Results 1 to 2 of 2
    January 2014
    (Urgent) Microphone issues
    Hey thanks for reading,
    I recently bought a Medusa NX USB 5.1 Surround Headset (SpeedLink) which I took out of the box, plugged it in to the USB hole, I went into Sound, under 'Recording' I see 'Microphone' and green lines moving up and down which means it's working.
    However when I go into TeamSpeak it doesn't work, I can hear people but they can't hear me. At best they hear sound for half a second and then it disappears.
    I went into Options > Capture and set my capture Device as 'LeMicrophone' (I renamed it that) and it should work with Push to talk but doesn't so I tried Continuous Transmission and Voice Activation Detection and still nothing.
    I went in the program called 'Sound Recorder' and I recorded myself and I came out perfectly and could hear myself. I then went onto an online microphone testing program and it works there as well. Went to Skype and green bars move smoothly as I talk so I guess it works.
    I tried Ventrilo and it doesn't work there either.
    So for some reason TS and Vent won't work with my mic.
    Anyone have any ideas?
    September 2013
    Croatia
    93
    Did u get any driver with the microphone? Your problem must be on capture device, the one u set is probably aint right......and try putting direct sound on capture mode.
  1. Urgent Server Issues - No ticket reponse
    By Alderman in forum Server Support
    Last Post: June 25th, 2013, 04:54 PM
