I am making a plugin which uses plugin commands to share positional data between clients, for that i am trying to use sendPluginCommand. Now sending a command to the whole channel, like this, works perfectly.
ts3Functions.sendPluginCommand(connectionHandlerID, pluginID, "some command", PluginCommandTarget_CURRENT_CHANNEL, NULL, NULL);
However if i try to send a command to a specific user like this
ts3Functions.sendPluginCommand(connectionHandlerID, pluginID, "some command", PluginCommandTarget_CLIENT, &idClient, NULL);
it works perfectly for x32 build of the plugin, however fails for x64 build of the plugin, as TeamSpeak throws an "invalid clientID" error.
Is there anything i'm missing, or is this actually an issue with TS itself?
