Results 1 to 3 of 3
    September 2013
    Question Port forwarding suddenly stopped working (only for TS3)
    Hey,
    I have an old PC which is used as server. I'm running a MineCraft and a TeamSpeak 3 server on it.
    I configured the PC and my router and everything worked fine. Then, suddenly, about one or two months ago, connecting to the TS server was not possible anymore, but MineCraft still worked. Then I discovered that from inside the network, connecting to the server was still possible, only access via the internet doesn't work.
    I tried restarting the router, restarting the PC, changing the TS3 server port (and activating port forwarding for the new port), setting up a new TS3 server, but still nobody can connect from outside the network.
    TS3 Client: v3.0.12
    TS3 Server: v3.0.7.1
    PC OS: Windows 7
    Router: Vodafone EasyBox 803
    Forwarded Ports: 9987 (TCP&UDP), 10011 (TCP), 30033 (TCP)
    I have no idea whether this is a router or a teamspeak problem ... but perhaps you know how to solve it.
    Thanks,
    KillerJo
    2,698
    Quote Originally Posted by KillerJo View Post
    TS3 Client: v3.0.12
    PC OS: Windows 7
    Try with Port 9987 UDP only
    September 2013
    I think the guy above probably fixxed it but if not make sure you are forwarding to the right computers internal IP address
  1. Mic Suddenly Stopped Working w/ TS3
    By DarkLight in forum Client Support
    Last Post: October 19th, 2015, 08:23 AM
  2. TS3 Server Suddenly Stopped working
    By Paleetech in forum Server Support
    Last Post: January 13th, 2015, 02:36 PM
  3. Server suddenly stopped working
    By Censurerat in forum Windows
    Last Post: October 10th, 2013, 01:05 PM
  4. Server was working fine, then suddenly stopped.
    By NYBrian84 in forum Windows
    Last Post: December 17th, 2012, 10:05 AM
