Results 1 to 13 of 13
    March 2013
    8
    npl error: |ERROR |Accounting | | too many virtualservers running, shutting down!
    so we got a new ip and a new root server and teamspeak already changed the ip int the license but i'm still getting this error: |ERROR |Accounting | | too many virtualservers running, shutting down!
    but the old root isn't even running anymore
    can somebody help pls
    6,079
    Either more servers than allowed by the license are attempting to start when you load the instance, or the license is still in use elsewhere and running servers.
    check the server logs, it should tell you how many servers it tries to start up.
    March 2013
    8
    we have another ts3 server rurnning on the rootserver but it hasn't got a license so it's just the 32 slot version
    2nd the license was updated to our new ip through ts3-support
    also here is waht the log says
    2013-04-17 10:12:25.896147|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.7.1 (2013-03-18 10:56:27)
    2013-04-17 10:12:25.896381|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2013-04-17 10:12:25.896402|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2013-04-17 10:12:25.896576|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2013-04-17 10:12:25.931377|INFO |SQL | | database updated successfully to revision: 21
    2013-04-17 10:12:25.934138|INFO |ServerLibPriv | | updated server query admin password
    2013-04-17 10:12:25.934309|INFO |DatabaseQuery | | database busy, waiting for finishing index tasks, may take some time!
    2013-04-17 10:13:00.994850|INFO |SQL | | updated permissions to version 16
    2013-04-17 10:13:01.013756|INFO |SQL | | updated permissions to version 17
    2013-04-17 10:13:01.235406|INFO |Accounting | | Licensing Information
    2013-04-17 10:13:01.235448|INFO |Accounting | | type : Non-profit
    2013-04-17 10:13:01.235539|INFO |Accounting | | starting date : Sun Jan 20 00:00:00 2013
    2013-04-17 10:13:01.235565|INFO |Accounting | | ending date : Wed Jul 24 00:00:00 2013
    2013-04-17 10:13:01.235586|INFO |Accounting | | max virtualservers: 10
    2013-04-17 10:13:01.235597|INFO |Accounting | | max slots : 512
    2013-04-17 10:13:01.242741|INFO |FileManager | | listening on 84.200.5.122:30033
    2013-04-17 10:13:01.247171|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1, 82.211.2.219, 87.118.120.192,
    2013-04-17 10:13:01.281018|INFO |Query | | listening on 84.200.5.122:10011
    2013-04-17 10:32:05.703270|INFO |VirtualSvrMgr | | startServer() VirtualServer(1) started
    2013-04-17 11:13:04.280518|ERROR |Accounting | | too many virtualservers running, shutting down!
    2013-04-17 13:07:13.838036|INFO |VirtualSvrMgr | | startServer() VirtualServer(1) started
    2013-04-17 13:13:10.384176|ERROR |Accounting | | too many virtualservers running, shutting down!
    2013-04-17 13:25:02.770971|INFO |ServerMain | | Received signal SIGTERM, shutting down.
    6,079
    you can try and stop the server running without a license.
    March 2013
    8
    i deleted the other server, but now the ts can't find a valid license
    2013-04-17 13:25:39.814374|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.7.1 (2013-03-18 10:56:27)
    2013-04-17 13:25:40.014332|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2013-04-17 13:25:40.015129|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2013-04-17 13:25:40.056578|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2013-04-17 13:25:40.204053|INFO |ServerLibPriv | | updated server query admin password
    2013-04-17 13:25:40.304710|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2013-04-17 13:25:40.388220|INFO |FileManager | | listening on 84.200.5.122:30033
    2013-04-17 13:25:40.408146|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1, 82.211.2.219, 87.118.120.192,
    2013-04-17 13:25:40.408494|INFO |Query | | listening on 84.200.5.122:10011
    2013-04-17 13:30:11.129181|INFO |VirtualSvrMgr | | startServer() VirtualServer(1) started
    2013-04-18 13:56:48.589262|INFO |VirtualSvrMgr | | startServer() VirtualServer(1) started
    and still uses the 32 slots
    Texas
    745
    Just to be safe:
    1. Stop ALL running teamspeak servers
    2. Verify that licensekey.dat is in the root folder of the licensed server (same folder as the binary)
    3. Start ONLY the licensed server.
    4. Post logs if further issues arise.
    If I remember correctly, sometimes the license server takes some time to refresh so if the IP changed it may not have registered that the old one no longer exists.
    March 2013
    8
    i did as you said but still the same error as above
    also it seems that the server can't even find the licensekey.dat
    Texas
    745
    When you open licensekey.dat is there any humn readable text? It could be that the file is corrupt. That happens with certain mail clients.
    March 2013
    8
    yeah it's all right with the licensekey.dat
    it's also in the right folder on the server but the ts3 can't find the license
    Texas
    745
    what OS are you using?
    March 2013
    8
    the server is running debian 6.0
    Texas
    745
    does your start script launch teamspeak in the binary directory
    March 2013
    8
    solved the problem
    there were other servers (without license) running in the background
    rootsupport solved the problem
    can be closed
  1. [Resolved] too many virtualservers running, shutting down!
    By hellsing6537 in forum Server Support
    Last Post: February 4th, 2015, 06:31 PM
  2. Replies: 1
    Last Post: December 2nd, 2014, 03:07 PM
  3. too many virtualservers running, shutting down!
    By BL3ND in forum Server Support
    Last Post: April 23rd, 2014, 01:30 PM
  4. Accounting | unknown error, shutting down!
    By ThiefMaster in forum Linux / FreeBSD
    Last Post: September 20th, 2010, 07:48 PM
  5. Too many virtualservers running, shutting down!
    By Samifighter in forum Linux / FreeBSD
    Last Post: February 13th, 2010, 03:20 PM
