Results 1 to 3 of 3
    May 2007
    Eastern NC
    1,794
    Solved minor text box value not always displaying right value
    Testing I found that if a user without b_channel_modify_temp_delete_delay opens the edit window and selects the Advanced Tab the value of the Delete Delay box is not updated correctly. In my test I had the delay set to 86400 but this user without b_channel_modify_temp_delete_delay see 99 in the disabled control. If I gave them b_channel_modify_temp_delete_delay even though they had no i_channel_create_modify_with_temp_delete_delay the control was still disabled as it should be but would show the correct value of 86400.
    No real impact on the use of the server, just a minor UI bug I think.
    17,941
    Acknowledged
    We can reproduce it. It appears to be a problem, when channel delete delay is higher than 100 seonds on target channel.
    17,941
    This issue was fixed with client 3.0.13.1
  1. [Rejected] Some minor issues (client ui)
    By Zardo in forum Suggestions and Feedback
    Last Post: May 18th, 2011, 06:58 PM
  2. minor app scanner corrections
    By protopethunter in forum Bug Reports [EN/DE]
    Last Post: August 10th, 2010, 12:15 AM
