Results 1 to 7 of 7
    March 2013
    Solved How to sort groups
    You see that Staff is number 9 and Guest is number how I can put Staff above Guest?
    2,698
    Quote Originally Posted by Daniel123 View Post
    Your permission is:
    i_group_sort_id Group Sort ID
    If set, this value defines the sort order of the groups and its icons in the permission system. If unset or zero, the group ID is taken to determine the sort order.
    March 2013
    Your permission is:
    I did not understand you, what should I do here?
    2,698
    Ok, I see. You have to select the advanced permission system:
    Settings ---> Options --> Application --> "Misc" section --> Activate "Advanced permission system" --> Button "Accept"
    Then go again to Permissions --> Channel Groups --> In "Filter" indicate 'sort' and then you'll see the permission and then indicate a value for each group and the list will be shown ordered according to that value.
    Once finished... you can deactivate the advanced permission system.
    March 2013
    thank you very much, it work
    August 2013
    how do i fix this
    how do i fix this so its
Name:	SERVER GROUPS ID.png
    how do i fix this so it like this
    Owner (1)
    Server Admin (2)
    Server Mod (3)
    its just like giveing me ocd on it thanks any help is appreciated xD
    2,698
    Quote Originally Posted by tysonphilip123 View Post
    Owner (1)
    Server Admin (2)
    Server Mod (3)
    That number is an inner and unique value, not editable.
    If you want to sort the groups, you have a permission for that, see this thread:
    http://forum.teamspeak.com/showthrea..._group_sort_id
  1. [Resolved] How to: Sort Groups/Users
    By auroxx in forum Permission System
    Last Post: May 31st, 2019, 08:18 PM
  2. [Solved - on todo] Sort Order in Server/Channel Groups
    By -{HGH}-GEN.Skylab in forum Permission System
    Last Post: October 28th, 2013, 02:11 PM
  3. [Resolved] How to: Sort Groups/Users
    By auroxx in forum General Questions
    Last Post: August 3rd, 2011, 10:07 AM
  4. Sort Server and Channel Groups DB ID
    By Col_Crunch in forum Permission System
    Last Post: July 27th, 2011, 06:35 PM
  5. [Suggestion] Ability to arrange/sort groups order
    By -{HGH}-GEN.Skylab in forum Suggestions and Feedback
    Last Post: March 29th, 2010, 09:28 PM
