Results 16 to 30 of 37
  1. #16
    March 2012
    11
    Deleted
    Win 7x64
    UAC is default
    TS3 runs in Admin mode as do most other of my programs
    Can't remember hotkey mode 2 patches ago.
    Have not tried new database.
    Changing PTT hotkey to A-Z makes no difference. Same problem.
    No other software using macros is used.
  2. #17
    October 2013
    I am on Windows 8.1 and on the latest update x64 push to talk would not work while focused on any game or game lauuncher, It worked after I ran Teamspeak as Admin and set compatability for windows 8.
  3. #18
    18,144
    Quote Originally Posted by jdc2389 View Post
    This is a known behavior, when your game does run in admin mode. It catches all the keyes before teamspeak will get them. No bug, but thank you for the information.
    scudwillms
    Our developer tries to find a way to recognize these buttons. I do have the same Joystick here and it won't work.
  4. #19
    January 2005
    Orlando, FL, USA
    8
    Question 3.0.13.1 Client selects wrong OS InputDevice on start.
    In order for HotKeys to be recognized at startup, we have to switch whatever value is set for Options -> Hotkeys -> (Default or Keyboard & Mouse Only) to the other option -- doesn't matter which. When we change that value to either option and Apply, Hotkeys start working again.
    While investigating the log files, we can see the startup sequence (shown below).
    On line 7, the TS client is detecting our USB UPS device and appears to think it is an input device (categorized as "InputDevices" as noted. Is this the reason HotKeys are not able to be detected at startup?
    By changing the input type (mentioned earlier), perhaps the correct input device is getting selected as a result of the change and that's why HotKeys start working as expected.
    Please advise.
    -- LOG DUMP (truncated) --
    2013-11-17 11:47:01.287896|INFO    |              |   | TeamSpeak 3 Client 3.0.13.1 (2013-10-23 12:10:11)
    2013-11-17 11:47:01.287896|INFO    |              |   | SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 64bit
    2013-11-17 11:47:01.287896|INFO    |              |   | Using hardware aes
    2013-11-17 11:47:01.303521|DEBUG   |Direct Sound  |   | setting timer resolution to 1ms
    2013-11-17 11:47:01.545929|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-11-17 11:47:01.545929|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-11-17 11:47:01.617999|INFO    |InputDevices  |   | Input device name: American Power Conversion Uninterruptible Power Supply
    2013-11-17 11:47:01.617999|INFO    |Input         |   | Default monitoring enabled
    2013-11-17 11:47:01.634015|INFO    |              |   | *** Time [MAINWINDOW]: 361
    2013-11-17 11:47:01.635016|INFO    |              |   | *** Time [INIT]: 362
    2013-11-17 11:47:01.642022|INFO    |ClientUI      |   | Qt version: 4.8.3
    2013-11-17 11:47:01.642022|INFO    |ClientUI      |   | Using configuration location: D:/Program Files/TeamSpeak 3 Client/config/settings.db
    2013-11-17 11:47:02.133974|INFO    |ClientUI      |   | Last update check was: Sun Nov 17 08:18:21 2013
  5. #20
    18,144
    How can it be, that an external Power supplybecomes an input device?
    Do you really use such an external Power supply on your computer and what other Hardware (Keyboard, mouse, gamepad/joystick) do you use?
    What is in the log, when you have changed the keyboard mode?
  6. #21
    January 2005
    Orlando, FL, USA
    8
    Arrow Info
    How can it be, that an external Power supply becomes an input device?
    That's exactly my question too. Why would TS detect my uninterrupted power supply as an input device is why I'm asking if that's the problem.
    Do you really use such an external Power supply on your computer...
    This UPS is a standard APC backups unit that has been connected for ages. I've used TeamSpeak for years with the UPS connected -- this is a new problem.
    ... and what other Hardware (Keyboard, mouse, gamepad/joystick) do you use?
    Logitech G15 and Logitech G9x, both also the same for a long time. No joysticks or gamepads connected.
    You'll see below, that it logs the selection change, but there's no other indicators of the "InputDevices" line.
    As I mentioned the process that we can produce is this:
    1) Open TeamSpeak.
    2) Connect to any server.
    3) We discover that HotKeys are not working.
    4) Open Settings -> Options -> Hotkeys.
