Results 1 to 6 of 6
    March 2011
    France
    8
    Big crash problem
    I have a big problem on my fresh TS3 server.
    When the clients connected at the same time exceeds ~10-15 clients, some clients crashs at a random time, at the same time for exactly 30 seconds before reconnecting, and sometimes they crash to reconnect immediately (their internet connection works perfectly). The server works perfectly, i have reinstall many times teamspeak 3 and os (debian 5). I tried 32 and 64 bit. It is always the same. I recovered database to test locally on Windows, and there it works ... I really do not understand... thanks for help
    6,079
    firewall considering traffic by teamspeak as flooding, which causes the clients to drop.
    If you linux machine has multiple IP addresses this can also happen, you should force TeamSpeak to use one specific IP address by using the voice_ip parameter. See serverquickstart.txt section 6 in the docs folder of your server installation.
    March 2011
    France
    8
    Thanks for reply but now it show this error in logs :
    loading VirtualServer(1) failed to start, error: unable to bind network port
    6,079
    because the port that server is configured to use is already being used by another application.
    Make sure the server is not already running.
    March 2011
    France
    8
    No server running, I have reboot vps before (i've tried 3 times)
    The command that i made :
    ./ts3server_minimal_runscript.sh voice_ip *my server ip*
    6,079
    well something is already using the network port TeamSpeak is configured to use. Check the log files to see which port TeamSpeak attempted to use and then check which application uses said port on the system.
  1. [Resolved] teamspeak 3 application android crash crash crash
    By hycksou in forum Android
    Last Post: July 5th, 2017, 07:05 PM
  2. Crash i beliove its a mic problem.
    By lonewolf9567 in forum Windows
    Last Post: April 17th, 2010, 03:48 PM
