Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 69
  1. #31
    September 2016
    7
    Please check server log 0 (must have same timestamp as shown log 1).
    I have this in the server log:
    9/19/2016 9:19:59 VirtualServer Info listening on 0.0.0.0:9987, 9987 :::
    My TeamSpeak server does not have the same time as me VPS
  2. #32
    18,513
    You are showing Server log 1 again and not the requested 0.
  3. #33
    September 2016
    7
    Or find it?
  4. #34
    18,513
    Find what?
    Edit
    Name:  log differences.png
    You also need to check and the log 0 which has the same timestamp of server log 1 (where the shutdown happened)
  5. #35
    September 2016
    7
    Find what?
    Server log 0
  6. #36
    18,513
    It's in the same log folder. See my post above. I made an edit on it.
  7. #37
    September 2016
    7
    2016-09-19 10:02:33.921714|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.0.13.4 (2016-08-29 12:39:04)
    2016-09-19 10:02:33.922503|INFO |ServerLibPriv | |SystemInformation: Linux 2.6.32-openvz-042stab113.11-amd64 #1 SMP Fri Dec 18 17:40:41 MSK 2015 x86_64 Binary: 64bit
    2016-09-19 10:02:33.922536|WARNING |ServerLibPriv | |The system locale is set to "C" this can cause unexpected behavior. We advice you to repair your locale!
    2016-09-19 10:02:33.922554|INFO |ServerLibPriv | |Using hardware aes
    2016-09-19 10:02:33.929225|INFO |DatabaseQuery | |dbPlugin name: SQLite3 plugin, Version 3, (c)TeamSpeak Systems GmbH
    2016-09-19 10:02:33.929360|INFO |DatabaseQuery | |dbPlugin version: 3.11.1
    2016-09-19 10:02:33.936006|INFO |DatabaseQuery | |checking database integrity (may take a while)
    2016-09-19 10:02:33.961256|ERROR | | |TS3ANetwork::Connect failed error: 111
    2016-09-19 10:02:33.961315|ERROR | | |Unable to connect to primary address, trying secondary
    2016-09-19 10:02:33.961442|ERROR | | |TS3ANetwork::Connect failed error: 111
    2016-09-19 10:02:33.963864|ERROR |Accounting | |Unable to connect to accounting server
    2016-09-19 10:02:33.963900|INFO |Accounting | |Licensing Information
    2016-09-19 10:02:33.963912|INFO |Accounting | |type : Non-profit
    2016-09-19 10:02:33.963928|INFO |Accounting | |starting date : Wed Sep 14 00:00:00 2016
    2016-09-19 10:02:33.963940|INFO |Accounting | |ending date : Tue Mar 14 00:00:00 2017
    2016-09-19 10:02:33.963955|INFO |Accounting | |max virtualservers: 2
    2016-09-19 10:02:33.963969|INFO |Accounting | |max slots : 512
    2016-09-19 10:02:35.484453|INFO | | |Puzzle precompute time: 1491
    2016-09-19 10:02:35.485090|INFO |FileManager | |listening on 0.0.0.0:30033, :::30033
    2016-09-19 10:02:35.512110|INFO |CIDRManager | |updated query_ip_whitelist ips: 127.0.0.1/32, ::1/128,
    2016-09-19 10:02:35.512350|INFO |Query | |listening on 0.0.0.0:10011, :::10011
    2016-09-19 10:02:35.570840|ERROR | | |TS3ANetwork::Connect failed error: 111
    2016-09-19 10:02:35.570901|ERROR | | |Unable to connect to primary address, trying secondary
    2016-09-19 10:02:35.571005|ERROR | | |TS3ANetwork::Connect failed error: 111
  8. #38
    18,513
    The server shuts down, because it is unable to contact our accounting server.
    the error code is directly from the system. 111 usually is connection refused. See this article for the ports.
    Open the needed port 2008 TCP and allow the server to connect to accounting.teamspeak.com
  9. #39
    September 2016
    7
    Port open always the same
    Please help me ty
  10. #40
    18,513
    Re private message: Yes the server will shutdown after 2 hours, when the license could not be validated.
    This is a wanted behavior.
    Please fix what i answered in post #35 or chris did in several posts here.
  11. #41
    September 2016
    7
    Problem solved I add this in my host file follows:
    128.65.210.118 accounting.teamspeak.com
    Because by causing a traceroute I perceive more he read me accounting.teamspeak.com as local
  12. #42
    18,513
    I would not count on this fix. I would remove any routings to accounting.teamspeak.com and let your DNS server do his job.