    5) Toggle the keyboard pulldown to the other choice (line 45/46 below).
    5) Click Ok.
    6) HotKeys start working.
    7) <Use TeamSpeak as per usual>
    8) Disconnect and Close.
    We have to do this process every time we start TeamSpeak.
    Below is the full log session of the steps above.
    2013-11-18 06:35:17.700683|INFO    |              |   | TeamSpeak 3 Client 3.0.13.1 (2013-10-23 12:10:11)
    2013-11-18 06:35:17.700683|INFO    |              |   | SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 64bit
    2013-11-18 06:35:17.700683|INFO    |              |   | Using hardware aes
    2013-11-18 06:35:17.731935|DEBUG   |Direct Sound  |   | setting timer resolution to 1ms
    2013-11-18 06:35:18.178597|INFO    |              |   | *** Time [MAINWINDOW_ACTIONS]: 176
    2013-11-18 06:35:18.347762|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-11-18 06:35:18.347762|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-11-18 06:35:18.523656|INFO    |              |   | *** Time [SERVERVIEW_ACTIONS]: 149
    2013-11-18 06:35:18.528662|INFO    |              |   | *** Time [SERVERVIEW]: 190
    2013-11-18 06:35:18.563693|INFO    |              |   | *** Time [SERVERVIEWMANAGER]: 303
    2013-11-18 06:35:18.614742|INFO    |InputDevices  |   | Input device name: American Power Conversion Uninterruptible Power Supply
    2013-11-18 06:35:18.614742|INFO    |Input         |   | Keyboard & mouse monitoring enabled
    2013-11-18 06:35:18.660035|INFO    |              |   | *** Time [MAINWINDOW]: 1022
    2013-11-18 06:35:18.666231|INFO    |              |   | *** Time [INIT]: 1028
    2013-11-18 06:35:18.705025|INFO    |ClientUI      |   | Qt version: 4.8.3
    2013-11-18 06:35:18.705025|INFO    |ClientUI      |   | Using configuration location: D:/Program Files/TeamSpeak 3 Client/config/settings.db
    2013-11-18 06:35:19.155799|INFO    |ClientUI      |   | Last update check was: Sun Nov 17 08:18:21 2013
    2013-11-18 06:35:19.206816|INFO    |              |   | Checking for updates...
    2013-11-18 06:35:19.294496|INFO    |TSDNS         |   | DNS resolve successful, "update.teamspeak.com"=176.9.148.78
    2013-11-18 06:35:19.537700|INFO    |              |   | Update check, my version: 1382530211, latest version: 1382530211
    2013-11-18 06:35:24.939675|INFO    |ClientUI      |  1| Connect to server: ts.tacticalgamer.com
    2013-11-18 06:35:24.942678|INFO    |ClientUI      |  1| Trying to resolve ts.tacticalgamer.com
    2013-11-18 06:35:25.001740|INFO    |TSDNS         |   | SRV DNS resolve unsuccessful for "_ts3._udp.ts.tacticalgamer.com"
    2013-11-18 06:35:25.002741|INFO    |TSDNS         |   | No SRV TSDNS found at "_tsdns._tcp.ts.tacticalgamer.com"
    2013-11-18 06:35:25.004577|INFO    |TSDNS         |   | DNS resolve successful, "ts.tacticalgamer.com"=174.123.98.92
    2013-11-18 06:35:25.453750|INFO    |ClientUI      |  1| Lookup finished: 174.123.98.92 9988 ts.tacticalgamer.com 0 0
    2013-11-18 06:35:25.453750|INFO    |ClientUI      |  1| Resolve successful: 174.123.98.92:9988
    2013-11-18 06:35:25.453750|INFO    |ClientUI      |  1| Blacklist check ok
    2013-11-18 06:35:25.454755|INFO    |ClientUI      |  1| Initiating connection: 174.123.98.92:9988 ts.tacticalgamer.com
    2013-11-18 06:35:25.512072|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-11-18 06:35:25.512072|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-11-18 06:35:25.668203|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-11-18 06:35:25.668203|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-11-18 06:35:25.668203|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2013-11-18 06:35:25.697842|DEBUG   |Windows Audio Session|   | WAS Buffer size: 896
    2013-11-18 06:35:25.698845|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2013-11-18 06:35:25.698845|INFO    |PreProSpeex   |  1| Speex version: speex-1.2beta3
    2013-11-18 06:35:25.699844|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2013-11-18 06:35:25.700937|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2013-11-18 06:35:25.758548|INFO    |ClientUI      |  1| Connect status: Connecting
