Results 1 to 7 of 7
    January 2014
    loading VirtualServer(1) failed to start, error: max slot limit reached HELP!
    Anyone have any ideas how to resolve this?
    LOG:
    2014-01-19 17:50:46.220915|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-01-19 17:50:46.221915|INFO    |ServerLibPriv |   | SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 64bit
    2014-01-19 17:50:46.221915|INFO    |ServerLibPriv |   | Using hardware aes
    2014-01-19 17:50:46.239917|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-01-19 17:50:46.239917|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2014-01-19 17:50:46.240917|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2014-01-19 17:50:46.269982|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2014-01-19 17:50:47.800178|INFO    |              |   | Puzzle precompute time: 1518
    2014-01-19 17:50:47.801117|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2014-01-19 17:50:47.860152|ERROR   |VirtualSvrMgr |   | loading VirtualServer(1) failed to start, error: max slot limit reached
    2014-01-19 17:50:47.861141|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2014-01-19 17:50:47.862140|INFO    |Query         |   | listening on 0.0.0.0:10011
    2014-01-19 17:50:49.941522|INFO    |GetWanIP      |   | WAN ip: x.x.x.x
    April 2011
    1,266
    You have no valid license. So you are allowed to run 1 virtual server with 32 slots. If you have configured more then 32 slots in that virtual server I'd suggest that you lower this number again. Start server, login to server query, select server 1 and edit slots to 32. Then your virtual server should be able to start again.
    January 2014
    And how?
    Sorry but i'm a newby
    January 2014
    Thanks a lot!
    April 2011
    1,266
    ***Deleted*** Bad advice! Not supported.
    That isn't the supported way and you know this.
    It should have been starting the server, logging into server query interface as serveradmin and editing the virtual server.
    It would work this way:
    Login to server query with your preferred telnet client on server-ip tcp-port 10011 and using the following command sequence.
    login client_login_name=serveradmin client_login_password=xyz
    use sid=1 -virtual
    serveredit virtualserver_maxclients=32
    serverstart sid=1
    logout
    Elements in red should be replaced with the value for your server.
    June 2013
    TeamSpeak Community Forums
    108
    use sid=1 -virtual
    serverstart sid=1
    logout
    Instead of using login client_login_name=serveradmin client_login_password=xyz , you could just do --> "login serveradmin password"
    February 2016
    Ukraine
    use sid=1 -virtual
    serverstart sid=1
    logout
    Thx for help dude!
  1. Max slot limit reached above 32 slots "Error id=2817"
    By BigGreenBudz in forum Server Support
    Last Post: March 25th, 2016, 02:28 PM
  2. Replies: 1
    Last Post: November 24th, 2015, 09:03 AM
  3. VirtualServer Limit Reached
    By FSXCorps in forum Server Support
    Last Post: June 25th, 2013, 04:39 PM
  4. Replies: 3
    Last Post: March 26th, 2013, 07:01 AM
  5. Non profit license and "max slot limit reached" error.
    By Beliar in forum Linux / FreeBSD
    Last Post: July 28th, 2010, 07:37 AM