    Changing the data center will also change the IP and this happened once or twice already.
    //Edit
    See here http://forum.teamspeak.com/threads/4...o-62-146-63-84
  13. #43
    October 2016
    I have a problem when i put my NP Liscence on my teamspeak, in fact the server crash every 2 hours.
    All ports are opened for TeamSpeak.
    Logs Teamspeak :
    2016-10-26 01:31:56.901185|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.0.13.4 (2016-08-29 12:39:04)
    2016-10-26 01:31:56.905553|INFO |ServerLibPriv | |SystemInformation: Linux 3.2.0-4-amd64 #1 SMP Debian 3.2.82-1 x86_64 Binary: 64bit
    2016-10-26 01:31:56.907592|INFO |DatabaseQuery | |dbPlugin name: SQLite3 plugin, Version 3, (c)TeamSpeak Systems GmbH
    2016-10-26 01:31:56.907688|INFO |DatabaseQuery | |dbPlugin version: 3.11.1
    2016-10-26 01:31:56.908185|INFO |DatabaseQuery | |checking database integrity (may take a while)
    2016-10-26 01:31:56.984728|ERROR | | |TS3ANetwork::Connect failed error: 111
    2016-10-26 01:31:56.984849|ERROR | | |Unable to connect to primary address, trying secondary
    2016-10-26 01:31:57.132415|INFO |Accounting | |Licensing Information
    2016-10-26 01:31:57.132518|INFO |Accounting | |type : Non-profit
    2016-10-26 01:31:57.132603|INFO |Accounting | |starting date : Mon Oct 24 00:00:00 2016
    2016-10-26 01:31:57.132672|INFO |Accounting | |ending date : Mon Apr 24 00:00:00 2017
    2016-10-26 01:31:57.132729|INFO |Accounting | |max virtualservers: 2
    2016-10-26 01:31:57.132778|INFO |Accounting | |max slots : 512
    2016-10-26 01:32:03.691658|INFO | | |Puzzle precompute time: 6388
    2016-10-26 01:32:03.692615|INFO |FileManager | |listening on 0.0.0.0:30033, :::30033
    2016-10-26 01:32:03.759301|INFO |CIDRManager | |updated query_ip_whitelist ips: 127.0.0.1/32, ::1/128,
    2016-10-26 01:32:03.759973|INFO |Query | |listening on 0.0.0.0:10011, :::10011
    2016-10-26 01:32:03.855765|ERROR | | |TS3ANetwork::Connect failed error: 111
    2016-10-26 01:32:03.855884|ERROR | | |Unable to connect to primary address, trying secondary
    What the problem ? I have search on the web for the code 111 but no lot of people got that.
    Can you help me ?
    Thanks for your answers,
    Gheeks
    Anybody have the solution ?
    Please support help me thanks :x
    UP Please i need help
    Last edited by dante696; October 31st, 2016 at 10:05 AM. Reason: merged 2 threads and 3 posts, port(s) are closed or wrong forwarded
  14. #44
    April 2011
    1,266
    There is NO server crash. There is only an intended server shutdown because the server can't verify it's license. Enable your server to connect to teamspeak's licensing servers and all is fine. And don't call something a crash which isn't any.
  15. #45
    October 2016
    It is in hosts file ? ( Debian 7.11 amd64 )
    My host file :
    # TEAMSPEAK LISCENCE
    127.0.0.1 accounting.teamspeak.com
    127.0.0.1 backupaccounting.teamspeak.com
    127.0.0.1 ipcheck.teamspeak.com
    Iptables all ports requiere opened.
  1. TS3ANetwork::Connect failed error: 22
    By altiris in forum Linux / FreeBSD
    Last Post: April 2nd, 2014, 12:19 AM
  2. TS3ANetwork::Connect failed error: 113
    By Egbert101 in forum Server Support
    Last Post: May 15th, 2013, 11:28 AM
  3. TS3ANetwork::Connect failed error: 110
    By Crunk_Bass in forum Linux / FreeBSD
    Last Post: August 2nd, 2011, 04:27 PM
  4. TS3ANetwork::Connect failed error: 113
    By DRUG_ADDICT in forum Linux / FreeBSD
    Last Post: April 18th, 2011, 02:28 PM
