Results 1 to 3 of 3
    September 2013
    TS3 identity help
    Okay, so i'm trying to transfer my TS3 identity from my windows 7 computer to windows 8.
    I've exported it onto my USB, placed that USB into my laptop, dragged the .ini onto my desktop, then imported it. I set it as the default identity, but when I connect to the server I have no permissions that I had on my other computer under the same identity.
    If you could help me you'd be my hero <3
    May 2007
    Eastern NC
    1,801
    If you are using a bookmark did you update the Identity there?
    April 2009
    173
    Hi Darian.
    The easy way is to Export your identity at your Win 7 and Import it at the new PC.
    Under Settings/Identity you can do the Export.
    The other way is to copy the ts3clientui_qt.secrets.conf File to the new Computer.
    Hope it helps.
    Regards Sargnagel
  1. Replies: 6
    Last Post: July 8th, 2014, 03:09 AM
  2. Dj with one identity
    By Skalleper in forum General Questions
    Last Post: April 25th, 2014, 08:01 PM
  3. Replies: 4
    Last Post: July 3rd, 2011, 02:06 PM
  4. TS3 identity
    By DaFinshi in forum General Questions
    Last Post: June 18th, 2011, 09:04 AM
