Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 69
  1. #16
    18,151
    Your server can not contact accounting.teamspeak.com
    This will shutdown your server.
    Please fix your network and open the needed ports. (do not try to ping accounting.teamspeak.com, this will never work)
    https://support.teamspeakusa.com/ind...ticle/View/44/
  2. #17
    November 2015
    All ports on the server have a default unlocked.
    netstat -tulpn
    Active Internet connections (only servers)
    Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 621/sshd
    tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 632/exim4
    tcp 0 0 0.0.0.0:10011 0.0.0.0:* LISTEN 31527/ts3server_lin
    tcp 0 0 0.0.0.0:30033 0.0.0.0:* LISTEN 31527/ts3server_lin
    tcp6 0 0 :::22 :::* LISTEN 621/sshd
    tcp6 0 0 ::1:25 :::* LISTEN 632/exim4
    udp 0 0 0.0.0.0:9987 0.0.0.0:* 31527/ts3server_lin
    I explain that I have no blocked ports. Hosting gives unlocked account by default on all ports.
    I do not have a firewall or iptables.
  3. #18
    18,151
    In addition to that, packets originating from or sent to accounting.teamspeak.com:2008 (TCP)
    Read text above
    Not blocking, does not mean it is opened by default. And it's not listed in your post either.
  4. #19
    November 2015
    Still not working.
    iptables -L
    Chain INPUT (policy ACCEPT)
    target prot opt source destination
    ACCEPT tcp -- anywhere anywhere tcp dpt:10011
    ACCEPT tcp -- anywhere anywhere tcp dpt:41144
    ACCEPT tcp -- anywhere anywhere tcp dpt:30033
    ACCEPT udp -- anywhere anywhere udp dpt:9987
    Chain FORWARD (policy ACCEPT)
    Chain OUTPUT (policy ACCEPT)
    ACCEPT tcp -- anywhere anywhere tcp dpt:2008
    ACCEPT udp -- anywhere anywhere udp dpt:2010
    I installed iptables. I added to it the rules, rebooted the server. Still not working.
    Can you give more precise suggestions for debian?
    It is getting more and more tiring.
  5. #20
    November 2015
    I still do not get a response.
    Please do not refer me to a FAQ in which it is written only what is required TS3 server.
    Please help solve the problem.
    Support TS3 also refers me to the subjects in which there is no solution or guidance.
  6. #21
    288
    Because of your problem, can you please give an overview of your firewall-rules.
    In detail, the rules for the OUTPUT-chain will be relevant to check.
  7. #22
    November 2015
    Angry
    or two posts above have not written rules that are in iptables?
    When I had no firewall on the server it was also a problem.
    Now installed iptables added a rule, the problem is still there.
  8. #23
    September 2014
    Exclamation Server stops every 3 hours.
    Good day to all.
    I'm having problems with my server, it stops every 3 or 2 hours the server and I have to use the command to start it.
    "./ts3server_starscrip.sh start"
    Appreciate your support
    Thank,
  9. #24
    February 2012
    575
    Your server isn't able to contact the Teamspeak licensing server to verify your license, so it shuts down itself after a grace period.
    Fix: remove the firewall rule that blocks the connection to the licensing server.
  10. #25
    April 2015
    153
    TS3ANetwork::Send failed error: 111
    my instance log looks like this:
    UDPConnection::send failed to update target ip
    TS3ANetwork::Connect failed error: 22
    My ts3server ini looks like this:
    machine_id=
    default_voice_port=9987
    voice_ip=0.0.0.0
    licensepath=
    filetransfer_port=30033
    filetransfer_ip=0.0.0.0
    query_port=10011
    query_ip=0.0.0.0
    Any help ?
  11. #26
    August 2016
    9
    TeamSpeak Accounting - Can't use NPL
    Heys guys, our community has just received it's Non Profit License. We have set up the new server with all 30 groups and 200 channels including all permissions and the server runs without problem. Unlicensed with 32 slots.
    As soon as I restart with the NPL licensekey.dat the server (obviously) tries to validate this license. After 2 hours it's shutting down.
