Results 1 to 8 of 8
    May 2013
    Let TS use TCP instead of UDP
    Hello everyone,
    this is my little issue. I've installed TS3 server on a linux server that give me some problems with UDP ports. I've found in this doc ( http://www.teamspeak.com/?page=blog&p=3 ) the following quote:
    Although the UDP protocol is a superior choice for real time voice communication, TeamSpeak 3 will also provide the option of using TCP instead of UDP. Support for TCP connectivity is particularly useful for circumstances where people need to use proxies, or where UDP is completely blocked due to corporate firewalls, etc.
    Who can help me to setup TS3 to use TCP connection instead of UDP?
    Thanks very much!
    June 2012
    Portugal
    317
    I think that is only available to custom coded servers.
    Your best choice would be: Change host OR use a VPN trough TCP (that has the ability to open ports) but the ping would suffer alot...
    December 2004
    RF
    3,006
    Quote Originally Posted by 000HR000 View Post
    Hello everyone,
    Thanks very much!
    Specifically, which problem?... And what is this server, in fact?
    Catalunya
    2,350
    If I remember correctly, it was discarded.
    July 2013
    Solved Using tcp instead of udp
    Ok i know its not ideal but i want to try and make teamspeak use tcp instead of udp to see if it fixes a connection issue, is there a way to do that?
    April 2011
    1,266
    No, as that is no configurable option within ts. For voice data the only valid transport is udp.
    December 2004
    RF
    3,006
    Last I checked, TS3 support both TCP and UDP for voice channel.
    Anything has changed since?
    18,153
    TCP was never used for voice.
