Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    November 2017
    Noises
    Hi, I am getting beeps when I have the microhone muted and the headphones/speakers on...any help
  2. #17
    November 2017
    How do I disable this sound? [talking while muted]
    Hello, I really don't understand why this option was apparently disabled. I am trying to disable the horrifically annoying beep that constantly happens when I am pressing my PTT key while the mic is muted in teamspeak.
    Every other setting has a checkbox to turn the sound off, but not the "special" section:
    Quite frankly, this is completely unacceptable. I use multiple chat clients and sometimes share the PTT key between them. Consequently I mute teamspeak when I am speaking in another client. TS has decided this action is worthy of blowing my ears out with one of the most grating beeps that I have ever heard. And worse, it repeats every few seconds. YES I KNOW MY MIC IS MUTED.
    Please fix this immediately.
  3. #18
    February 2018
    Beeps when friend talks - solution
    Go to C:\Program Files\TeamSpeak 3 Client\sound\default and delete stop_talking.
    Thatīs it
  4. #19
    17,817
    That's no good solution.
    The file will be back on every update and not everyone has installed the client in this path.
    Solution is:
    1. Open Tools Options -> Application first.
    2. Then uncheck 'Warn when talking while mic muted'
    3. Press the OK button.
  5. #20
    November 2018
    Beeping while mic muted
    I looked in 'options->notifications->special->talking while muted, but it doesn't have a check box. I go as far as 'sounds deactivated' sound pack too... but the only actions with checkboxes are outside of the 'special' list.
    Any ideas? All solutions don't seem to match up with my teamspeak.
  6. #21
    November 2018
    No check box solution
    Quote Originally Posted by UltimatePedigree View Post
    I have the same issue as you where there isn't a check box for any of the "special" notifications including 'talking while muted' and I think I solved it. If you double click on the sound script (the part that says 'play("stoptalking.wav")' or whatever, it should highlight the text and then you can just hit backspace and delete it. After doing that I hit apply and stopped getting the beep! Let me know if that works for you too.
    -otirrub
  7. #22
    17,817
    This how to isn't right.
    Post #2 or #19 show how to solve it.
  8. #23
    June 2019
    Talk while muted"
    HTML Code:
    https://forum.teamspeak.com/threads/47614-Solved-Teamspeak-quot-Beeps-quot-when-Microphone-is-Muted
    My problem is the same as in the posted thread
    But which part is now the one to uncheck? Looked through all of the menu carefully but there was no second time "talk while muted" and this one is not "checkable" at all, for reasons i dont understand "Disable all sound packs" didnt solve it too
    (Why even bother changing something like that in newer patches? unless there is another way i need to dispatch my mic instead of mute me so that im not going crazy >.< )
    Appreciate every help!
  1. Weired very high beep when my fiend is talking
    By BaritanFly in forum Client Support
    Last Post: July 2nd, 2017, 11:52 PM
  2. [Request] Getting a notification when certain users start talking?
    By piets in forum Client Plugins / Lua Scripts
    Last Post: June 24th, 2016, 11:01 PM
  3. When I talking everyone are muted.
    By mizder in forum Windows
    Last Post: April 4th, 2014, 07:34 PM
  4. how to disable beep when microphone is muted
    By ghozt in forum Client Support
    Last Post: August 20th, 2010, 05:58 PM
  5. Mic Muted Notification
    By JohnJ in forum Client Support
    Last Post: December 20th, 2009, 11:37 PM
