Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 103
  1. #46
    18,513
    I understand why the wrong context menu does appear.
    Another permission than your taget seesm to be selected.
    But I still fail to reproduce it, because my right click does activate the permission.
    What happens when you just hover above permissions? A blue background should appear.
  2. #47
    December 2010
    United Kingdom
    340
    Hello !
    I use every possibilities to click in permissions:
    http://ts3bahu.com/wilhelm/bug2.wmv
  3. #48
    18,513
    We still fight to get that
    Thank you for your patience and the feedback
    Another idea from a co-worker: Maybe it has something to do how Teamspeak was started
    What are your Windows UAC settings?
    Where is your client installed and started from?
    How do you start the client (with admin mode or just normal user mode) and do you use any parameter for the client?
    Where is your configuration stored under (appdata or program folder)?
  4. #49
    December 2010
    United Kingdom
    340
    OS: Windows 8.1
    UAC: Default.
    Starting program as administrator always.
    Configuration stored in: %appdata%
    Program teamspeak 3 installed in %programfiles%
    Reproduced bug finally know where is exactly:
    http://ts3bahu.com/wilhelm/reproduced_bug.avi
    That's all.
  5. #50
    April 2011
    1,266
    I can reproduce it...
    The shortend context menu appears if the mouse hovers over the "negate" or "grant" area on the line. The full context appears if mouse is in the area of "permission", "value" or "skip" while pressing right mouse button.
    Win 7 64 bit
    Client 3.0.14 64 bit
  6. #51
    August 2011
    Belgium
    20
    A problem too when you use special chars with Alt+Num. For exemple, usure of "♥" will crash TS3 Client with dump.
    I can send the dump file if necessary. Confidential datas are recorded in dump file ??
    EDIT : Dump file https://mega.co.nz/#!gJljHKzK!Oq5XiU...1PVvSYd71_oESM
  7. #52
    18,513
    Quote Originally Posted by goldensun View Post
    Yea please edit your post an add that dump file.
    My client did not crash, when i used these symbols in nickname, chat , channel name.
  8. #53
    Krün, Germany
    510
    Regarding right/click on permissions You are right, I see what you mean. Thanks.
    EDIT: Last 3.0.13.1 stable client seems to behave exactly the same. Still, it looks wrong, so we should fix it.
    Regarding all the rest in this thread:
    1) Thanks a lot for all your feedback
    2) Lots of things are already fixed, some are not yet. We are meanwhile back from vacation (yes, even TeamSpeak developers are just human ^^) and looking through the issues reported here. New beta will be incoming once we are through with the list. Perhaps this week, perhaps next.
  9. #54
    August 2011
    Belgium
    20
    done.
    For me, it crash in poke/mp/nickname/channel edit. I've test with "♥" (alt+3).
  10. #55
    18,513
    Nothing happens here on XP, Vista, windows7 and Windows 8.1.
    Are you using the default style and /or any plugin?
  11. #56
    August 2011
    Belgium
    20
    I use the template named "Fusion", with "French" translation, plugins :
    - AppScanner
    - ClientQuery
    - Teamspeak 3 control plugin.
    My build (not the same of your ??) :
    Version TeamSpeak:3.0.14 (19/12/2013 10:08:14) [Beta] sur Windows
    Dump file in previous topic.
    TeamSpeak don't always crash, it's just 4/5 times.
    A friend who have 3.0.14 too have the same bug.
    User logs :
    14/01/2014 12:44:17 Info TeamSpeak 3 Client 3.0.14 (2013-12-19 09:08:14)
    14/01/2014 12:44:17 Info SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    14/01/2014 12:44:17 Info Using hardware aes
    14/01/2014 12:44:17 Direct Sound Debug setting timer resolution to 1ms
    14/01/2014 12:44:17 Info *** Time [SPAWN_EVENTCONVERTER]: 246
    14/01/2014 12:44:17 Info Skipping Qt4 dependant overlay plugin
  12. #57
    November 2011
    Belarus
    142
    how to get your build number:
    1. 'Check for Update' button
    2. Tools - Client Log (CTRL+L)
    Example
    14.01.2014 15:17:13 Info Update check, my version: 1387444094, latest version: 1387444094
  13. #58
    18,513
    just ignore my version.
    I can not reproduce that crash here on my system.
    Do you use another Font under "Settings > Options > Chat" ?
  14. #59
    August 2011
    Belgium
    20
    MS Shell Dlg, 2, 8
  15. #60
    18,513
    Just a quick reply at the end of my working day.
    Quote Originally Posted by Tomi-Toma View Post
    Channel / User appears twice.
    Fixed, it was caused from hunterpl's following report.
    Quote Originally Posted by hunterpl View Post
    " Collapse all channels " and " Expand channels " make freeze program, increase the CPU usage up to 50% for a few seconds WTF! Memory work all right. Especially on the big public servers, you can test it.
    You won't notice any lag or freezes anymore.
    Quote Originally Posted by Killingmarv View Post
    On Mac OSX when closing the Teamspeak window via the standard X-button (Applikation is still running), there is no possibility to open the window again.
    The X is disbaled as a workaround. There is currently no ther way to solve this.
    Wrong translation in the rightclick menu from the chatbox.
    It should have the language from client settings.
    - Appscanner plugin not working on Windows XP and Vista
    - Wrong context menu in permission dialog (This needs an already broken database. We could not reproduce this, but hope to have it fixed.)
    All these issues / bugs will be fixed with the next beta release.
    @ goldensun
    I have the same settings but nothing happens so far.
    Do you and your mates do use some sort of software or same devices?
  1. [Beta Channel] TeamSpeak 3 Client 3.0.18
    By Chris in forum Archive
    Last Post: September 18th, 2015, 12:42 PM
  2. [Beta Channel] TeamSpeak 3 Client 3.0.17
    By PeterS in forum Archive
    Last Post: August 10th, 2015, 08:35 AM
  3. [Beta Channel] TeamSpeak 3 Client 3.0.10.1
    Last Post: April 1st, 2013, 11:50 AM
  4. [Beta Channel] TeamSpeak 3 Client 3.0.10
    Last Post: March 4th, 2013, 09:22 AM
  5. [Beta Channel] TeamSpeak 3 Client 3.0.9
    Last Post: October 22nd, 2012, 07:41 AM
