Results 1 to 6 of 6
    December 2010
    Prague
    14
    Solved Some guide how to enable Opus codec ?
    Hi, do you have some guide or suggestions, how to enable Opus codec?
    I can't click on it if I want to set it for some channel.
    Thanks for your help.
    18,513
    You need server 3.0.7 for that feature. Because the old server does not have the permissions to enable it.
    It was said here http://forum.teamspeak.com/showthrea...-Client-3-0-10
    December 2010
    Prague
    14
    I think that I have the last versions.
    SERVER is " 3.0.7-beta (24.12.2012 8:48:14) on Windows "
    and
    CLIENT is " 3.0.10 (7.12.2012 10:41:57) on Windows "
    I don't know why it is not working.
    btw. If I click to check for update it writes that:
    Previous update session for v. 1357824174 found
    Starting update process
    Download / check product ini
    Downloading client_win64.ini
    There are no (more) known working mirrors available
    Update cancelled
    But I am already on version " 3.0.10 ".
    Is there something wrong?
    18,513
    Are you sure that the permission b_channel_create_modify_with_codec_opusvoice and b_channel_create_modify_with_codec_opusmusic is enabled in your serer group.
    December 2010
    Prague
    14
    Thank You dante, it is solution. Now it works fine.
    May 2007
    Eastern NC
    1,801
    That should have been set when the server was updated via the i_group_auto_update_type permission. If you have a database from a really old server beta (I think this feature was initially added in 3.0.0-beta21 30 March 2010) you needed to update these manually before they would start working.
  1. [Not Supported] Problems with codec opus music
    By lucky40990 in forum Client Support
    Last Post: November 6th, 2017, 10:11 AM
  2. [Rejected] Opus 1.1, Opus Voice Stereo, Server-side smiles
    By KIDINK^ in forum Suggestions and Feedback
    Last Post: October 27th, 2014, 11:11 AM
  3. User Permissions and the Opus Audio Codec
    By theckman in forum Permission System
    Last Post: January 18th, 2014, 11:51 PM
  4. Opus Codec
    By RadarGaming in forum General Questions
    Last Post: September 7th, 2013, 01:47 PM
  5. What happened to the Opus Music codec? Quality is awful now.
    By Morthawt in forum General Questions
    Last Post: April 9th, 2013, 05:13 AM
