Results 1 to 3 of 3
    March 2013
    Fresno
    Problem with /dev/shm
    FreeBSD *.*.* 8.2-RELEASE FreeBSD 8.2-RELEASE #0: Fri Feb 18 02:24:46 UTC 2011 [email protected]:/usr/obj/usr/src/sys/GENERIC i386
    I have a Few Problems Here is my Log File.
    The Command I use to activate the Server.
    Command: ./ts3server_minimal_runscript.sh inifile=ts3server.ini
    2013-03-29 21:23:18.275507|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.7 (2013-03-02 06:03:25)
    2013-03-29 21:23:18.960306|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2013-03-29 21:23:19.382987|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2013-03-29 21:23:19.493511|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2013-03-29 21:23:20.455573|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2013-03-29 21:23:20.456318|ERROR   |Accounting    |   | failed to register local accounting service
    2013-03-29 21:23:20.456590|ERROR   |ServerLibPriv |   | Server() error while starting servermanager, error: instance check error
    Now I have the Licensekey.dat in the folder which the teamspeak server runs.
    My ini File Below.
    machine_id=
    default_voice_port=9987
    voice_ip=6.1.1.1
    licensepath=/usr/home/User/teamspeak
    filetransfer_port=30033
    filetransfer_ip=6.1.1.1
    query_port=10011
    query_ip=6.1.1.1
    dbplugin=ts3db_sqlite3
    dbpluginparameter=
    dbsqlpath=sql/
    dbsqlcreatepath=create_mysql/
    logpath=logs
    logquerycommands=0
    my Licensekey.dat
    Company name : My Name
    address      : Address
    zipcode      : Zip
    city         : Fresno
    country      : U.S.A.
    phone        : +1 111 222 3333
    fax          :
    sales contact: Bioblaze ([email protected])
    tech contact : Bioblaze ([email protected])
    type         : Nonprofit
    start date   : Thu Feb 31 00:00:00 2013 <-- I have this legitly, I only received a Email with the Hash Code below
    end date     : Fri Nov 30 00:00:00 2014 <-- I have this legitly, I only received a Email with the Hash Code below
    max. virtual servers: 10
    max. slots   : 512
    description  : TeamSpeak 3 Non-Profit License
    Q29tcGFueSBuYW1lIDogUmFuZG9scGg.......
    Now I have a few problems
    First I dont have /dev/shm
    I dont know how to make it work, now I tried adding it to my fstab, but it doesnt show up in df -h
    as shown
    [[email protected] /usr/home/User]# df -h
    Filesystem     Size    Used   Avail Capacity  Mounted on
    /dev/ad0s1a    989M    176M    734M    19%    /
    devfs          1.0K    1.0K      0B   100%    /dev
    /dev/ad0s1e    989M    2.7M    907M     0%    /tmp
    /dev/ad0s1f     25G    6.7G     16G    30%    /usr
    /dev/ad0s1d    5.8G    737M    4.6G    14%    /var
    /dev/ad0s2     108G     30G     69G    30%    /usr/home
    linprocfs      4.0K    4.0K      0B   100%    /proc
    linprocfs      4.0K    4.0K      0B   100%    /usr/compat/linux/proc
    linsysfs       4.0K    4.0K      0B   100%    /usr/compat/linux/sys
    devfs          1.0K    1.0K      0B   100%    /usr/compat/linux/dev
    linprocfs      4.0K    4.0K      0B   100%    /usr/local/gentoo-stage3/proc
    linsysfs       4.0K    4.0K      0B   100%    /usr/local/gentoo-stage3/sys
    devfs          1.0K    1.0K      0B   100%    /usr/local/gentoo-stage3/dev
    devfs          1.0K    1.0K      0B   100%    /var/named/dev
    Now I trie to Mound it, but it doesnt work, I trie to create the directory and it doesnt work.
    Anyone have this Problem, I own the Server. I Colo It. But im having some problems with this. Lulz. It only happened after my first restart.
    April 2011
    1,266
    If the license is in the same directory as the server binary you can leave the license path blank in the ini-file. Also I'm not sure if that value should have a trailing "/", if used. The mount point "/dev/shm" is only needed if no valid license is presented. Then shared memory is used to ensure that only one server instance is running. Make sure the serverkey.dat is owned and read-/writeable by the user account running teamspeak.
    6,080
    It's the licensekey.dat that needs to be read and writable by the user running the server.
  1. Serveredit problem, and Admin user problem.
    By 0wn3r in forum Linux / FreeBSD
    Last Post: December 23rd, 2018, 01:09 PM
