Results 1 to 3 of 3
    March 2009
    United States
    144
    Channel admin group overriding permission for custom group
    This is kinda a strange issue i'm trying to wrap my head around.
    The issue is with Group Member Add Power here is an example:
    Server Groups
    	Guild Leader
    		Channel Max Depth 10 0 0
    		Create Channel with Minimum Latency Factor 1 0 0
    		Change Channel Type to Temporary 1 0 0
    		Modify Channel Name 1 0 0
    		Modify Channel Topic 1 0 0
    		Modify Channel Description 1 0 0
    		Modify Channel Password 1 0 0
    		Modify Channel Max Clients 1 0 0
    		Modify Channel Max Family Clients 1 0 0
    		Channel Modify Power 50 0 0
    		Modify Channel Voice Encryption 1 0 0
    		Delete Permanent Channels 0 0 0
    		Delete Semi-Permanent Channels 1 0 0
    		Delete Temporary Channels 1 0 0
    		Force Deletion of Channels 1 0 0
    		Channel Delete Power 50 0 0
    		Join Permanent Channels 1 0 0
    		Join Semi-Permanent Channels 1 0 0
    		Join Temporary Channels 1 0 0
    		Ignore Channel Max Clients 1 0 0
    		Channel Join Power 50 0 0
    		Channel Subscribe Power 50 0 0
    		Channel Description View Power 50 0 0
    		Icon ID 1194784585 0 0
    		Group is Permanent 1 0 0
    		Group Sort ID 29 0 0
    		Needed Group Modify Power 70 0 0
    >>>		Group Member Add Power 40 0 0
    		Needed Group Member Add Power 60 0 0
    		Group Member Remove Power 40 0 0
    		Needed Group Member Remove Power 60 0 0
    		Max number of additional connections per Identity 2 0 0
    		Ignore Anti-Flood Measurements 1 0 0
    		Client Whisper Power 10 0 0
    		Client Needed Whisper Power 10 0 0
    		File Upload Power 10 0 0
    		File Download Power 10 0 0
    	All
    		View Virtual Server Connection Info 1 0 0
    		Use Privilege Keys to gain permissions 1 0 0
    		ServerQuery: View Channel Info 1 0 0
    		Create Sub-Channels 1 0 0
    		Create Temporary Channels 1 0 0
    		Create Channels with Topic 1 0 0
    		Create Channels with Password 1 0 0
    		Create Channels with Speex Narrowband Codec 1 0 0
    		Create Channels with Speex Wideband Codec 1 0 0
    		Create Channels with Opus Voice Codec 1 0 0
    		Create Channels with Max Codec Quality 7 0 0
    		Create Channels with Max Clients 1 0 0
    		Create Channels with Needed Talk Power 1 0 0
    		Icon ID 1604442474 0 0
    		Group Auto Update Type 15 0 0
    		Group Sort ID 317742 0 0
    		Show Group Name in Tree 1 0 0
    		View List of Server Group Members 1 0 0
    		View List of Channel Group Members 1 0 0
    		Permission Modify Power 30 0 0
    		Max Avatar Filesize (Bytes) 200000 0 0
    		Max Channel Subscriptions -1 0 0
    		Client is Priority Speaker    50
    		Use Channel Commander 1 0 0 30
    		Request talk power in moderated channels 1 0 0
    		ServerQuery: View Client Info 1 0 0
    		View Client Permission Overview 1 0 0
    		View Own Client Permission Overview 1 0 0
    		Needed ServerQuery Client View Power 75 0 0
    		Needed Client Kick From Server Power 50 0 0
    		Needed Client Kick from Channel Power 50 0 0
    		Needed Client Ban Power 50 0 0
    		Needed Client Move Power 50 0 0
    		Needed Client Complain Power 50 0 0
    		Private Textmessage Power 50 0 0
    		Send Text Messages to Channel 1 0 0
    		Send Text Messages to Offline Clients 1 0 0
    		Client Talk Power 50 0 0
    		Client Poke Power 50 0 0
    		Client Whisper Power 20 0 0
    		Client Needed Whisper Power 10 0 1
    		File Download Power 25 0 0
    		File Browse Power 25 0 0
    		Download Quota per Client (MByte) -1 0 0
    		Upload Quota per Client (MByte) -1 0 0
    Client
    Channel
    	Chatroom
    		Needed Channel Permission Modify Power 75
    		Needed Channel Delete Power 70
    		Icon ID -1951539762
    Channel Groups
    	Channel Admin
    		Create Permanent Channels 1
    		Create Channels with Description 1
    		Create Channels with Sort Order 1
    		Change Channel Type to Permanent 1
    		Change Channel Type to Semi-Permanent 1
    		Modify Channel Codec 1
    		Modify Channel Codec Quality 1
    		Modify Channel Latency Factor 1
    		Modify Channel Needed Talk Power 1
    		Channel Modify Power 70
    		Icon ID 100
    		Group Auto Update Type 40
    >>>		Group Member Add Power 35
    		Needed Group Member Add Power 35
    		Group Member Remove Power 35
    		Needed Group Member Remove Power 35
    		Client Move Power 25
    		Client Talk Power 60
    		Grant Talk Power 1
    Channel Client
    All
    	Needed Channel Permission Modify Power 75 0 0
    	Create Permanent Channels 1 0 0
    	Create Channels with Description 1 0 0
    	Create Channels with Sort Order 1 0 0
    	Change Channel Type to Permanent 1 0 0
    	Change Channel Type to Semi-Permanent 1 0 0
    	Modify Channel Codec 1 0 0
    	Modify Channel Codec Quality 1 0 0
    	Modify Channel Latency Factor 1 0 0
    	Modify Channel Needed Talk Power 1 0 0
    	Channel Modify Power 70 0 0
    	Needed Channel Delete Power 70 0 0
    	Icon ID 100 0 0
    	Group Auto Update Type 40 0 0
    >>>	Group Member Add Power 35 0 0    ????? (shouldn't this be 40?)
    	Needed Group Member Add Power 35 0 0
    	Group Member Remove Power 35 0 0
    	Needed Group Member Remove Power 35 0 0
    	Client Move Power 25 0 0
    	Client Talk Power 60 0 0
    	Grant Talk Power 1 0 0
    For some reason I can't figure out Channel admin is overriding the higher value of 40 from the server group and lowering it to 35. Despite negate and skip not being selected. Some groups were omitted from the permissions export but I have confirmed they have no effect on this strange interaction. I highlighted the issue lines with >>>
    May 2012
    Portugal
    161
    Draygo,
    There is a permission hierarchy between different permission types. Same permission in the ServerGroups will always be overwritten by the ChannelGroup ones unless the skip flag is enabled for that particular permission on the servergroup (or b_client_skip_channelgroup_permissions is active for the servergroup).
    /cheers
    March 2009
    United States
    144
    Thanks! hnd11 ill try that now.
  1. Replies: 10
    Last Post: September 21st, 2017, 11:09 AM
  2. [Resolved] Channel Admin permission overwrite group permission
    By spyder25000 in forum Permission System
    Last Post: February 22nd, 2015, 04:25 AM
  3. Custom permission group cannot set channel permissions
    By omniomi in forum Permission System
    Last Post: May 28th, 2013, 03:09 PM
  4. New Admin Group cant edit the Channel Permission
    By Bumpy01 in forum Permission System
    Last Post: April 23rd, 2013, 04:35 AM
  5. Channel group NOT overriding Server Group
    By sinister_evil in forum Permission System
    Last Post: January 4th, 2011, 06:12 PM
