Results 1 to 2 of 2
    July 2013
    TS3 issue-Mic disabled when PTT
    Hey all-
    Ok...I have been using ts3 without issue for the past 2 years. A few days ago, I had to exchange my G35 headset for a new one (earpieces broke and I had bought the replacement plan). Same headset, plug it in and when I hit my PTT, it kept giving me spam warning and told me to try again in a few minutes. I un and re installed my g35 software and Ts3 with no luck.
    My PTT was caps lock. I know that is a no no, but I never had an issue with it prior. So I switched it to TAB and it began to work. However, if I ever mistakenly hit caps lock, I lose sound in my headset and it reads "microphone disabled". This also seems to disable my headset, as I get intermittent sound until I restart TS3.
    This is obviously not suppose to work like this and I would like to fix it. I searched the forums and found similar problems, but the solutions were not what I needed.
    any help would be appreciated.
    Thanks!
    6,079
    Make sure you don't have any hotkey set on Caps Lock in TeamSpeak. Also check your logitech software / other macro software you might have installed and either remove them or remove your keybinds on caps lock.
  1. Speakers/Headphones Disabled Microphone Disabled
    By love9509 in forum Client Support
    Last Post: January 2nd, 2016, 06:48 AM
  2. Replies: 1
    Last Post: June 24th, 2012, 08:50 PM
  3. MIC disabled
    By TCBob in forum Windows
    Last Post: September 6th, 2010, 12:50 AM
  4. why is it disabled
    By Enoche in forum Client Support
    Last Post: June 9th, 2010, 07:26 AM
  5. why is it disabled
    By Enoche in forum Bug Reports [EN/DE]
