Results 1 to 9 of 9
    January 2014
    server randomly crashing
    my server is randomly crashing, here is the log:
    TS3ANetwork::Connect failed error: 110
    2014-01-20 15:28:58.920509|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-01-20 15:28:58.920657|INFO    |ServerLibPriv |   | SystemInformation: Linux 2.6.32-358.14.1.el6.x86_64 #1 SMP Tue Jul 16 23:51:20 UTC 2013 x86_64 Binary: 64bit
    2014-01-20 15:28:58.921809|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-01-20 15:28:58.921854|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2014-01-20 15:28:58.922176|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2014-01-20 15:29:13.952426|ERROR   |              |   | TS3ANetwork::Connect failed error: 110
    2014-01-20 15:29:13.952504|ERROR   |              |   | Unable to connect to primary address, trying secondary
    2014-01-20 15:29:13.955977|ERROR   |              |   | TS3ANetwork::ResolveHostName failed error: -2 (Name or service not known) 0
    2014-01-20 15:29:13.959986|ERROR   |Accounting    |   | Unable to connect to accounting server
    2014-01-20 15:29:13.960022|INFO    |Accounting    |   | Licensing Information
    2014-01-20 15:29:13.960046|INFO    |Accounting    |   | type              : Non-profit
    2014-01-20 15:29:13.960083|INFO    |Accounting    |   | starting date     : Thu Jan 16 00:00:00 2014
    2014-01-20 15:29:13.960108|INFO    |Accounting    |   | ending date       : Wed Jul 16 00:00:00 2014
    2014-01-20 15:29:13.960128|INFO    |Accounting    |   | max virtualservers: 10
    2014-01-20 15:29:13.960147|INFO    |Accounting    |   | max slots         : 512
    2014-01-20 15:29:14.572821|INFO    |              |   | Puzzle precompute time: 601
    2014-01-20 15:29:14.573072|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2014-01-20 15:29:14.605261|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2014-01-20 15:29:14.605751|INFO    |Query         |   | listening on 0.0.0.0:10011
    2014-01-20 15:29:29.670424|ERROR   |              |   | TS3ANetwork::Connect failed error: 110
    2014-01-20 15:29:29.670504|ERROR   |              |   | Unable to connect to primary address, trying secondary
    2014-01-20 15:29:29.675524|ERROR   |              |   | TS3ANetwork::ResolveHostName failed error: -2 (Name or service not known) 0
    any idea what could cause it? i swift restart gets it back up but it seems to crash every hour or so?
    August 2013
    530
    "Accounting Unable to connect to accounting server" and "TS3ANetwork::ResolveHostName failed error: -2 (Name or service not known) 0"
    Please read this FAQ entry: https://support.teamspeakusa.com/ind...k-3-server-use
    In addition to that, packets originating from or sent to accounting.teamspeak.com:2008 (TCP) and weblist.teamspeak.com:2010 (UDP) must not be blocked. The local port for these connections is randomly assigned by the operating system when the connection is established.
    January 2014
    ok those ports are open now, ill keep my eye on logs if it crashes again, thanks for your help
    January 2014
    Question [HELP] Unable to connect to primary address (Randoms Crash)
    Hi all,
    I've a problem with my Teamspeak 3 Server on Debian 7.
    I use a NPL License since this moorning but ...
    In this afternoon the server crashed 3 times.
    Here is a screenshot from ts3 logs.
    Can someone help me ?
    (And how can i do a script which check if server is ON every 5 minutes and if not ON the script has to start it ?)
    January 2014
    it crashed again with the following errors:
    2014-01-20 20:14:35.478498|INFO |Accounting | | Licensing Information
    2014-01-20 20:14:35.478522|INFO |Accounting | | type : Non-profit
    2014-01-20 20:14:35.478560|INFO |Accounting | | starting date : Thu Jan 16 00:00:00 2014
    2014-01-20 20:14:35.478584|INFO |Accounting | | ending date : Wed Jul 16 00:00:00 2014
    2014-01-20 20:14:35.478603|INFO |Accounting | | max virtualservers: 10
    2014-01-20 20:14:35.478622|INFO |Accounting | | max slots : 512
    2014-01-20 20:14:36.209092|INFO | | | Puzzle precompute time: 718
    2014-01-20 20:14:36.209341|INFO |FileManager | | listening on 0.0.0.0:30033
    2014-01-20 20:14:36.321528|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2014-01-20 20:14:36.322157|INFO |Query | | listening on 0.0.0.0:10011
    2014-01-20 20:14:51.387410|ERROR | | | TS3ANetwork::Connect failed error: 110
    2014-01-20 20:14:51.387499|ERROR | | | Unable to connect to primary address, trying secondary
    2014-01-20 20:14:51.404608|ERROR | | | TS3ANetwork::ResolveHostName failed error: -2 (Name or service not known) 0
    2014-01-20 20:16:16.465250|INFO |Query | | query from 1 81.107.49.238:63884 issued: login with account "serveradmin"(serveradmin)
    2,698
    Quote Originally Posted by Garvey View Post
    Maybe this thread could help.
    http://forum.teamspeak.com/showthrea...ght=accounting
    Try with
    ping accounting.teamspeak.com
    from your server computer.
    It must to resolve and to reach to 80.190.145.215.
    August 2013
    530
    About the accounting issue - please read this: https://support.teamspeakusa.com/ind...k-3-server-use
    About the script: You can use Crontab to execute certain commands repeatedly in certain time intervals and you can use the output of "./ts3server_startscript.sh status" to check whether your server is running or not.
    January 2014
    Thanks i solved the problem by opening the port 2010 TCP in/OUT on my debian and it seems to stop random crash.
    For crontab i'll learn how it works.
    April 2011
    1,266
    Quote Originally Posted by Rouche View Post
    [...] seems to stop random crash.
    I don't like it when it's called a crash. The server did not crash. A crash is a fault situation which is not properly handled by the program which results in an abnormal termination of that program. In your case the server absolutly cleanly shuts down because he couldn't verify his license. That is no crash!
  1. Randoms Creating Channels?
    By Neefgi in forum Permission System
    Last Post: June 26th, 2015, 04:52 AM
  2. Unable to Link TS Address to Domain
    By Jollyj3ssicA in forum Linux / FreeBSD
    Last Post: June 15th, 2014, 01:34 PM
  3. Randoms keep joining! Please help!
    By taconinja45 in forum Server Support
    Last Post: March 13th, 2013, 08:30 AM
