Results 1 to 12 of 12
    July 2007
    Germany / NRW
    10
    Channel Admin unable to modify Channel Permissions
    I am having a Problem which I do not get solved.
    I give the Channel Admin permission to a user, who should then be able to change the join/subscribe (etc.) permissions for this channel but I cant get it working. I always get the error message "insufficient permission modify power". I have tried several permissions but it seems I did not get the right combination.
    Can anyone tell me how which permissions I need to change?
    Thanks!
    September 2013
    63
    I_channel_modify_power
    But check the i_needed_channel_modify_power of the channel. May be wrong ;D
    July 2007
    Germany / NRW
    10
    i_channel_needed_modify_power of this channel is not set.
    i_channel_modify_power of the channel group is set to 75
    but i_channel_needed_permission_modify_power of the channel is set to 75 - i have also set the i_channel_permission_modify_power for the channel group to 75.. doesnt help
    July 2007
    Germany / NRW
    10
    April 2011
    1,266
    And you are sure those rights are not overwritten by a server group? Try to check the permission overview of a user affected.
    July 2007
    Germany / NRW
    10
    seems like yeas i am sure :/
    Secret Base in Arctic Region
    1,671
    Did you read the permissions guide that comes with the server?
    (In case you dont host yourself, it can be found -> here.)
    To set an permission you need not only "*_permission_modify_power" but also the GRANT value for that permission.
    Only if your permission_modify_power is >= the GRANT value of the permission you want to set it can be done.
    July 2007
    Germany / NRW
    10
    I always thought the grant power was for granting a permission on a channel group for example. Probably I am wrong but the documentation seems not that clear as I hoped it was.
    but anyway. even adding a 75 to the grant power of i_permission_modify_power and i_channel_modify_power does not fix the problem.
    it is still "insufficient permission modify power"
    May 2006
    Europe/Czech Rep.
    1,616
    Argh, I though I wrote this already but can't find it.
    Do only this to a testing channel group:
    i_channel_modify_power 4
    i_channel_needed_join_power GRANT=4
    i_channel_needed_subscribe_power GRANT=4
    i_channel_needed_description_view_power GRANT=4
    i_channel_permission_modify_power 4
    b_client_is_priority_speaker GRANT=4
    Before testing make sure that channel permissions have:
    i_channel_needed_permission_modify_power 4
    Of course you might replace all those 4 with higher number like 75, but this is my preference. There are obviously some implications if you go with "high" numbers.
    Then give it a s pin :-)
    to Relicted last post:
    if GRANT is set on some permission it means that user affected by it can change this permission on other users/groups inside a teamspeak, if there isn't other requirements forbidding him to do so on those layers in hierarchy.
    July 2007
    Germany / NRW
    10
    can't get it working maybe there is another unseen-"problem".. i really don't know. Probably someone of you could have a look at my permission system? I would surely pay for your time.
    1,671
    Send a PM to -> "Matthias B", here surely will help you
    July 2007
    Germany / NRW
    10
    idk but this sounds very ironically
  1. Channel Permission Modify Power - Unable to change
    By Gannex in forum Permission System
    Last Post: July 29th, 2015, 09:49 PM
  2. Replies: 2
    Last Post: April 26th, 2015, 02:54 PM
  3. Replies: 4
    Last Post: December 7th, 2014, 02:30 PM
  4. Unable to modify my own channel not being in it
    By grieferignoto in forum Permission System
    Last Post: October 13th, 2014, 10:13 AM
  5. [Resolved] Channel Group unable to modify its channel no matter what I do?
    By Alakuu in forum Permission System
    Last Post: February 14th, 2014, 12:48 AM
