Results 1 to 6 of 6
    January 2014
    Question Channel admin group for the temp or semi channels
    is there any option how to create a server group for the Channel admin of the temporary or semi-permanent channels, which is assigned automatically?
    I know I can negate sortorder for Channel admin, but this settings negate sortorder for admins of the permanent rooms and that's what I don't want. I just want block sortorder for this two types, because some users sorts theirs room above/under the main channel.
    Thank you for your help.
    May 2012
    Portugal
    161
    Hello Dicson,
    I can't understand very well your request. What do you want to block?
    - The User order within temporary/semi-permanent channels.
    or
    - The temporary/semi-permanent channels location within the teamspeak?
    /Cheers
    April 2012
    317
    Sort order only influences how icons behind a username are sorted.
    Sorting of clients below or above sub-channels is a client setting only.
    And there is only one channel group (channel admin by default) that will be automatically assigned when creating a channel.
    Sent from my C6603 using Tapatalk
    January 2014
    I want block sort option (b_channel_create_with_sortorder and b_channel_modify_sortorder) but only for the Channel admins of the temporary channels.
    May 2012
    Portugal
    161
    Quote Originally Posted by Dicson View Post
    You cannot have different permissions for the same channel group depending on the type of channels.
    Instead of trying to get different permissions, you can do a different thing:
    - Clone the Channel admin channel group (let's call "TEMP C.A.") and remove the features you don't want;
    - Edit the Virtual Server Properties and on the Misc tab, make the default Channel Admin group the "TEMP C.A." channel group. This channel group will be the default channel group for everyone who creates a new channel;
    - Manually give to the few select users the original Channel Admin channel group, which grant them the said permissions.
    OR
    - Create specific channels, where the Temporary or Semi-Permanent rooms can be created and disable their creation in Parent channels.
    Hope this can be of any help.
    /Cheers
    January 2014
    Haha, I'm stupid, it's so easy.
    Thank you for help.
  1. Replies: 2
    Last Post: June 15th, 2014, 06:27 PM
  2. Channel admin - change channel type to semi-permanent
    By constrych9 in forum Bug Reports [EN/DE]
    Last Post: November 16th, 2010, 04:09 PM
  3. [Solved] Channel admin - change channel type to semi-permanent
    By constrych9 in forum Permission System
  4. [Fixed] temp channel with (semi-)perm sub channel bug
    By Screech in forum Bug Reports [EN/DE]
    Last Post: August 25th, 2010, 05:42 PM
  5. [SUGGESTION] Create sub-channels w/ temp, semi and/or permanent
    By poisonpanik in forum Suggestions and Feedback
    Last Post: July 21st, 2010, 03:38 PM
