Results 1 to 6 of 6
    August 2013
    Post Help with additional permissions, management and join power.
    Hi! I'm creating a TS3 server, I'm using the advanced Permissions but I have a pair of problems:
    First I want to move the place of the server groups, they appear like this:
    Owner
    Admin
    Member
    Moderator
    and I want to place them like this:
    ~~~staff~~~
    Owner
    Admin....
    ~~~guest~~~
    member
    Second, I would like all can send messages to the staff but for prevent spam, I want to create a group called Don't message and this group will not let you receive messages from members. (I want to make it with poke and move)
    Third, for example:
    I have 3 channels
    Admin Channel - Join permission 75
    VIP Channel - Join permission 50
    Lobby - Join permission 25
    What is the permission that defines your join power? I search in the filter "join" and I put 25 to the members but they can join the admin channel. Why?!
    And the last question:
    I will create a group called Poke for help who makes the admins can receive members messages who need help. How can I create it?
    If you have some questions write them below
    THANKS!!!
    August 2013
    530
    the sort order of groups within the permission system is determined by their "i_group_sort_id". The order of the clients in the channel tree is determined by the "i_client_talk_power".
    In the "Don't Message" group, you will need to set a "i_client_needed_private_textmessage_power" with a high enough value, maybe 75. This will prevent people from being able to message members of "Don't Message".
    The Join power you are talking about is called "i_channel_join_power". It will be compared with the "i_channel_needed_join_power" of the channel you are trying to join. Please make sure your member group does not have the permission "b_client_skip_channelgroup_permissions" as it will make the group ignore channel group permissions and channel permissions.
    Such a "Poke me" group can be made by adding the "i_client_needed_poke_power", set the value to 0 (do not remove the permission!) and check the "negate" box.
    August 2013
    Unhappy Thanks and help again O.o
    Oh thanks you help me a lot.
    But right now I have the same problems of the join power permission, I revised the permissions you tell me and all they are ok.
    For example:
    member join power: 15
    owner join power: 75
    and the needed join power of the admin channel is set to 70.
    And the members can join the admin channel, I don't know why?!, the other permissions work fine....
    For that help be more effective, my skype is: theUxicoD6
    I tell you my server ip and you revise the permissions.
    :D thanks again!
    Secret Base in Arctic Region
    1,671
    Do "members" have any other servergroup that may grant them higher join_power?
    Also check if "members" group has "b_client_skip_channelgroup_permissions" set, if yes, remove it.
    August 2013
    Yeah, I know it, but b_client_skip_channelgroup_permissions isn't active for member group I don't know why
    August 2013
    Thanks to all, I finally understand why do the permissions fail the channels have been created before the permissions xD
    Thanks again
  1. Someone with lower than needed join power can join my channel
    By Spacecraft in forum Permission System
    Last Post: September 2nd, 2014, 06:47 PM
  2. Default needed join power / inherit join power
    By omniomi in forum Permission System
    Last Post: May 28th, 2013, 03:02 PM
  3. [Resolved] Listening Power + group server channel join power
    By dartzdevil in forum Suggestions and Feedback
    Last Post: August 5th, 2011, 01:09 PM
  4. Join Power permissions
    By tgcsniper in forum Permission System
    Last Post: January 4th, 2010, 04:08 PM
