Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 114
  1. #46
    2,698
    Quote Originally Posted by nongranda View Post
    When i want to connect to a serves this pops up: Attachment 10695
    Help me pls :s
    You can help yourself and all the community reading, following and giving feedback about post#15 in this thread:
    http://forum.teamspeak.com/showthrea...132#post335132
  2. #47
    June 2014
    Error TS3
    Hello! I will join i server, my programm close it and there stand: Failed to convert string nan to float.
    Please Help
  3. #48
    April 2011
    1,266
    Please search!
  4. #49
    June 2014
    Teamspeak coming with error message HELP please
    thts the error message how can i resolve it??
    Kind Regards
  5. #50
    July 2014
    Question need help
    im trying to get in to my alliance server and every time i try it comes up with: Failed to convert string nan to float. and it closes TS3 application down can some one help me can i fix it of do have to uninstall it so some thing thx
  6. #51
    18,151
    No we can not help, if user ignore messge, that have been send over and over again in this thread.
    Post #1 post #19 post #25 post #28 post #29 post #31 post #33 post #36 post #38 post #40 post #44
    and now in post #49
  7. #52
    July 2014
    The capture and play back in windows are headset microphone ASTRO wireless transmitter deafault device
    Setting 16 bit,48000 HZ (DVD Quality)
    When I do %appdata%/TS3Client I do not see the setting.db
    This is all I see http://prntscr.com/41129q please help thank you
  8. #53
    2,698
    Quote Originally Posted by mcshadow View Post
    The file is "settings". You can see on the right that its type is "DB File".
    Note: So, as it's said in post#15, point 4:
    you should rename "settings" to "backup", with the TS3 client closed.
  9. #54
    October 2009
    Sweden
    Hi. Iv never seen this issue before in TS3. The solution to replace the settings.db with a new works. Kind of sad tho as you have to make all settings again.
    It happened as I have a external sound-card that was shut of, when I started the TS3 client. I connected to our server and it told me I had no sound for capturing what I was saying. So I entered the settings, clicked on the drop-down and saw it was not listed as it was shut of. While I had this drop-down shown of audio interfaces, I started my external sound-card and saw all new options be filled in the list. Selected the interface I wanted to use, and I got this crash.
    Have not yet been able to duplicate this. But it seems to have something to do with the listed audio interfaces. Because if I select another interface than my external sound-card that I wish to use it works.
    Selecting another interface shutting down the external, start it up again and try select it again dose not work either. So something weird was added to the db file this time my external sound-card was started up with the settings/dropdown visible.
    Hope this might give some light on this issue even tho I have not been able to duplicate it yet.
  10. #55
    July 2014
    Me in Problem
    Bug in TeamSpeam me in joint to server in crash and
    HTML Code:
    http://zapodaj.net/b45a23b6c42ff.png.html
    Pleas help me
  11. #56
    July 2014
    every time I am trying to connect to a server this message pops up, anybody have an idea what it means. and how I can resolve it? it happened right after I updated my client, and now my headset is not working anymore either. so can it be an audiocard issue as well?
  12. #57
    August 2014
    teamspeak giving me a code saying Failed to convert string nan to float
    when i try to open up my teamspeak i get a code that says 'Failed to convert string nan to float' i dont know what to do and i need HELP i am also using trutle beach xp500's if that helps at all
  13. #58
    August 2014
    My Teamspeak Won't Let Me Connect To Any Servers
    ^This is the message I recieve everytime I try to connect to a server. I have tried re-installing but nothing helps. I need assitance.
  14. #59
    August 2014
    Hello, Failed to convert string nan to float
    http://puu.sh/aJ4VY/87d50e1948.jpg, the Error puushed and my Ts
    http://puu.sh/aJ511/9f03ea1962.png Headphone
    http://puu.sh/aJ54e/4332ed6701.png micro
    http://puu.sh/aJ5dN/c92a622777.png my log
  15. #60
    August 2014
    Lightbulb Failed to convert string nan to float
    the client crushes every time, here is how to easy reporduce
    - add another microphone
    - set it to be you capture device
    - use it
    - exit the client
    - remove the new mic
    - open ts
    - try to test mic or login to a server - you get crush with error "Failed to convert string nan to float"
    no matter if i change the capture device back or plug the mic the same mic
    the only thing that works is to delete the db file....
    please help
    logs: https://www.dropbox.com/sh/hnpom1te5...tJZiSB6QMj0Tka
