Results 1 to 8 of 8
    September 2013
    Headset works in skype, not in TS
    Hello!
    I have a problem on TS
    I can only talk on TS if I talk to someone on Skype... :O
    Without calling someone on Skype I cant talk on TS
    PLZ HELP ME!!!!
    Wouter
    18,513
    This could happen, when the wrong device is set under windows. Skype has a feature to enable the right device during the session.
    You can't hear or talk?
    - What device do you use and are your drivers up to date?
    - Please tell us your capture or playback settings.
    - Try to select your device directly and not default under Settings > Options > Playback or Capture.
    - Is there a capture or playback profile set in your bookmark?
    Please check your settings under Bookmarks > Manage Bookmarks > Click the "More"
    - Have you tried to send something with Push-To-Talk/Continous Transmissions enabled?
    October 2013
    Angry Headset works in skype, not in TS
    The topic says it all...
    I can use my microphone perfectly in Skype, but it just doesn't work in TS...
    It is only about the microphone, i can hear the others talk in TS too.
    I tried to uninstall Skype, reinstall TS, reboots,...
    Using the newest TS3 version, and Windows Vista.
    No solution found! Please help!
    Thanks!
    April 2015
    Cannot speak on a server
    So today I encountered a very strange problem in teamspeak. I was unable to transmit my voice to the server. My friend on the server who was helping me troubleshoot the problem told me to get on skype and see if it worked then. I was able to talk on skype so i know it wasn't a microphone hardware issue but then i realized my voice was now working on the teamspeak. I closed out of the skype call and then realized i was no longer able to talk on teamspeak. So basically i cant talk on the server unless i have a skype call running. I'm currently running the skype test call on mute so i can talk to people on teamspeak. I restarted my computer and reset my input device in the options and have tried most everything to fix it. Anybody know how to fix it? (Also I have clownfish voice changer installed as a plugin)
    April 2015
    Microphone disabled
    Hi, i've a problem with my ts3, it say my microphone is disabled but in skype or other he is on.
    And in the options they are not my micro, juste Default.
    Thanks for help me.
    April 2015
    Mic works fine in Skype, but doesn't work properly in TS3
    Using Skype there's literally zero issues with my mic, but in TS3 it barely picks up when I talk. I'm being told it picks something up, but it's mostly just noise.
    I've been through Setup Wizard and Capture options, trying every single Capture Mode and Device. I have a built in digital mic on my laptop that I'm using. Detailed specs on the laptop (Thinkpad E330) are here: http://support.lenovo.com/us/en/documents/pd024702
    I've tried uninstalling TS3 completely.
    Using Windows 7.
    Help?
    April 2015
    Don't know why I was merged with a two year old thread with a guy who didn't even have the same problem as me. What has been written here did not even help me slightly, as I've already tried it.
    It is not RESOLVED at all as the thread says...
    April 2015
    Mic & Speakers Disabled
    When I log onto teamspeak, my mic and speakers are disabled.
    I can perfectly talk on skype and stuff, but not teamspeak.
    Teamspeak is updated, I've restarted my computer, I've relogged ts multiple times, I've changed my sound format, I've done everything I can.
    If anyone is able to help me that'll be great.
  1. [Resolved] Teamspeak only works with skype
    By Polinesian in forum Windows
    Last Post: November 7th, 2015, 10:24 PM
  2. microphone works only when skype enables it
    By unix-fan in forum Windows
    Last Post: November 10th, 2014, 01:39 PM
  3. Replies: 1
    Last Post: December 7th, 2011, 06:17 PM
