2 days ago my teamspeak worked well.Now it doesnt work at all,i tried everything reinstalled,check does my mic works and it does i tried to fix it at teamspeak options but i just dont know what rly could be no voice sound at all...
Make sure you have a proper playback device selected in the TeamSpeak options (settings -> options -> playback).
Make sure that TeamSpeak is not muted or very low in the Windows sound mixer (left click speaker icon in systray -> mixer)
Make sure that the playback volume is not set very low in TeamSpeak (setting -> options -> playback -> top slider should be around 0dB)
Well in that case make sure that you got a proper capture device selected in the options (settings -> options -> capture).
And make sure that in the Windows sound options the capture device you are using is not muted (right click speaker icon in tray -> recording devices -> select device -> properties -> levels).
Also make sure that you have a capture profile selected in TeamSpeak when you are connected (self -> capture profile should have one selected).
I Tried everything and still not everything u write.
Now even on Mumble,Ventrilo its not working also.
But on Skype Microhpone Works.
Ok, skype, the magic word.
If you are using Skype, be sure that:
in Skype Tools --> Options --> Sound --> you have to Uncheck "Automatically adjust microphone settings"
http://forum.teamspeak.com/showthrea...ighlight=skype
I dont use them at same time,i mean i did before but now even when i talk on skype and im on ts still dont works on teamspeka...there is blinking my light blue signal like im talking but no sound of micro to other ppl in there...
Its Unchecked...
Rly i have no clue whats going on....It just come from nothing...i turn on pc and it just doesnt work
Im sorry for double post i fix it.
Thanks to PotaBlova and Teamspeak Team who helped me to try figure out whats wrong.U're the best
Happy New Year best wishes!