    2016-08-23 23:12:58.202055|INFO    |ServerLibPriv |   |TeamSpeak 3 Server 3.0.13.3 (2016-08-18 16:46:43)
    2016-08-23 23:12:58.202205|INFO    |ServerLibPriv |   |SystemInformation: Linux 3.13.0-042stab111.12 #1 SMP Thu Sep 17 11:38:20 MSK 2015 x86_64 Binary: 64bit
    2016-08-23 23:12:58.202241|INFO    |ServerLibPriv |   |Using hardware aes
    2016-08-23 23:12:58.203014|INFO    |DatabaseQuery |   |dbPlugin name:    SQLite3 plugin, Version 3, (c)TeamSpeak Systems GmbH
    2016-08-23 23:12:58.203066|INFO    |DatabaseQuery |   |dbPlugin version: 3.11.1
    2016-08-23 23:12:58.203307|INFO    |DatabaseQuery |   |checking database integrity (may take a while)
    2016-08-23 23:12:58.236412|ERROR   |              |   |TS3ANetwork::Connect failed error: 111
    2016-08-23 23:12:58.236450|ERROR   |              |   |Unable to connect to primary address, trying secondary
    2016-08-23 23:12:58.236586|ERROR   |              |   |TS3ANetwork::Connect failed error: 111
    2016-08-23 23:12:58.238629|ERROR   |Accounting    |   |Unable to connect to accounting server
    2016-08-23 23:12:58.238657|INFO    |Accounting    |   |Licensing Information
    2016-08-23 23:12:58.238674|INFO    |Accounting    |   |type              : Non-profit
    2016-08-23 23:12:58.238695|INFO    |Accounting    |   |starting date     : Mon Aug 22 00:00:00 2016
    2016-08-23 23:12:58.238710|INFO    |Accounting    |   |ending date       : Wed Feb 22 00:00:00 2017
    2016-08-23 23:12:58.238723|INFO    |Accounting    |   |max virtualservers: 2
    2016-08-23 23:12:58.238736|INFO    |Accounting    |   |max slots         : 512
    2016-08-23 23:12:59.236330|INFO    |              |   |Puzzle precompute time: 974
    2016-08-23 23:12:59.236818|INFO    |FileManager   |   |listening on 0.0.0.0:30033, :::30033
    2016-08-23 23:12:59.259727|INFO    |CIDRManager   |   |updated query_ip_whitelist ips: 127.0.0.1/32,
    2016-08-23 23:12:59.259988|INFO    |Query         |   |listening on 0.0.0.0:10011, :::10011
    2016-08-23 23:12:59.352244|ERROR   |              |   |TS3ANetwork::Connect failed error: 111
    2016-08-23 23:12:59.352332|ERROR   |              |   |Unable to connect to primary address, trying secondary
    2016-08-23 23:12:59.352466|ERROR   |              |   |TS3ANetwork::Connect failed error: 111
    This is what clients see:
    <22:58:52> Server has been shut down: Server Shutdown!
    <22:58:52> Disconnected from server
    The server is running on a VPS by German hoster STRATO: https://www.strato.de/linux-vserver/
    2 vCores
    Up to 4 gigs of RAM (2 guaranteed)
    It is running Ubuntu 14.04.5 LTS with Parallels Plesk. I've tried whitelisting TeamSpeak and turning off the Plesk firewall completely, but I was still not able to fix the problem.
    What can I do to fix the TSANetwork problem? I've tried most of the things I found on the internet thought I wasn't able to fix this problem
  12. #27
    August 2016
    9
    Teamspeak Team, do not merge this thread with mine.
    The problem is not being fixed by anything in here.
    There is NO firewall active on the server and it is still not able to connect.
    I have just put my licensekey.dat on my local computer (e. g. an NPL on an IP which was not given) and it works for over 10 hours now without shutdown. So what the fuck is the problem with your linux server software?
  13. #28
    18,151
    Quote Originally Posted by cat24max View Post
    But your explanation is exactly what this thread is about.
    Your machine can't contact our accounting server. This is needed to use a license in the server.
    Open port 2010 TCP and make sure your machine can contact accounting.teamspeak.com
    This is explained in post #3
    Not reading our replies will not solve anything :/
  14. #29
    September 2016
    7
    My server will stop alone
    Already desoler for my English I use a translator.
    So I have a big issue with my TeamSpeak, I'm on it with friends and go to speak, when all of a sudden the server what cut for no reason.
    My TeamSpeak server and a debian 8 64bit.
    I download files from the TeamSpeak website and use a license NPL.
    In my logs I have this
    PHP Code:
    2016-09-15 12:14:18.818147|INFO    |VirtualServerBase|1  |stopped
    Thank's you
  15. #30
    18,151
    Please check server log 0 (must have same timestamp as shown log 1).
  1. TS3ANetwork::Connect failed error: 22
    By altiris in forum Linux / FreeBSD
    Last Post: April 1st, 2014, 11:19 PM
  2. TS3ANetwork::Connect failed error: 113
    By Egbert101 in forum Server Support
    Last Post: May 15th, 2013, 10:28 AM
  3. TS3ANetwork::Connect failed error: 110
    By Crunk_Bass in forum Linux / FreeBSD
    Last Post: August 2nd, 2011, 03:27 PM
  4. TS3ANetwork::Connect failed error: 113
    By DRUG_ADDICT in forum Linux / FreeBSD
    Last Post: April 18th, 2011, 01:28 PM
