 2014
    Everytime i stat TS3 it chrashes
    This is what appears after closing the programme.
    HELP??
  6. #21
    April 2014
    I have a fail ! Need quick help !
    Pls help me.
    Fabian
  7. #22
    April 2014
    Thx.
    I do this ! But the fail is there again !
  8. #23
    April 2014
    Quote Originally Posted by SkillerPro View Post
    Thx.
    I am new in this forum.
    I had the same problem but I solved it.
    Try this:
    Delete ts settings file. For Windows 8.1 users, go to %appdata%\TS3Client and delete the settings.db
    You will have to start it again and do all the setting from the begging,
    but this is the only solution I could find.
    Hope it will work for you to.
  9. #24
    April 2014
    Cannot connect to channel: "Failed to convert string nan to float"
    Ok, new problem today. TS was working fine earlier, but now I get this error when trying to join a channel:
    I had plugged in my USB headset into a different port right before this happened. (My cpu is stupid and thinks each time I plug it in a new port its a different headset.)
    Tried uninstalling and reinstalling TS, no luck.
    System specs:
Name:	system specs.PNG
  10. #25
    April 2014
  11. #26
    April 2014
    Can't even connect.
    What doas that mean ? I don't understand :s I tried to close/ope my device, reset my connection... Nothing works. What should I do ?
  12. #27
    18,151
    My post above still counts.
    #post #15
    There is nothing we can do without these steps.
    And Please make sure, that all of your drivers are updated.
  13. #28
    April 2014
    Hi there.
    I had the same problem and I think I've found a solution. After following the steps in post 15, I messed about with the profiles
    After you get the error 'Failed to convert string nan to float' whilst trying to connect to a server, somethings gone wrong with your profile! However, it's only the Default profile that seems to be affected.
    Solution: Go to the Settings > Options > Playback tab, bottom of the list click the green + and make a new profile. Use your preferred settings. Do the same for your capture profile.
    Now, when you try to connect to a server, before you click the connect button make sure you do NOT use the default capture and playback profiles, but the new profile you created, even if it has the same settings as your default!
    Worked for me anyway, hope it works for you.
  14. #29
    May 2014
    Post TeamSpeak 3 Error
    My Teamspeak 3 hours ago is working , but when i open it again he said : Failed to convert string nan to float.
    What's happen? Help Me please. it's urgent
  15. #30
    4,350
    See here.
    Quote Originally Posted by NexTiMe View Post
    What's happen?
    All your base are belong to us.