    2013-11-18 06:35:26.021676|INFO    |ClientUI      |  1| Connect status: Connected
    2013-11-18 06:35:26.115568|INFO    |ClientUI      |  1| Connect status: Establishing connection
    2013-11-18 06:35:26.245065|INFO    |ClientUI      |  1| Connect status: Connection established
    2013-11-18 06:35:26.258926|INFO    |PermManager   |   | Loading permissions from cache
    2013-11-18 06:36:05.571921|INFO    |Input         |   | Keyboard & mouse monitoring disabled
    2013-11-18 06:36:05.572921|INFO    |Input         |   | Default monitoring enabled
    2013-11-18 06:36:50.453896|INFO    |ClientUI      |  1| Connect status: Disconnected
    2013-11-18 06:36:50.455898|INFO    |ClientUI      |  1| Disconnected or forced to leave, want autoreconnect = 0
    2013-11-18 06:36:50.759190|INFO    |Bookmarks     |   | Disconnect, total time: 84 - 855180
    2013-11-18 06:36:53.515469|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-11-18 06:36:53.515469|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-11-18 06:36:53.964511|DEBUG   |Windows Audio Session|   | WAS::stopDevice-enter
    2013-11-18 06:36:53.964511|DEBUG   |Windows Audio Session|   | WAS::stopDevice-leave
    2013-11-18 06:36:53.964511|DEBUG   |Windows Audio Session|   | WAS::closeDevice-enter
    2013-11-18 06:36:53.965515|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - enter
    2013-11-18 06:36:53.965515|DEVELOP |Windows Audio Session|   | DeviceDeleteList::queueDeviceDelete - leave
    2013-11-18 06:36:53.965515|DEBUG   |Windows Audio Session|   | WAS::closeDevice-leave
    2013-11-18 06:36:53.965515|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-11-18 06:36:53.965515|DEVELOP |Windows Audio Session|   | Waiting for device to close
    2013-11-18 06:36:53.965515|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - enter
    2013-11-18 06:36:53.967631|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-11-18 06:36:53.968636|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - leave
    2013-11-18 06:36:54.119608|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-11-18 06:36:54.119608|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-11-18 06:36:54.121614|DEVELOP |Windows Audio Session|   | DeviceDeleteList::clearQueue - enter
  7. #22
    18,144
    Thank you for these information, I will talk to our developer tomorrow about that problem.
    I have currently no idea, how this could happen, that a power supply unit becomes a device for the hotkey system.
    Edit
    Maybe this has nothing to do with that external device.
    My opinion:
    The problem, that hotkeys are not working until you switch mode seems to be related to following unsolved thread
    http://forum.teamspeak.com/showthrea...968#post363968
  8. #23
    18,144
    We still can not explain why your hotkeys do not work after connecting to a server.
    Are you all 100% sure ,that your current bookmark entry has a valid (filled in with hotkeys) hotkey profile selected?
  9. #24
    January 2005
    Orlando, FL, USA
    8
    This is not a bookmark problem. The problem occurs regardless. As proof, I launched TeamSpeak and connected directly to the official "voice.teamspeak.com" server; direct connect (no bookmark) and still have to make a change to the keyboard mouse selection in order for HotKeys to start working.
    The same would hold true if I had a hotkey to connect to a server (no server connected yet). This is a problem with out TS is obtaining a hook into the input stream to detect HotKeys. For some reason it doesn't do it on start.
    So are you saying my log dump regarding the InputsDevices seeing my USB APC UPS is non-issue??
  10. #25
    18,144
    I can explain, why your power supply is listed as an input device.
    Every non Keyboard/mouse device is listed in there, when it does match the usb.ids from your TeamSpeak folder.
    051d  American Power Conversion
        0001  UPS
        0002  Uninterruptible Power Supply
        0003  UPS
    Means we could recognize hotkeys from that device.
    But i can not explain, why hotkeys do not work after connection was made.
