Results 1 to 6 of 6
    January 2014
    Problem connecting to a server.
    I'll try to make this thread as short as possible and pardon me if i'm posting in the wrong section.
    So when i try to connect to a friends server, which is (example) Servername.ts3.serverhostname.com , it connects me to (example) serverhostname.com ( if you want the real IP to test pm me i guess.) This happens to me at least once a day and its getting really annoying, my friends say they have that problem too, but not as often as me, i've been experiencing this for over two months now, i would really like to have a solution, thanks
    2,698
    Quote Originally Posted by Nick_Bc View Post
    Is that happenning with PC clients or Android devices?
    January 2014
    Only on pc
    2,698
    Only on pc
    You should see your client logs and compare when connection is ok and when it "fails" connecting to other server.
    The client log --> Tools --> Client log
    Probably your case is similar to this one:
    http://forum.teamspeak.com/showthrea...desired-server
    January 2014
    Well, I was able to temp fixing it by ipconfig/flushdns , the problem kept appearing once in a while but meh... i guess ill have to live with it, anyway, thanks.
    (this can be locked or w/e)
    2,698
    Well, if the final IP is not a dynamic one you could indicate in your bookmarks the final IP and port that the client resolves correctly and "forget" the addressname.
  1. Problem with connecting TS3 server
    By ATSARU in forum Windows
    Last Post: May 16th, 2011, 01:53 PM
