Results 1 to 5 of 5
Thread: TSDNS problem
    Poland
    83
    TSDNS problem
    I want to change user who runs tsdns. I have removed /dev/shm/*, changed owner:group for files but when I run then it does not load entries from config.
    Scanned tsdns_settings.ini, number of entries: 0
    When I starts with old user then it works.
    Scanned tsdns_settings.ini, number of entries: 120
    6,079
    Make sure the user you intend to run the tsdns server as has access to the tsdns_settings.ini
    January 2013
    Kazan City
    I also have a problem. Once connected, the client in the log warning
    14.03.2013 10:17:51 StringHelp Warning Invalid UTF-8 string passed to function, returning as-is
    14.03.2013 10:17:51 Warning getaddrinfo error: ������ - ��� ��������� ������, ����������� �� ����� ���������� ����� ����, � ����������, ��� ��������� ������ �� ������� ������ �� ������������ �������.
    6,079
    @ighostx:
    Maybe your tsdns_settings.ini is corrupted, redo it from scratch. If it contains UTF-8 characters make sure the file is saved with UTF8 encoding.
    Poland
    83
    I have found a solution. When I start the tsdns with command /home/tsdns/tsdnsserver_linux_amd64 then it does not load the entries. But when I change dir and run directly ./tsdnsserver_linux_amd64 then it works.
  1. TSDNS problem
    By Andevi97 in forum Windows
    Last Post: September 22nd, 2014, 05:49 PM
  2. Big Problem, TSDNS
    By Tryton in forum Server Support
    Last Post: December 2nd, 2013, 02:15 PM
  3. Replies: 0
    Last Post: August 4th, 2013, 01:52 PM
  4. TSDNS problem
    By Tiranous in forum Client Support
    Last Post: July 21st, 2011, 12:53 AM
  5. TSDNS problem
    By erikz in forum Linux / FreeBSD
    Last Post: June 15th, 2011, 07:52 PM