    We can not reproduce this.
    @ Everybody
    Do you use a Laptop or a Computer?
    What USB devices are connected?
    Do you use the Windows USB driver or did you install something from a manufactor like INTEL USB 3.0 Driver.
    Can you Test and confirm something for us? We'd like to see if that happens with older clients.
    What do you need?
    - You need a backup of your current client config (just safe or rename this folder, while testing)
    Stored here: C:\Program Files\TeamSpeak 3 Client\config
    or here: %appdata%\TS3Client
    - Client 3.0.9 and Server 3.0.9
    http://dl.4players.de/ts/releases/3.0.9/
    How to:
    1. Install client 3.0.9 and start it (should have an empty configuration)
    2. Go into Settings > Options > Hotkeys and switch to Hotkey profil "Default"
    3. Go into your Bookmark manager and change the server address to localhost
    4. Now Setup some Hotkeys "Mute Unmute PTT and a hotkey to connect to your bookmark"
      (Please use normal keys like A B S Mouse1 Mouse2)
    5. Now Close the client and reopen it
    6. Unzip the server on your desktop and start the binary
    7. Now try to connect with your hotkey and check if your hotkeys still do work
  11. #26
    December 2013
    TS3 3.0.13.1 doesn't register key presses
    When ever I start up TS3 I have to go into hotkeys and switch from default to mouse and keyboard or from mouse and keyboard to default before TS3 registers the PTT key I've setup (its left control). After a few hours TS3 will forget this and I have to switch over to either Default or Keyboard and mouse. This was never an Issue back when you guys had Direct Input because I would set it to that and never have any issues.
  12. #27
    18,144
    Please read the post above yours.
    http://forum.teamspeak.com/showthrea...478#post366478
  13. #28
    June 2012
    The only "Hot Key" that I had that was assigned anything to do with TeamSpeak was, #12 on my Logitech 3D Pro joystick. It was assigned as my push to talk. All other keys were assigned to various tasks associated to my Rise of Flight sim. After the update, two updates ago, my #12 key would not respond as my PTT. I attempted to switch to another key, #11, #10, #9, #8, but the only key that TeamSpeak would recognize was the #7 key. As far as TeamSpeak was concerned, keys #8 through #12 do not exist. My only solution was to transfer function of #7 key, my flight recorder, to key #12, and make key #7 my PTT. My Rise of Flight sim recognizes all of the keys, #7 through #12. Since the update, two updates ago, TeamSpeak is the only one that WILL NOT recognize any of the aforementioned keys. I now have two Logitech 3D Pro joysticks, my original and a new one....both of which I have used in various ports....and each has the same results: FAILURE OF TEAMSPEAK TO RECOGNIZE KEYS #8 THROUGH #12.
    I hope this simple description helps, and I hope that you are able to work out some sort of patch, as the key arrangement that I am currently force to use is most inconvenient.
    Appreciate all that you do...
    Scud
  14. #29
    18,144
    Quote Originally Posted by scudwillms View Post
    The only "Hot Key" that I had that was assigned anything to do with TeamSpeak was, #12 on my Logitech 3D Pro joystick.d
    Wrong thread!
    Again.
    This is your thread and i already answered there.
    http://forum.teamspeak.com/showthrea...not-recognized
  15. #30
    December 2013
    Push to talk doesn't work with latest update
    Alright, I'll short it up.
    I've upgraded my TS3, push to talk didn't work unless its a mouse button or voice detection.
    So what I've done -
    Manually selecting profiles (They were already selected)
    Reinstalled TS3
    Removed TS3Config.
    No success.
    What to do?
  1. Replies: 3
    Last Post: August 10th, 2014, 05:12 PM
  2. [outdated thread][Push to talk: No hotkey assigned
    By greedywhore in forum Windows
    Last Post: October 1st, 2013, 07:16 AM
  3. Push to talk assigned...
    By dcstryker in forum Permission System
    Last Post: December 18th, 2011, 04:08 PM
  4. [outdated thread][Push to talk: No hotkey assigned
    By greedywhore in forum Bug Reports [EN/DE]
    Last Post: October 5th, 2010, 05:25 PM
  5. Push to talk problem
    By Ballzy in forum General Questions
    Last Post: August 16th, 2010, 04:24 PM
